OFSSET PICTURES&SET UP THREAD
Old Jan 20, 2022 | 01:19 PM
  #176
604 C63's Avatar
2012 E550 Cabrio
Originally Posted by FrankTDot
Hey,
Believe me, I've read every post and drooled over every photo but almost everyone is running 19" or 20" and I want to stick to 18" since I've just bought a new set of tires.
I'll keep researching.
Thanks for your help.
As long as you are adjusting the profile of your tires to make sure that you have the same circumference, the offset will stay the same.
ie a 35 series tire on a 18" instead of a 30 series on an 19 etc.
As has been mentioned, you need to stay within a couple % or your traction control will be screwed up.
But 18, 19, 20....no matter, the offset should be the same.
Old Jan 24, 2022 | 07:38 PM
  #177
Dnasty's Avatar
2010 e550 coupe
Originally Posted by Neko 1
Here's my 2015 E400 With Rennen CSL 3s Front 19 x 8.5 et35 245/35/19 Rear 19 x 9.5 et38 275/30/19 I have Amg Sport Pkg with factory 10mm lowered suspension <--- Fyi.
Which tires and psi are you running. I have pretty much the exact same setup but looks different on your vehicle... are these the extreme contact sport or dsw?
Old Jan 28, 2022 | 12:15 PM
  #178
m1l3n's Avatar
2013 C300 4Matic
I'm looking at the Mandrus Millennium wheels however the sizes are 19x8.5 et 42 (front) and 19x9.5 et53
I want a look that has the wheels flush with the fenders or maybe just slightly in... with those offset are the rims going to be too far in and not flush? would they work?
Old Feb 1, 2022 | 09:53 PM
  #179
Visionariable's Avatar
2016 E400 4MATIC Coupe
New member to the forum, but this is the setup i’ve been running on my E400 4MATIC for the past 8 months. My local performance shop is an absolute wizard for confidently being able to make this setup work properly and safely.
H&R Lowering Springs
Vertini RFS1.3 RotaryFlow Forged wheels
20x9 fronts on 245/35/20
20x10 rears on 285/25/20
Nitto Invo tires
I know the question everyone will ask is, does it rub? Absolutely no rubbing in the front, even at full lock. In the rears however, initially it was rubbing but only when there was a deep dip in the pavement. It was corrected by my performance shop by slightly curving upwards the part of the rear body that tucks into the wheel well. That is about as well that I could describe it but it was done professionally and looks literally untouched as it did from the factory. No issues with rubbing since then.
As I said in the beginning, i’ve been running this setup for the past almost 9 months with no issues. Thankfully my local Florida roads are not bad so this works fine as my daily driver putting little mileage on it. I’m young so i’m not too bothered by a stiff ride, dodging the occasional pothole, etc. It is a very aggressive setup and most definitely is not for everyone but I love the way the car sits and it’s a big head turner and compliment-getter everywhere I go.
Old Feb 1, 2022 | 10:45 PM
  #180
604 C63's Avatar
2012 E550 Cabrio
What are the offsets?
Car looks great but all of that feedback re rubbing is meaningless without offset info.
Car does look good tho
Old Feb 14, 2022 | 12:19 PM
  #181
Dnasty's Avatar
2010 e550 coupe
Wondering if either of these will work in the front.
19x8.5" et33 255/35/19
or
19x8.5" et33 245/40/19
I'm currently running 245/35/19 et33 and wanted to get more sidewall to match my rears. I have no rubbing at all up front with this but not sure how much space I can afford here.
Old Feb 14, 2022 | 12:31 PM
  #182
PhuongNguyen's Avatar
2013 E550 coupe
Offset
or
If you’re already running that size, then you yourself would be the person to ask, since you already have it in hand. Just use a little imagination since probably no one on here has run that. I see no issues with 245/40
Old Feb 14, 2022 | 01:03 PM
  #183
Dnasty's Avatar
2010 e550 coupe
I have 245/35 I am looking to go to 245/40..or 255/35
Old Feb 14, 2022 | 01:12 PM
  #184
2013 E550 coupe
Use your imagination LoL. I don’t think anyone here is running that. With 245/40 you will be slight taller. With 255/35 you will be 5mm wider each side but shorter.
Old Feb 14, 2022 | 01:19 PM
  #185
Dnasty's Avatar
2010 e550 coupe
Oh believe me i've been imagining all sorts of things. I posted here in hopes someone had done it or something similar before I roll the dice. I understand the numbers though I think the 245/40s may be fine or they may be way too tall for this car but rather find out here before having them mounted.
Old Feb 14, 2022 | 01:28 PM
  #186
2013 E550 coupe
well to help you out I did run 255/35r18 ET33 on my rears. Stock is et48 and I put a 15mm spacer on it making it 33. Fit just fine and had phenomenal flush fitment. I did not put it on the fronts though unfortunately. You running square or staggered?
Old Feb 14, 2022 | 01:40 PM
  #187
Dnasty's Avatar
2010 e550 coupe
I'm running staggered.. 275 in the back et38. I could see your setup definitely working on the rears... the front makes me a little nervous. I think going 255 may be safer than going up in aspect as I can get a 5mil spacer if necessary. Very difficult for me to get any measurements for clearance in here though. I am lowered on coilovers as well.
