e320 4 matic...i wanna lower my ride
Old Oct 5, 2009 | 12:00 AM
stunna202's Avatar
02 c240
from wut i read is it true that i need special lowering springs for my 98 4 matic?
all info u can pass on to me will be a big help thanks guys!
Old Oct 5, 2009 | 01:34 AM
Rat's Avatar
Rat
1997 E420
why people want to do that? you really want something on the road hit your car and create huge damage?
Old Oct 5, 2009 | 09:18 AM
raymond g-'s Avatar
99 E320
come now, there are degrees of lowering. s/he didn't say 'slammed'.
to the OP, check for posts by "ghaffer"
Old Oct 6, 2009 | 04:38 PM
stunna202's Avatar
02 c240
ya i didnt say slammed!
i just wanna lower a lil bit so when i put 18's or 19's it doesnt look like a 4x4
Old Oct 7, 2009 | 07:53 PM
ohlord's Avatar
You don't
want 19's they ruin the ride.
Remove the springs,cold cut saw 1 1/2 coil from each spring measured properly and reinstall.Get camber eccentrics and rear links and a good align and call it good.
Old Oct 10, 2009 | 07:20 PM
illest's Avatar
w210 AMG or S213
about how much of a drop will you get from cutting 1.5 coils?
Old Oct 10, 2009 | 09:49 PM
kyosuke's Avatar
1999 e320 ,2006 AMG S55
this is a benz,even 240sx guys dont dare cut their springs because it ruins the suspension over time to a degree where theres no turning back and you wont be able to have an alignment done ever again.
Old Oct 10, 2009 | 10:46 PM
ohlord's Avatar
Another myth
We have be racing MB with cut springs for years. Even the factory guys still do it. All you change is the spring rate about 10% and if done with a cold saw and not heat you won't fatigue the spring a bit.
Aftermarket springs often exhibit far more than 10%
You can still get it aligned.
Dealer sponsored track cars do it all the time.
Mb shop foremen do it to their track/road cars
4matics have very few options available in lowering kits if you can find them at all. So a good proper cut does the trick. Old springs cut right don't change rate after the cut and -1.5 neg camber is not hard to correct.
Old Oct 11, 2009 | 02:17 AM
raymond g-'s Avatar
99 E320
i'm taking a stab here....
since ohlord has, in the past, suggested 1.5 coil trim, he is/was referring
to RWD. for the 4matic, the coil will need to be cut specific to the coil-
over design and thus, different than RWD.
Old Oct 12, 2009 | 03:49 PM
stunna202's Avatar
02 c240
was reading everyones comments here and i dont know what to do now....cutting the springs sounds like a plan but u gotta cut it to the specific coil design seems very tricky!
i was wondering if i can just put amg springs on my 4 matic ??wud it work?
Old Oct 12, 2009 | 04:20 PM
raymond g-'s Avatar
99 E320
don't think you can drop in E55 springs. pretty sure the E55 design is based
on seperate shock v springs, whereas 4matic has coil-over configuration
Old Oct 12, 2009 | 04:42 PM
ohlord's Avatar
No
they are different springs.Made to fit the shocks which have a U shape on the bottom that the axle goes through on the 4matic.
http://www.detali.ru/cat/oem_mb2.asp...SGR=052&SGN=01
bottom diagram.The front axle goes through the inverted U at the bottom of the shock.
look at the 4matic spring the ends are tangential front and rear.Meaning you can chop them
So spend the time and if you go a bit at a time start at 1 coil and go more later.
You will be spending additional money on camber units so budget them in also.
Maybe I should start building custom springs and shorter travel shocks with proper brackets.Titanium coils sounds like a winner $$$$
