Are 17 by 8 inch wheels too wide for a W124?
I have a set of Zenetti Milano 17 x 8's on my W124 400E in the summer and i have few problems with them rubbing or anything. Everything is still original stock setup with the suspension and everything. I only have rubbing when i go over big bumps too fast. That is my only problem. So i guess you would be fine with a set.
65 or above, unless it's a larger bump, or pothole. But at the moment i'm looking into springs and what not to help with that issue, if driven conservatively i doubt you will have a problem seeing as i have a tendency to push it in unfavorable conditions and roads or so i have been told. What kind of wheels are you looking into?
