Cheap W124 Modding
Old May 22, 2008 | 12:48 PM
  #51
berti_00's Avatar
2016 Cls63s AMG
Originally Posted by STLe320
...Loudest car in all of St. Louis County, MO and Edwardsville IL...
But who knows?
hahahaha what in lords name do you have in that thing? am trying to figure out why mine keeps cutting off when i turn it up.. it deff pisses the jessus out of me
Old May 22, 2008 | 01:08 PM
  #52
cap'n jasper's Avatar
W124
Originally Posted by GEDaggett
Back to the topic the best mod you can do to a Benz diesel is run veggie. In the states you can get a set up for about $800 (which is like 25 euro these days) and convert vegetable oil to diesel and it cost about 60 cents a gallon. IT takes a bit of work but you can "brew" about 100 - 200 gallons at a time and it stores for about 4 - 6 months.
With the W124 diesel you don't even need to brew it. Just mix fresh cooking oil with normal diesel (50:50) and you're good to go. Lots of people in the UK do it now that diesel is £1.30/ltr ($10/us gallon) and cooking oil is less than £1/ltr.
You can even use neat, used cooking oil provided you filter all the bits out.
Old May 22, 2008 | 01:44 PM
  #53
STLe320's Avatar
95 e320...sold the rest
I have 2 12" Kicker L7's in a ported box tuned to 34hz with an adjustable port to tune it to different hertz. They're powered by a Hifonics Brutus 1600 watt amp wired down to 1 ohm. The whole system is ran with 1/0 gauge wire. And I have a 1.2 farad capacitor..even though it doesn't help lol.
And as for your system cutting out, it could either be a safety issue (head-unit turning it off) or your amp is getting too hot. If it's the amp, you can easily get a fan to keep it cool
Old May 22, 2008 | 02:05 PM
  #54
Makahveli's Avatar
"88 300CE- First Year Production
I do like the drop on your car though
Old May 22, 2008 | 02:10 PM
  #55
Makahveli's Avatar
STL doesn't your trunk rattle when you turn it up? I did some mods to my rear shelf to make the bass clearer and louder where rattling is so minimal. 800watts class d mono is good for me.
Old May 22, 2008 | 02:22 PM
  #56
Demos_sav's Avatar
Mercedes Benz W124 250D
what about my rust spot and dinged up rim?...Just can't get any love around here.
Lol I love them
Old May 22, 2008 | 03:17 PM
  #57
YNVDIZW124's Avatar
lots of cars
How many voice coils are on your subs? what ohms are they? Maybe you have a weak amp or wired the subs wrong.
About that rattle....just use a lot of dynamat and expanding foam.....
My system right now is weak but clean....900w rms to a single treo 10" ssi sub...
I really need a 150amp alternator but eh...i don't bump music that much anymore...
Old May 22, 2008 | 05:04 PM
  #58
Demos_sav's Avatar
I forgot to mention I love your side skirts and that custom painting on the wheels
Old May 22, 2008 | 05:09 PM
  #59
STLe320's Avatar
I just used A LOT of dynamat and expanding foam. I removed my rear speakers so I could have ports coming into the cabin
Also, I forgot to mention my subs are DVC and 4 ohm.
Old May 23, 2008 | 09:14 PM
  #60
Demos_sav's Avatar
Can someone tell me how much the bolt diameter is and what bolt pattern do these cars have? After the rims I may be getting some wheel spacers too so that my car can look more aggressive
Old May 23, 2008 | 09:43 PM
  #61
YNVDIZW124's Avatar
lots of cars
12mmx1.5 ball seat and conical for aftermarket wheels bolt pattern is 5x112 center bore is 66.59..
Old May 25, 2008 | 01:06 AM
  #62
berti_00's Avatar
2016 Cls63s AMG
i just have one JL and one other one they are loud and sh!it but i dono i think its the amp that ****s up its hella annoying it cutts off sometimes at a musics that is my fav part lol i just get mad... could it be the amP
Old May 25, 2008 | 01:37 AM
  #63
STLe320's Avatar
is it your whole system shutting off of just the bass?
because if it's just the bass it's your amp most likely, but if it's the whole thing then it's something in the head unit. most likely a safety function.
Old May 25, 2008 | 10:00 PM
  #64
berti_00's Avatar
2016 Cls63s AMG
no dude its not the head unit.... cuz my other cd player did the same thing before i had the dvd put in... i think its somting with the amp or wire i am not sure... but i have to figure it
Old May 25, 2008 | 10:32 PM
  #65
ps2cho's Avatar
E
Originally Posted by Demos_sav
So what do you guys think of my car now?
I really like that grill. I will have to add that to my buy list this summer once my misfire is resolved. I've got a little chunk missing in the front of mine anyway, so it needs to be replaced.
Old May 25, 2008 | 11:24 PM
  #66
RHW's Avatar
RHW
94 Wagon and 94 Cabriolet
Berti, it could act like that if it was after a little while of turning it up and the amp was overheating...is there ventilation and or a fan?
Old May 25, 2008 | 11:30 PM
  #67
GEDaggett's Avatar
1994 E320 (current)
Talk about jacking a thread. Guess that happens.
Old May 26, 2008 | 12:37 AM
  #68
YNVDIZW124's Avatar
lots of cars
Berti, You should match the rms of you sub to your amp. If you have a 600wrms sub with a 300w max amp it's gonna go into protection sec after you turn it on. if your sub has dual voice coils and you wire it down to 2ohms it's gonna cut off. You mostly likely have a AB class amp which aren't good for anyhting below 2ohms. Get a class D amp and match the rms of the sub to your amp...
Old May 26, 2008 | 04:39 AM
  #69
Demos_sav's Avatar
I don't mind..YNVDIZW124 thank you for those useful information
Old May 26, 2008 | 04:42 PM
  #70
Makahveli's Avatar
I remember seeing a guy here before use a rattle can to paint his lower cladding, how long is that good for? I don't think he had to worry about even strokes cause the color was black. Is there a such thing as clear coat from a spray can?
Old May 26, 2008 | 04:52 PM
  #71
Makahveli's Avatar
I don't have the skillz zorro had but I was playing with an old picture of my CE... Actually this is a 2 year old pic now that I was just seeing what you guys think of the color scheme? note that I now have that carat duchalet runk spoiler and a front spoiler that needs to be put on now.
Attached Thumbnails Cheap W124 Modding-mercedes-paint.jpg   Cheap W124 Modding-mercedes-b4-paint.jpg
Old May 26, 2008 | 09:47 PM
  #72
berti_00's Avatar
2016 Cls63s AMG
thats exactly what its happening... when its been on for a while
Old May 27, 2008 | 01:00 AM
  #73
STLe320's Avatar
like i said twice...get a fan!
Old May 27, 2008 | 01:14 AM
  #74
RHW's Avatar
RHW
lol, just read backwards...
Old Jun 8, 2008 | 04:03 PM
  #75
Demos_sav's Avatar
Guys my car has been upgraded and more are still to come. Tell me what you think. The rims are 16" and the tires are Michelin Primacy HP 205/55/16
Attached Thumbnails Cheap W124 Modding-dsc00231.jpg   Cheap W124 Modding-dsc00237.jpg   Cheap W124 Modding-dsc00238.jpg   Cheap W124 Modding-dsc00239.jpg   Cheap W124 Modding-dsc00240.jpg
