E-Class (W211) 2003-2009
Old 06-09-2015, 04:19 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: General Overview
Print Wikipost
W211 Recalls!
Rating: Thread Rating: 7 votes, 4.86 average.
Old 02-21-2020, 10:00 PM
  #376
Pitek's Avatar
06 MB E350 4Matic Sedan, 08 MB S550 4Matic Sedan
No recall in Canada
I checked with the local MB stealership here in Ontario, Canada.
No recall - as usual.
Thanks,
Pitek
Old 02-26-2020, 05:19 PM
  #377
Pitek's Avatar
Follow-up
Thanks,
Pitek
I received the safety recall letter from the MB today in the mail.
They admitted to the long-existing problem in... Canada.
They wrote: “We are working to obtain replacement parts to remedy this issue as soon as possible. Once we have the required parts, we will contact you again.
I am waiting for the next letter from the MB to schedule this free repair.
Thanks,
Pitek
Old 04-16-2020, 03:44 PM
  #378
Shack1's Avatar
06 E350
Thanks,
Pitek
The least of most peoples problems right now, I wonder how many have a had issues, they should have dont this for the balance shaft issue that affected nearly every 2006
Old 04-16-2020, 04:09 PM
  #379
Pitek's Avatar
Angry Balance shaft issue
Exactly. I am still waiting for any positive solution to the still existing and affecting so many 2006 owners - "balance shaft issue."
Old 06-26-2020, 08:45 AM
  #380
Lee Herd's Avatar
e350
Fuel tank
I have a 2007 E 350 that has a small fuel leak and is stalling. My mechanic told me that the fuel pump is bad and the whole tank has to be replaced for a cost of $3000.I have read the recall notice about this, however I never received a letter about it as I am the second owner.
Should it matter that I am the second owner, shouldn’t I still be able to get the repairs done under the recall?
Old 06-26-2020, 09:34 AM
  #381
Mackhack's Avatar
Its a 15 year/unlimited mileage extended warranty. No matter how many owners, letter received or not, go to MB and get it fixed before your 15 years are over. If you go to your Indy shop make sure you get a detailed invoice. You can take that invoice to any MB dealership and they will put it in the system. Two weeks later you’ll receive a check over the reimbursement amount. That’s how we did it the first time. The seconds time we went straight to the dealership so we would have to pay it first and wait for the check.
Old 06-26-2020, 09:39 AM
  #382
Lee Herd's Avatar
e350
I just called mbusa and gave them my vin, they told me it is not a vehicle covered by the recall, they told me it is a California vehicle if that makes a difference
Old 06-26-2020, 09:43 AM
  #383
Mackhack's Avatar
Doesn’t matter. It’s a US not a California extended warranty. Just do what I suggested.
Old 06-26-2020, 11:49 AM
  #384
konigstiger's Avatar
Received 4,435 Likes on 3,152 Posts
'71 Pinto
VIN? If independent is recommending whole tank replacement and MB mentions it is a CA vehicle may be PZEV covered by 15 year / 150,000 mile Emissions warranty.
Old 07-01-2020, 09:33 AM
  #385
SmokinJoe's Avatar
2021 E-350 Loaded
FYI: Sliding Roof Bonding.
Spoke to MB today, blame COVID for parts delay.
Was told parts should be available and recall letters sent out by end of July.
Old 07-01-2020, 10:30 AM
  #386
Mackhack's Avatar
Letters were sent out months ago. First owners went to MB already.
I know if at least two owners who which they wouldn’t have gone. Techs pulled on the glass too hard/wrong procedure and shattered a perfectly fine sun roof.
I know for a fact, neither of my 211’s sun roofs fell off in 15 years and I won’t let anyone test the bonding. If it didn’t come off in 15 years it won’t come off in the next 20 years either.
