Headlight upgrade
I don't really now what's out there for it or where the best place to get it.
Any info is greatly appreciated...Thanks!
link: https://mbworld.org/forums/classifieds/213567-w210-xenon-headlight.html
link: https://mbworld.org/forums/showthread.php?t=213567
brighter lights are not what you need in a fog lamp,they are not for range they are for beam pattern in poor weather conditions.
Brighter headlights,polish the lens and install 65 watt osram H7 rally bulbs from danielsternlighting.
And if you want the best fog bulb he has the selective yellow fog bulb euro spec.
and while you are at it read his article about retro fit hid.
Polished lens won't do...neither will yellow fog bulbs.
I know need to know a good set of HID kits for the headlights, and a brightness most everyone uses. I think I may get the Depo housing that looks like the W211 style, will a HID conversion kit fit? What does everyone usually do, and what are my options.
Thanks for your time.
reflector design and not the prevailing projector design now common with HIDs
attached are OEM headlights for 99
If you're wanting projector HID, you'll need to make one yourself as none are
offered from M-B. This is bixenon projector fitted into a Depo. Projector is
from an E55
