Kleemann header pics
By suicidal4life at 2007-09-28
Before I packed them up I tried test fitting them on my spare cylinder heads and noticed that one of the pipes was out of line. Its off by 3/16" which is alot worse then it looks in the pic!! FWIW the local distributor/installer that I ordered them from is handling the problem and is confident Kleemann will make it right. I'm glad I noticed this before I sent them out to Swain!!
I'll let everyone know what happens.
Link to E43's Kleemann pics
https://mbworld.org/forums/showthrea...ight=header%2A
My photos...sorry the quality sux
How are you going to map all the changes?fuel pump,injectors,timing curve?Is that all part of a kit or you flying alone on this mod?
ohlord
BTW, how far is you manifold along? I'm down to the final stages that will follow with a final polish for a mirror finish. I'm actually affraid that due to the magnesium it is going to lose it's luster quickly
But it should perform non the less. I just finishing the intake ports for the 8 butterflys where the sharpe corners are being angled and smoothed to better flow. Man, we need to pick brains sometime. My heads like a messy desk with what and when I want to do things with this system. Lastly, I've got some current info that is a must for this system. I will shoot you a PM about it.
ohlord
I'm not sure why Kleemann used individual flanges. Most headers are a single flange. The only thing I can think of is perhaps its the different expansion rates of the aluminum heads and stainless headers. If they were not allowed to expand and contract freely maybe it would cause cracking problems?
One would expect more from a "major" tuning house.Anyway, hope they fix it and you'll get what is expected from them. Do watch out for leaks due to poor fitment (i.e. doesn't sit flat on the manifold) - seen that happen on many cars.
Nice clean car btw, good luck on your project
Thank you!!
Naturally, the disappointed customer returned the order after waiting for the longest time and got Carlsson RS kit instead...sad.For the price you're paying, couldn't you just get a customed header? Seen some very good ones made and yes, design was a lot more efficient than the Kleemann and others available off the rack.
Honestly the reason I went with Kleemann was I just wanted an easy solution with the least amount of headaches
Also my cats are rattling and although I am still well under the 80K and 8 years I figured I should just bite the bullet and get some headers now instead of later. Everything I had read about Kleemann said they are top notch. I'm a pretty capable fabricator and originally was going to fab up my own headers but I have been so busy traveling and working the last year I haven't had the time to do much of anything with this car. I also considered having a shop fab up a set for me but the price would still be close to the Kleemann's and It seemed like more headaches then just buying the Kleemann's. If I wasn't able to get the Kleemann's at this price I wouldn't have bought them.
I can't wait to see some dyno numbers.
Mario
BTW whos meth injection system are you running? The more I research the more I want to mix and match the best parts from the different companies. So far I think coolingmist comes closest to what I want.
Last but not least. We all know the Eaton M90 is too small for the 5.5 and better suited for the 4.3 but what about the 5.0? I've seen several 500 engines for decent deals. I always figured if I accidentally grenade my 4.3 I would upgrade to a 500.
Your pulley is really 2"? I know you had it machined down but I didn't realize it was that small. Of course Nitro did say it was the size of a friggen quarter. I was planning on milling my pulley down in the future. I wanted to do my mods in baby steps to keep the tuning easier. First I'll get the stock system dialed in. Then add the meth and get that system figured out and running without problems then start thinking about increasing the boost. After that will come P&P'ing the heads.
BTW whos meth injection system are you running? The more I research the more I want to mix and match the best parts from the different companies. So far I think Coolingmist comes closest to what I want.
The 500 motor would be nice but you may run into ECU problems and having some one able to remap it. I doubt your motor will blow before your tranny. The tranny seems to be the weak link, so in case it does blow you should step up the 55 transmission. You motor should be fine just make sure you get your air/fuels into the low 12's and if you can find a Dimsport dealer to remap your ECU tables that would make your car even more powerful and run safe.
Good luck
Mario
I doubt your motor will blow before your tranny. The tranny seems to be the weak link, so in case it does blow you should step up the 55 transmission.[/QUOTE]
Ya I have been keeping my eyes open for a good deal on an AMG trans. Also thanks for the coolingmist info!
My replacement Kleemann headers arrived yesterday. No ill feelings towards Kleemann except I think they should have shipped the replacements a lot quicker. Everything looks kosher with the new set. Both headers easily slip over the studs on my spare heads. With the first set one side wouldn't even come close to fitting and the other side only fit if you forced it on. I'll be shipping them to Swain tech for thermal coating after the weekend.
I can't wait to get these on the car!!
I will get some better pics in a day or two. The coating looks more silver in person and has a sandpaper like appearance. Also here is a link to a Nissan forum that has some pics that better represent the color of Swains coating. http://www.titantalk.com/forums/tita...ng-photos.html
did they coat the inside?
what you gonna do with all the new found power
I doubt the extra 25HP or so (with my stock E430) will be all that noticeable but after the SC install the headers should make a dramatic improvement. Kleemann claims around 15% increase with headers on SC vehicles so that would mean the headers would add about 50HP at that point.
If you scroll down to post 15 on that Nissan forum I linked to you will see the following quote.........
I haven't yet coated any exhaust parts for the Titan, but coming from an STi & Evo (turbocharged sedans), I have some experience with different headers & exhaust parts and coatings. I've used Jet Hot, Performance Coatings, Crucial (they outsource), and Swain Tech. The Swain looked and felt much thicker and tougher (as they advertise)...I never put my hand to it when it was hot, but I did notice a huge drop in underhood temps. The non swain tech brands looked nicer, but more heat escaped the piping.
This is just one example of many similar stories and posts I read while researching Swain.
Are you suggesting I should have a machine shop mill the flange to make sure its perfectly parallel? The flanges are smooth and the welds are on the outside not up against the cylinder head like some Chevy hooker headers or something of that nature.
Here are a couple of better pics. They still suck. My photography skills are not up to par and I cannot get the color or texture to show up correctly. The pics on that Nissan forum are a much better example.
Passengers header
Drivers header
Poor attempt to show the texture
Couple of pics of the flange for Ohlord
