source for shorter lug bolts
Old May 31, 2011 | 09:33 AM
midnightsaint's Avatar
2001 E320 4matic Estate
I am needing shorter lug bolts. I need them to be about 1/2 inch shorter than stock on my e320. Where do i get them. all the guys at my parts desk looks at me stupid when i ask them.
Old May 31, 2011 | 03:29 PM
RHW's Avatar
RHW
94 Wagon and 94 Cabriolet
I think stockers are 27mm, on ebay, I see 23mm and 24mm but haven't seen shorter.
Old May 31, 2011 | 04:47 PM
ima55r2's Avatar
2018 Mclaren 720s, 2021 Aston Martin DBX
These guys might have what you need.
http://www.prestigewheel.com/
Old May 31, 2011 | 05:54 PM
edcarls's Avatar
97R129-01W163-94E320-93500E
Dremel is the final answer!
Old May 31, 2011 | 06:24 PM
ima55r2's Avatar
If you going to cut them shorter, screw on the right size nut before cutting. When you take the nut off, it will straighten out the damaged threads.
Old May 31, 2011 | 07:35 PM
This is the bolts from my car. They are 40mm long from seat to tip. So the car should have 27mm from seat to tip?
Old May 31, 2011 | 09:59 PM
ima55r2's Avatar
I'm not going to tell you what size you need so use this order form to figure it out.
http://www.prestigewheel.com/Catalog...gBoltOrder.pdf
Old Jun 1, 2011 | 01:18 AM
ohlord's Avatar
Rad/otis usa
determine shank length and lug seat shape.
They carry all sizes to adapt and about 50 bucks a complete set.
http://www.otisincla.com/
make sure you have enough threads what set of rims are you trying to install that require lugs that much shorter?
Old Jun 1, 2011 | 07:21 AM
Saijin_Naib's Avatar
1990 300ce 24v I6
My w210 e420 replica rims are the same issue. They need to be about 8mm shorter than the w124 lugs from the back face of the rim to not lock on my parking brake, but still need to have 8mm of threading exposed to engage the hub (stock w124 lugs appear to engage 7-8 threads, @ 1mm threading pitch = 7-8mm of threading needed).
For this reason, I've yet to actually find the right lugs :P
So, w124 lug from back face of stock rim = 1.3mm with over 8mm of threading exposed at the end
w124 lug or w210 lug from back face of replica rim = 2.1mm with over 8mm threading exposed at the end.
Old Jun 1, 2011 | 11:53 AM
Ohlord
I am using Borbet wheels.
Old Jun 1, 2011 | 12:47 PM
edcarls's Avatar
Same reason why I cut my original rear lug bolt to accommodate Carlsson 1/6 without hitting the e-brake mechanism.
Old Jun 1, 2011 | 08:57 PM
doc4car's Avatar
I had the same problem,I bought some for mid 80s car and it worked fine.
Dont remenber part #
