how do i change the instument panal lights
i have a 300e and i was woundering in my dash board where the speedometer is etc... one of the lights went out, but i cant figure out how to change it, or take the light out or anything. and i dont want to break it.can anyone tell me how to do it please? thanks
1988 300E
Yeah I kinda need that info too, my lights are soo dim and even with the knob turned to the max, its as a dull as a donkey's intelligence !!
I have that special tool to pull the cluster out, but....didnt know how to pull it out !!
Plus, I also have the chrome rings..which i want to install....so if anyone can write that part up too....would be great !!
a TVR Cerbera Speed Twelve
89 300TE, and 68 280sel
you need to pull the cluster out and remove the guages from the cluster housing then insert the rings in through the back. Not that hard.
1988 300E
Sounds good !! Thanks
There's no way that the Glass separates from the entire housing does it? I also got this Carbon Fibre thing to go on to the instrument cluster.....so yeah !!
88-300CE TWIN TURBO, 99-C43, 05-G55K, 71-280SL, 94-E320 CAB, 08 CLK63 BLACK SERIES
The glass ( plastic) can be separated from the cluster, but there is a strong chance that it will crack as you attempt to seperate it !
1988 300E
LOL .....thanx for the advance warning !! So...whats the best approach to it? Get it done by a profession and pay **** loads, or take a chance and if it breaks...buy a new plastic.....that is if its even sold !!! Plus...how much would it cost !! If it's too expensive, then I guess I shouldn't bother with it !! What a waste though !!
