Something wicked this way comes
And yes I did such a thing when I was younger, but they made me pay to haul it back out.
First the blower motor is screeching, trying to die...taxing the old blower motor relay, which may or may not click back on. Then the door alarm is going off on the driver's door every time I unlock the vehicle. And last, but not least, the rear diver's side window (today) decided not to roll all the way back up.
I found some good links to the last problem in here. It seems to be the consensus that the actual door motor itself is very long lived and it's either a problem with the door regulator or the regulator channel needs lube. I've tried just to lift/push the window closed while working the switch with no avail. It stops about two inches from the top every time...just like it was programed to. Vexing little bast@$d.
If I could just get it back up without taking the door apart, I'd be ecstatic.All of which I'd tackle gladly if only I had a semi-heated garage space. I consider the window event the worst affront, because they'll use that to gain access to my stereo system. I have to park in the street too, which exacerbates the problem.
Well, I say "gladly" tentatively....if I remember correctly, the blower motor requires the dash to come out? And if so, I'd be going after all those vacuum pots as well in there that work the HVAC system. My idea to 'limp' through winter isn't panning out very well.
Oi, vai iz mir! I though God watched over fools & children??
Kevin
'92 300TE 4matic
The rear window regulators do go out and cost an absurd amount of money now. You can buy a whole car on craigslist for retail on one of these babies.
The alarm is easy. Just unplug the thing. It is under the passenger floor carpet, in front.
Excellent on disarming that turd alarm system, thank you!
The window regulator sounds just....awful. I guess I'll sleaze around and try to find some salvage thing for now. What a crock....what the hell is it made of, iridium???
Kevin
'92 300TE 4matic
Yeah, I've wandered through many a 'zorro' post, not impressed and how exactly does that pertain; other than you wanting to say that?
Kevin
'92 300TE 4matic
Kevin
'92 300TE 4matic
ZedStyle
'95 E320
Oooooooh, good thing I never set out in life to impress n00bs with a penchant for run-on sentences.
Enjoy your stay here, we are super friendly to insulting, desert eagle-toting know-it-alls.
ZorroAMG
'90 Better than yours.
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
Kevin
'92 300TE 4matic
If you're sure the motor's making the noise, you should buy a replacement and a regulator while your at it and prepare to spend a day for R&R. The difficulty is R&R the fan cages. I actually have a brush replacement kit that I've not needed yet.
You might check the door switch elect connector that's housed in the plastic plug (largest one) on the end of the door. I've had to disable an alarm many years ago not finding the cause.
I've never had a window motor and regulator fail, it was usually the switch or wiring at the motor. Since yours seems to work until full closure, the regulator could be miss-aligned causing the glass to bind in the track. That could lead to motor failure if not fixed. The two door failure also supports what I was told recently in that the switches are connected diagonally. First troubleshooting the windows is switching the switches with known good switchs. In your case the passenger and rear left. If they are good you'll have to pull the door panels which is not difficult. The only difficulty is pulling it up hard enough without breaking the clips.
Good luck and hope you don't need the "Desert Eagle" for this car...
Kevin
'92 300TE 4matic
BTW, if you tax the blower motor too much, it can cause an electrical fire....I 'caught' mine as smoke was starting to come through the vents. Instead of a blower motor, I had to pay for the replacement of the relay as well.
So don't go nuts looking for relays unless of course I'm wrong on this...Appatula
86' 300E Sedan
just FYI, threads usually meander slightly here, since most of us 'e-know' each other pretty well at this point. expect more random posts in your threads in the future, and apologies in advance on behalf of my friends and i for the aggravation this will be sure to cause you.
ZedStyle
'95 E320
personally, i will do my best to not comment in any thread you start. anyway, good luck with your issues.
That would actually be wonderful, thank you in advance for your lack of attendance.
i am not an alpha dog, and i am not trying to run the show with useless banter. i just made a comment in one of your threads that apparently created a wrinkle in your rectum. it caused you no harm, but because you decided to make mountains out of molehills, your thread is now VERY far off base, which is ironic.
as for my lack of attendance, I read the title of this thread, commented on it becuase that was the first thing i thought of when i saw it, and would have then proceeded to search/research your issues and post some help, which is exactly what i did in your OTHER thread, in which i was trying to help you solve your door alarm issue. your menstrual flow scuttled that possibility here quick-fast. and anyway, read your original post, it's one long complaint, and you only ask one question.
you have a serious attitude problem, and while this is primarily a technical forum, i find it very hard to believe that you do not see that there is a VERY strong social aspect to it as well.
you have now resorted to personally insulting members like zorro who have helped more members in their time here than you have snide comments about.
like i said before, without insulting you, that i will stay out of your threads. but if you feel the need to be rude or insult me, i will keep coming back to address it. your testes wrinkled when i commented on a thread title, i can only imagine the effect it wil have on you when every thread goes 'round the world and back.
But you keep coming back anyway and you're "insulting" a hell of a lot more than I ever did. Yeah, I see that there's more here than just technical talk, but I also see competition for exclusivity in a 'country club' type atmosphere. I freely admit that I'm a nobody, but that's a tougher admission for some here.
