Headlight Moisture - need to remove
Old Dec 2, 2006 | 03:55 AM
5-Salt's Avatar
Picked up a bunch of Moisture in the Headlight and Highbeam. Heat from bulbs really gets the condesation to build up and light output very much reduced. Source of moistue is my doing from an underhood cleaning.
Is it big issue to remove and replace lens/assembly so I can dry everything out?
I gave it a look over and it looks like it's a matter of releasing couple of key fastners or a big pain in the a**.
Old Dec 2, 2006 | 04:13 AM
raymond g-'s Avatar
99 E320
if factory light units, front lens should be quick and easy removal. if aftermarket,
it may prove more challenging. or, if you can remove as many bulbs and just
aim hair dryer into the ports, that will work. one time, i just set on low heat
and went for cup of coffee and read the paper. came back to cleared lens.
Old Dec 2, 2006 | 11:55 AM
Tommy_s4's Avatar
ML320, Looking for my S4
You can also keep the lights on while driving, or you can get a Grouppe M intake that will keep you headlights dry. Trust me, it works. or you can just go get aftermarket projector headlights
Old Dec 2, 2006 | 12:02 PM
raymond g-'s Avatar
99 E320
air intake will do little to remove headlight moisture induced through engine
cleaning. aftermarket projectors have high complaint ratio due to poor sealing
against condensation and direct water entry.
Old Dec 2, 2006 | 07:48 PM
Tommy_s4's Avatar
nah i said the air intake as a joke. But really the new aftermarket lights leak. Crap i just bought mine!. damn, now i'm scared!
Old Dec 2, 2006 | 11:08 PM
OldNate's Avatar
1998 E320
Seal them with silicone, I have had mine for a while and they have never leaked thanks to raymond
Old Dec 3, 2006 | 02:43 AM
Tommy_s4's Avatar
what do you mean? go around the gasket with silicon? pics?
Old Dec 3, 2006 | 11:51 AM
OldNate's Avatar
1998 E320
The headlights come sealed, but the problem is they are not sealed well enough. Go to a local auto shop, or pep boys, and pick up some high temperature silicone that can withstand high temperatures. Then apply a bead of silicone where the lens meets the plastic housing in the back. Apply it all the way around on both headlights and you should be fine. Has it already leaked for you? I had mine in for a couple months, then I took them out and sealed them, and never had a leak.
Old Dec 3, 2006 | 12:05 PM
Tommy_s4's Avatar
nah i didnt get them yt. they are ariving 2morrow
Old Dec 3, 2006 | 12:33 PM
OldNate's Avatar
1998 E320
Okay, before you get them in, just apply the silicone, wait a couple hours, then install them.
