would these wheels fit???
<table width="100%" cellpadding="0" cellspacing="0"><tbody><tr><th id="v4-43" class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" align="left" nowrap="nowrap">Rim Width: </th><td headers="v4-43" class="vi-ia-attrColPadding" width="50.0%">Front: 7.5 / Rear: 8.5</td></tr><tr><th id="v4-44" class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" align="left" nowrap="nowrap">Number of Bolts: </th><td headers="v4-44" class="vi-ia-attrColPadding" width="50.0%">5</td><th id="v4-45" class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" align="left" nowrap="nowrap">Offset: </th><td headers="v4-45" class="vi-ia-attrColPadding" width="50.0%">Front: 37mm / Rear: 30mm</td></tr><tr><th id="v4-46" class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" align="left" nowrap="nowrap">Bolt Pattern: </th><td headers="v4-46" class="vi-ia-attrColPadding" width="50.0%">5x112</td><th id="v4-47" class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" align="left" nowrap="nowrap">Rim Diameter: </th><td headers="v4-47" class="vi-ia-attrColPadding" width="50.0%">17</td></tr></tbody></table>
there going on a 1998 e320 4matic at stock height. would these fit ?would they rub ?
Not sure the maximum that will work but 225/45R17 and 235/45R17 are fine. It you have 16" rims now be prepared for a harsher ride on 17's if that matters.
for proper sizing on MB, you need the following specs answered:
- wheel width
- wheel diameter
- ball seat measure
- lug bolt diameter/length
- ET / offset
- tire size currently using
- tire size proposed on new rims
- hubcentric bore match
dont forget to run your specs through this tire calc engine
also, because you are planning on using these rims/tires on 4matic, the go/no-go
specs should be less than 4%, i opine.
<TABLE cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TH id=v4-43 class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" noWrap align=left>Rim Width: </TH><TD class=vi-ia-attrColPadding width="50%" headers=v4-43>Front: 7.5 / Rear: 8.5</TD></TR><TR><TH id=v4-44 class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" noWrap align=left>Number of Bolts: </TH><TD class=vi-ia-attrColPadding width="50%" headers=v4-44>5</TD><TH id=v4-45 class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" noWrap align=left>Offset: </TH><TD class=vi-ia-attrColPadding width="50%" headers=v4-45>Front: 37mm / Rear: 30mm</TD></TR><TR><TH id=v4-46 class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" noWrap align=left>Bolt Pattern: </TH><TD class=vi-ia-attrColPadding width="50%" headers=v4-46>5x112</TD><TH id=v4-47 class="vi-ia-hdAl vi-ia-attrLabel vi-ia-attrColPadding" noWrap align=left>Rim Diameter: </TH><TD class=vi-ia-attrColPadding width="50%" headers=v4-47>17</TD></TR></TBODY></TABLE>
But they should fit without rubbing. I had a set of 18's with very simular offsets. You can go as low as 42mm. It also depends on the wheels/brands you buy. Right now on my E320 is 19X9.5 offset 20 on rears and 19X8 offset 20 fronts. I have no rubbing issues.
For hub centric rings is not a big deal. There are mnay wheel dealers out there should have the size for you from whatever wheel to Mercedes hub size.
The offsets with 17's not lowered will fit fine
235/45/17 all around will pose no problems on a 4matic non lowered
except that staggered width might affect squat of the tire profile and kick off your cruise control. That is the big issue with staggered rims on 4 matic.
That and to large a difference in TD which can screw the trans.
So buy quality tires with good close tolerances
unless you cut the springs you won't ever be low enough to interfere with the tires or rims or body or suspension.
On a 4 matic.
Rims from MB should have the part no. engraved somewhere on the backside. You may need to clean them to find it.
There is a special hybrid lug bolt available from places like Rad-USA and Prestige Wheels. It has a 14mm ball seat but a 12mm shank. Also the lug bolt should extend out of the back of the wheel about 17mm. This is just enough to ensure you capture 6 threads but not so much that the bolts extend thru the rear hubs and hit the emergency brake shoes.