Old 07-21-2020, 02:39 PM
  #387
'71 Pinto
Recall Campaign 2020040011 6/20 – 2001-2011 203, 209, 211, 219 adhesion of the bonding between the glass panel and the sliding roof frame could deteriorate leading to a separation of the glass panel from the vehicle, dealer will replace the sliding roof. Approximately 641,843 vehicles affected.
Phase-2 released 7/20 sliding roof is replaced base on production date.
Old 08-03-2020, 02:18 AM
  #388
ctravis595's Avatar
2002 CL500 to CL55 conversion
Be careful. Last week I saw a w211 with the recall and the sliding roof was very significantly separating
Old 08-03-2020, 02:32 AM
  #389
Mackhack's Avatar
I have a roll of painter tape in the trunk just in case. Thanks for the heads up, I hope they are ok though and nobody got seriously hurt. Appreciate it.
Old 08-22-2020, 10:54 PM
  #390
Kris079's Avatar
2020 GLE300d (current); 2003 E500 (current); 2017 GLC250 Coupe; 2015 CLA45; 2010 ML63; 2008 ML320CDI
The sunroof recall is official in Australia, link below with affected VIN Numbers.
https://www.productsafety.gov.au/rec...rs-my2000-2010
Local dealer checked my 2003 E500, it was on the affected VIN List, but serial number of the sunroof confirmed no work was needed.
Said they had seen one other one come in so far also not needing any additional work, took them about 20 minutes to get a clear reading of my serial number though, it was apparently in a spot that made it quite hard to locate and read clearly.
notthew211 (04-24-2021)
Old 10-19-2020, 06:25 PM
  #391
Slider's Avatar
04 E55 AMG
Took mine in last week.
The sunroof didn't need repair, but I got a free car wash out of it.
Old 10-26-2020, 05:14 PM
  #392
'71 Pinto
LI35.30-P-058566 SEPT20 – 171,172,203,204,205,207,209,211,212,213,215,216,21 7,218,219,220,221,222,223,230,231,238,253,257, 164,166,167,292,293 single throttle lift-off clunking noise from the side shaft when moving off (audible at the outboard end) noise is heard once in each instance when changing direction of travel. If the complaint is eliminated by experimentally loosening the outboard collar nut (by 1 turn), the problem is due to cracking of the microweld between the wheel bearing inner race and the joint housing of the side shaft. The collar nut must always be replaced after being loosened. Coat contact surface of side shaft with wheel bearing with Molykote paint (MB part # 0009890152).
LI33.30-P-056665 SEPT20 – All Mercedes-Benz cars with front-wheel drive and 4x4 vehicles single throttle lift-off clunking noise from the side shaft when moving off (audible at the outboard end). The clunk is heard once when changing from forward to reverse (and vice versa). If the complaint is eliminated by experimentally loosening the outboard collar nut (by 1 turn), the problem is due to micromovement in the connection between the wheel bearing inner race and the joint housing of the side shaft. The collar nut must always be replaced after being loosened and must be tightened to the specified torque. Coat contact surface of side shaft with wheel bearing with Molykote paint (MB part # 0009890152).
LI27.50-P-049281 SEPT20 – 722.9 transmission when changing gear range from P to D, harsh engagement may be noticeable, engagement sequences for N-D and N-R must be taught in again as follows (always remain in the gear ranges N/R/D for at least 5 sec): start the engine from cold, shift 5 times N-R, shift 5 times N-D -> warm up transmission to 40°C and while doing so, exceed a speed of 30 mph at least once. Shift 5 times N-R, shift 5 times N-D -> warm up transmission to 70°C and while doing so, exceed a speed of 30 mph at least once. Shift 5 times N-R, shift 5 times N-D.
File Type: mp3
Old 11-27-2020, 09:16 AM
  #393
mildenbenz's Avatar
2013 C250
My non-PZEV 2008 E350 got its new tank and fuel pump assembly under warranty on Tuesday. No more fuel smell so far.
