- Mercedes-Benz E-Class: Why is My Car Hesitating?
Step by step instructions for do-it-yourself repairs
car hesitates badly when accelerating from stop + A/C fan has annoying delay
1. sometimes the car hesitates badly when you start accelerating from a stop.
2. when you turn the A/C fan to a higher speed, it takes from about 10 seconds to sometimes up to a minute or two before air starts coming out.
car is 03 e320 btw.
The second issue, is a again a warranty issue.. is it happening in auto or manual mode where there is a delay? Could be a temp sensor.
just wondering if anyone else has had these problems
Regarding the A/C: my a/c fan only blows at half speed, after 2 min. of start up and, simultaniously, the center vents stop working completely. The defroster takes over and my windows completely fog for about 15 min. Not to mention, the incredibly long amount of time it takes to cool off the cabin. Incidently, does anyone know if air should be comming from the ducts under the front seats, (leading to the rear)?
car is 03 e320 btw.
T
T
agreed...got some minor problems u learn to live with...
i experience a long delay going from drive to reverse
As to whether these latest changes will have finally fixed the issue remains to be seen, but, I am not yet willing to let MB off the hook and accept this as something I have to live with.
P-07_00-28F FEB 04 Engine Controls - Lack of Power/Hesitation/MIL ON
The problem is a CEU upgrade and this is the number of the Technical service bulletin.
Besides a transmission or software issue as a possible cause, maybe there is a problem with a spark plug(s) or wire(s). Test out a similar car to see if it feels the same. Try to see if there is anything you can do to easily replicate the problem. Good luck.
William
2003 E 320
I will say that my long standing problem of hesitation on accleration has apparently been fixed (no reoccurence in the last 2.5 months). During my last visit to the service department they figured out how to replicate the problem on demand and started to systematically replace components until the problem disappeared. The root cause was diagnosed as the fuel injector valves, which were replaced, but before that they changed out the throttle valve actuator, mass air flow sensor, accelerator pedal assembly, and tested all spark plug connector ends. Along with the fuel injector valves being replaced they also replaced a crankshaft sensor.
My advise to folks who have had similar problems is to keep going back to the service department until the issue is finally fixed.
William
2003 E320
It is good to be firm and persistent - but resist the temptation to lash out. Venting may make you feel better in the short term, but its not very constructive if you want to build a long term relationship. In my area I have only two dealerships to choose from and they are both owned by same company - so it is not an easy proposition to simply take my business elsewhere if I am dissatisfied.
As time went on, the "learning" done by "drive by wire" started to catch up to me and I started to get annoyed by the acceleration. After reading an item on this forum, I did the drive-by-wire "reset" and the car started driving excellent again.
If you haven't tried changing service departments, I'd try that first. Once they find the problem and fix it, after you have driven it for a while, try the "reset" and see if it gets even better.
Good luck, I know the feeling!
Date: February 2, 2004
Order No.: P-B-07.00/28f
Supersedes: P-B-07.00/28e dated Dec. 18, 2003
Group: 07
Revision: Warranty Information Updated
SUBJECT:
Model 220/215, Model Year 2003 Model 203, Model Year 2002 and later Model 210, Model Year 2002 Model 211, Model Year 2003 Model 209, Model Year 2003 Model 230 as of Chassis No. F029500
Model 170 (SLK32O only), Model Year 2002 and later
Engine Control Unit Software Update
The Flashware CD release 0004488102/0005 (refer to S-B-07.61/30) or any newer version contains a software update for the engine control unit for the following conditions. Please use only the latest flash CD for flashing.
Note
o not flash Model 230 (SL5OO) with chassis number lower than F029500. ME software with part no. 113 153 34 79 will not communicate with transmission control unit resulting in a no start condition.Note : Emissions are not exceeded under normal conditions.
All M112/M113 Engines - Model 220/215 MY 2003 and later remaining models MY 2002 and later:
^ Lack of power under full acceleration and mid range and/or upper long-term adaption values drifting to lean.
^ Hesitation caused by "two-footed" driver, i.e. driver depresses accelerator and brake pedal at the same time as outlined in DTB # 302 dated May 29, 2001.
After flashing the ECU will have part number as follows:
^ All models with M113 = 113 153 44 79 with the following exceptions:- S500/430 4-Matic = 113 153 46 79
^ All models with M112 = 112 153 51 79 with the following exceptions:- C320MY2003 = 112 153 59 79
- C-Class 4-Matic, MY 2003 = 112 153 44 79
Model E320/500 and CLK320/500 - MY 2003:
^ Check engine light with code P0442.
^ E/CLK500 = 113 153 44 79
^ E/CLK320 = 112 153 51 79
Note :
^ Ensure that all engine related systems are within specification. The software update will not compensate for any system or mechanical component malfunction.
^ When asking for SCN number (MY 2003 vehicles only), the PN that will be in the ECU after flashing must be specified.
Please refer to S-B-07.61/27 for instructions on flashware use.
