IS ENGINE FLUSH PRIOR TO OIL CHANGE A SMART THING TO DO?
Old Jun 9, 2017 | 11:52 PM
gary87xj6's Avatar
2001 E320; 2006 Mini Cooper S; 2004 V8 4Runner
2001 E320 APPROX 110k MILES OIL CHANGED REGULARLY ANNUALLY AT 5K MILES..GETTING READY TO DO IT AGAIN AND THOUGHT RUNNING AN OIL FLUSH PRIOR TO CHANGE MAY BE A GOOD IDEA BUT WANTED OTHER MB OWNERS THOUGHTS.
Old Jun 10, 2017 | 12:11 AM
Audi Junkie's Avatar
E Coupe C207, ML W166, ML W164, Sprinter 1500/144, W111 SB220 Fintail(s), A5 chassis Beetle 5+5
A quart of Marvel Mystery Oil for 500 miles will clean the engine up a bit. You can use kero or diesel or best of all biodiesel for 10 minutes at idle then drain it out.
BG flush is an option if desired. No other solvent flush is worth more than a few bucks, may as well use kero.
Old Jun 10, 2017 | 12:15 AM
Diesel engine oil, like Rotella or Delo can also clean the engine. A quart or two of Redline with it's ester base will help clean if used in the oil for a full change.
I did a lot of FI cleaner, and MMO in the gas, a q of MMO in the oil. Going to add a q of kero at idle for 10 min and drain, then use Rotella for a couple of 6 month oil changes before I go to 1 year on synth. I just got a 2006 500 with 60k, not well serviced.
Old Jun 10, 2017 | 05:35 PM
nelbur's Avatar
1997 E300D
I would not do it on my car. The problem is that one never gets all the oil out when it is drained. Even if you get the engine angle so that the pan empties, you still have oil in a cooler and all the oil galleries, which means that some of the flush stays in the engine. I would rather start off with 100% oil.
Old Jun 10, 2017 | 09:20 PM
It's not uncommon for oil to accrue quantities of excess fuel if driven short trips or idles a lot. Light compounds like fuel or flush simply evaporate away.
Kerosene is technically an oil anyway.
Old Jun 11, 2017 | 04:42 AM
fabbrisd1's Avatar
A gaggle of MB's
If you have been changing oil at 5K-miles/"annually" - on the oil side you don't need to do anything different.
At your age/mileage - you should focus on other items for your consideration:
1. Drain/replace coolant - after draining pull thermostat to check for signs of any electrolysis G05 or MB coolant - if diluting concentrate use distilled water only
2. Time for fresh plugs - OE type only - due to time and mileage -
3. Check engine mounts - failed mounts will lead to increased vibration thru exhaust system - in turn which accelerates front cat breakdown - especially on choice/low mileage W210's like yours
4. Begin considering fresh/new MAF/genuine-Bosch-reputable-source only. Brings back original spec
Old Jun 11, 2017 | 02:01 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
I was taking apart 603 diesel engine who run 293,000 miles on dino oils.
Don't know what intervals PO used, but there was no sludge at all. Beside common on diesel gunk in the intake the engine had perfect interiors.
When you do 5000 intervals, you are treating your engine to overdose of detergents and anti-acids.
Old Jun 11, 2017 | 02:28 PM
gary87xj6's Avatar
Thanks everyone, I went with a standard oil/filter since the prior owners (I have all records on this gem) performed maintenance regularly with quality products. I have MB coolant, a couple of hoses, and plugs, not sure about thermostat (maybe time for another FCP Euro order). I'm good at accumulating PM parts, it's finding the time to actually do the work. I had the tranny fluid changed at 95K, and I did the rear diff oil around that time, also replaced the shocks last year with new Bilsteins. It's the wife's car but it sure is a great driving car, ride, performance, mileage and built like a tank.
Old Jun 11, 2017 | 02:39 PM
gary87xj6's Avatar
Oh, failed to mention at idle, warm, I do notice a slight tapping, clicking noise.....probably time to see Messer Motorn Werke my local MB/Mini specialist. Always good to let the experts see the car every 12 - 18 months.