Old 03-25-2021, 05:55 PM
  #394
'71 Pinto
As part of the settlement with the U.S. authorities, Daimler will offer an emission modification program to owners and lessees of eligible model year (MY) 2009 through 2016 Mercedes-Benz BlueTEC II diesel passenger cars and MY 2010 through 2016 Mercedes-Benz and Freightliner BlueTEC II diesel Sprinter vans registered in the United States. US customers can call the MBUSA Customer Assistance Center at 1-800-FOR-MERC for any questions related to passenger cars and at 1-877-762-8267 for questions related to Mercedes-Benz or Freightliner Sprinter.
2009-2016 OM642 & OM651 Diesel Vehicles Extended Modification Warranty for each vehicle that has received the Approved Emission Modification. The EMW period is the greater of: 10 years/120,000 miles from the date of initial sale whichever occurs first; or 4 years/48,000 miles from the date of installation of the Approved Emission Modification whichever occurs first. If an owner already paid to a have a repair performed related to any of the covered components prior to the effective date of EMW those repairs are not eligible for reimbursement.
Old 08-03-2021, 05:56 PM
  #395
MEE87's Avatar
E500 w211 2005 Mercedes-Benz
W211 2005 airmatic suspension
Originally Posted by rcollins2867
I really wish that benz would do a major recall on the airmatic suspension, there are so many folks on this forum alone as well as the second benz forum that end up spending major bucks on the suspensions of these newer mercedes cars, my car is a 2003 with only 63k miles, and i had a front air spring go out, my car has been sitting for the last 3 weeks as i get the "Car to low to drive" error on the dashboard, my car is now out of warranty and the estimated repair is $1400.00, I have been waiting to scrape up the money for that front airspring, now the whole damn car is sitting dumped to the ground, talk about frustration....Benz just aint what they used to be, i would have never expected such problems from a newer car with low miles to have such costly repairs...a huge disappointment i tell you....So any suggestions and or help would be greatly appreciated.....
Was this addressed as I have the same problem too currently and its not good at a high cost. I live in New Zealand
Old 08-03-2021, 06:08 PM
  #396
MEE87's Avatar
W211 2005 e500 recalls
I live in New Zealand do you know if there is a site using my vin number to check the recalls here I tried the site in this thread but it dosent work maybe as its usa im assuming..I'm having trouble with my airmatic suspension and ive just got the car 2nd hand and id like to check if any recall on it and maybe other bits I know the brake system was completed via recall but if possible to check myself instead of Hassel Mercedes-Benz in nz checking myself will also knowledge me more on my new car that already needs fixing and sitting parked as stop too low warning on the dash and front drivers side is slightly lower than the rest of the car so sad!
Old 08-03-2021, 06:49 PM
  #397
Mackhack's Avatar
I can help people in SoCal. OEM parts and install. And it’s actually cheaper today than it used to be.
Not that MB isn’t an expensive place but the AIRmatic isn’t too bad and with the SBC extended warranty it’s a big relief.
Old 12-19-2021, 08:43 PM
  #398
E55 AMG Noob's Avatar
2006 w211 e55 AMG
You are amazing! So what do I do with my new (to me) 06 e55 AMG? Do I roll-up to my dealer and exclaim “there is a new Sheriff in town! Check my card for all recalls NOW”?
Old 12-20-2021, 09:39 AM
  #399
'71 Pinto
Request dealer pull Vehicle Master Inquiry (VMI) this is a record of all work performed to your vehicle by any/all MB dealers and confirm there are no outstanding recall and service campaigns. Dealer discretion if they want to supply printout.
Old 02-02-2022, 10:21 AM
  #400
mrbill3's Avatar
07 E320 Blue tec
Do you know what the check/test procedure B is?
Did they take it apart? They did not replace it.
You have already rated this thread Rating: Thread Rating: 7 votes, 4.86 average.
Quick Reply: W211 Recalls!
