A FEW NOOB Qs?.
87 Supra Turbo / 89 300ce
![Arrow](https://mbworld.org/forums/images/icons/icon2.gif)
hi new to the benz world here and i have a few qs.?
my heat or ac doesnt work and its nov. why?
and my car idels like crap i did order the bosch supers h8dc spark plugs.
and what trans do i have i wanna do the complete tune up on the car ect.
and where can i get the trans filter.
i just payd for the spark plugs, wires, rotor arm, dist cap, $300
<~~ is that normal? lol
so please help me out here i wanna get it in good shape and what is the maintnence i gota do to it.?
![crazy](https://mbworld.org/forums/images/smilies/crazy.gif)
Mercedes-Benz w124
Does it only idle roughly or also while driving? If only while idle, then it is most likely the motor mounts which i think are about $90 for the pair. You can pick up the transmission fluid and filter at the dealer, just tell them which car you drive. For the heat/ac, does it always not work? i have a similar problem which it doesn't initiate when i push the button. Most of the time the ac doesn't work for me but works decently , not great... at higher speeds such at 45 and up. Same thing with heat. And do these cars have the pollen/charcoal filters or what not? because it has an odd smell when i turn on the heat. Good luck with your car and enjoy her!
it idels rough when stoped in gear.
while driving its fine and the heat or a/c dont work at all and it geting colder
so the car will idle rough cause of the motor mounts.? wired.
lol my other car is a SUPRA so this MB it all new to me so i need some help and advice.
how bout the dif fluid ?
well its an 89 300CE
165xxx miles automatic
i just recently replaced the spark plugs but am getin new ones so hope that works and i also changed the oil filter and air filter i put syn oil.
what kinda info more do you need
![hammer](https://mbworld.org/forums/images/smilies/bonk.gif)
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
We need more info, like mileage...how about previous service...does it have service records of any sort??? I have, as well as many others here, have many different sources for parts to share with you but give some more info regarding your vehicle...
Yellow 87 300e
A/C problem
hello guys, i also experienced the same problem with my AC. The ac sometimes works and sometimes doesnt work. THe problem with this is the motor/fan for the AC. You need to simply replace this with a new one and your AC and heater will be blowing just with the touch of your button. I had mine replaced recently and cost me about 2-300 dollars. I can refer you guys to a good MB mechanic (friend of mine) if you live around my area.
Picture below is the old motor/fan from my 1987 300e
Originally Posted by 12four
I'm changing my motor mounts tomorow what should I expect. Any help is good. ![rice](https://mbworld.org/forums/images/smilies/rice.gif)
its easier to do this on a rack. i would bet its a biach to do it on jack stands and a jack.