How did this setup run that you posted? Vossen CV1. 19x10 front and rear. Not sure if anyone else put 10” wide in the fronts.
255/35 +40 offset
285/30 +55 offset
Old Mar 6, 2022 | 06:05 PM
  #188
Dnasty's Avatar
2010 e550 coupe
Originally Posted by Stevie101
Need your help on tire sizes please.
I have available for my 2009 C207 the following, 8.5*19 ET34.5 and 9.5*19 ET48. The current tyres on these wheels are 255/35 & 285/30 and they come from a C218.
If I leave my car at stock height I believe I can put on 245/35 and 275/30 without any rubbing back or front whatsoever, correct?
Can I get away with the 285/30's in the back? I understand the 255/35's are too big for the front.
If I drop it with springs, can I use 245/35 and 275/30 or will the tyres need to be 235/35 and 265/30?
Thanks in advance!
Why do you say that 255/35/19 is too big for the front?
Old Mar 6, 2022 | 06:16 PM
  #189
2013 E550 coupe
maybe he means at a certain offset. Yes the 19x10 255 front sand 285 rears work really well. Still got them on now. Just hate having to use a spacer for the fronts that’s all. I’m one of the first to put a 10” wheel on the front did a c207/w204. My next goal is to be one of the first to put 305 tires on the back without wide body modifications, just a little fender rolling. Just need to find a 10.5” wheel with 52-55 offset.
Old Mar 6, 2022 | 07:22 PM
  #190
Dnasty's Avatar
2010 e550 coupe
305s would look good on this car. I have 35 offset up front I’m gonna try the 255/35, I see another user fit these with 40 offset and claims no rubbing and I can fit close to a .7 inch between the perch and tire with 245. I tried the 245/40s but it slightly grazes the spring on large compression when the body shifts. I could drive the 40s comfortably and the ride is really good but I think it’s just too tall for the front looks wise. What is wrong with the spacer does it give vibration?
Old Mar 7, 2022 | 04:35 AM
  #191
Stevie101's Avatar
2009 C207
I never said I tried 255/35's. That's what size they came with as they came from a C218.
I don't think they would have worked. I have on 235/35s, and with an ET of 34.5 they are flush. 255/35 would have been too much for my liking.
Old Apr 4, 2022 | 11:43 AM
  #192
SULTIM's Avatar
2012 E350
Any issues with running 18x8.5 ET48 on both front and the back? Also, recomended tire sizes for a low profile. TIA
Old Jul 24, 2022 | 06:21 PM
  #193
fnfastmb's Avatar
2016 GLE63s 2010 E63 Coupe...
2010 E550
Brixton Forged PF7 Targa
Front – 20x8.5 ET35 245/30/20
Rear – 20x9.5 ET46 275/30/20
KW Coilovers
zero rub in front or rear.
Old Jul 24, 2022 | 06:47 PM
  #194
2013 E550 coupe
Nice ride!
BEAUTIFUL car! You spent a nice dollar on that ride. Brixton wheels, kw coilovers, full body kit, AMG brakes.
Originally Posted by fnfastmb
2010 E550
KW Coilovers
Old Jul 24, 2022 | 07:11 PM
  #195
fnfastmb's Avatar
Thanks! It has been quite a journey as are most builds I suppose...
Brakes from the w204 c63 are direct bolt up on rear and I had the black bracket made to convert the fronts from the c63
More pics..
Old Jul 24, 2022 | 07:26 PM
  #196
2013 E550 coupe
are the fronts 390mm?
More pics..
Old Jul 24, 2022 | 08:53 PM
  #197
Dnasty's Avatar
2010 e550 coupe
2010 E550
KW Coilovers
Looks nice what color is your wrap. Reminds me a little of mine in satin dark grey. I was gonna go with some stance wheels very similar to those but they w were on back order. Also did you change your exhaust setup?
Old Jul 24, 2022 | 10:21 PM
  #198
fnfastmb's Avatar
The fronts are 360 and the rears are 330. I had asked the shop that did the brake conversion to document the build for me and so he took a picture of the rear rotor and caliper with the bracket for the fronts...
Old Jul 24, 2022 | 10:33 PM
  #199
fnfastmb's Avatar
Thanks! Wrap is Avery Denison color is Brushed Titanium
GMP in Charlotte did the c63 brake conversion, KW coilovers and a set of Kleeman headers. As part of that they did x-pipe, resonator delete, cutouts and the mufflers were left stock. I replaced the chrome quad tips in these pictures with black ones to go with the all the black out I had done.
Old Aug 29, 2022 | 02:57 AM
  #200
Kaho_0409's Avatar
w207
Do you have rubbing issue?
Originally Posted by Dr-Nab
my set up:
front: ET40 8.5x19 235/35
rear: ET38 9.5x19 265/30
with H&R springs
Attachment 410109
Attachment 410110
Attachment 410111
My e350 rear ET38 9.5x19 275/30 has rubbing issue. Could 265/30 solve this problem?
