srs passenger seat sensor
You will need an E-14 torx female socket for the seat rail bolts as well as the standard torx T-series male sockets.
It will be much easier if you have someone to help you since the seat is somewhat heavy and bulky.
The plastic covers on the sides of the seat are probably brittle by now so be careful not to crack them. Some of the little tabs will probably break off but that shouldn't be too serious.
The door side seat belt cover pulls out toward the door, not up.
The console side plastic trim is easier to remove if the seat belt socket is removed first.
When removing the seat cover from the channels, start with the back. There is a little clip in the middle that a long thin screwdriver slipped in the channel will help to remove. The sides of the leather in the channnels aren't too difficult to remove but there is another clip in the middle of the front of the seat where the screwdriver will help.
I didn't remove the cover from the pad. I just cut the wires about 1 1/2 inches from the pad and from the plug. I soldered in new wires to make the assembly the same length, taped the joints, and covered the entire assembled wires with a spiral plastic wrap. I didn't wire-tye the assembly to the metal seat bottom since that seemed to be what caused the issue.
Je5
Thanks for the information guys, you guys saved me a ton of $$$$$$ :-)
EDIT: looking at my previous posts, just realized I have been driving with the SRS light on for over 3 years!
http://www.benzworld.org/forums/w210...placement.html
You must join benzworld to see the pics but it is free. Also, you will need either the external torx or a multifunction socket to remove the e-torx bolts that hold the seat rails to the floor.
You can remove the sensor and check it for wire continuity from plug close to the sensor.
2 buck for perfect tool for the job
and no, you don't need DAS for it.
They will replace the sensor.
I think your options are dealer, or upholstery shop.
Years ago I used http://tonysupholsteryandcanvas.com/ for upholstery and they did do good job without breaking the bank.
In case you go there - tell them Polish friend of Mirek send you.
