E-Class (W211) 2003-2009
Oil Change
Old Nov 10, 2007 | 03:49 PM
ey2001's Avatar
e350
Oil Change
hello, im trying to do my oil change but i cant find out anywhere how many quarts my e350 takes. i have a 2007. i know i need to use the mobil 1 0w-40. thanks for all your help
Old Nov 10, 2007 | 08:53 PM
sack5000's Avatar
2015 AMG C63 S
It takes 8.5 quarts. If you extract the oil with a vacuum extractor put in 7.5 quarts and check it, then add the remaining oil.
Old Nov 10, 2007 | 10:15 PM
hoezee's Avatar
04 e320
did my 05 e320 today, drained with drain plug, refilled 8.5 mobil 0 40, reset fss
Old Nov 11, 2007 | 02:28 AM
Diesel Benz's Avatar
Where did you search this for? I've had this mentioned in the car manual for every car I've owned or changed engine oil.
Old Nov 11, 2007 | 11:34 AM
sack5000's Avatar
2015 AMG C63 S
Right, it's in the manual but for most it's easy to just ask.
Old Nov 12, 2007 | 12:42 AM
Taiwanese's Avatar
2003 C230
I just recently change my own oil on my 03 C230.
How do I remove "service B in 1,800 miles."
Thanks.
Old Nov 12, 2007 | 02:47 PM
vettdvr's Avatar
03 E500 and Corvette
Instruction should be in the manual. But this should help.
File Type: pdf
Old Nov 17, 2007 | 10:26 PM
gnma's Avatar
'12 Mustang 5.0, '89 Supra Turbo, C55,
Tks. for posting this vettdvr! I've been searching for how to reset the service light". BTW, family said no to the C32, so I'm looking for an E500.
Old Nov 18, 2007 | 09:17 AM
mdreef's Avatar
2020 E450 Coupe, 2022 Porsche Macan, 2001 Porsche 911
Could you all please tell me the reason for needing an oil extractor to change the oil? Obviously the oil can be changed "the old fashioned way" through the drain plug - but there are many posts about using an extractor instead. What are the advantages?
Also, I am supposed to change my brake fluid soo according to the manual. Have any of you done this? If so, how did you do it? You apparently can't bleed the system without the Star Diagnostics computer..
Thanks!
Old Nov 18, 2007 | 10:19 AM
PaulX608's Avatar
2011 VW cc, 2004 ML350
Lots of advantages:
1) Don't need to lay on the ground, gettin too old for that ****.
2) Don't have to remove big cover under the car.
3) Don't have to worry about damaging the pan or drain bolt creating a leak.
4) No spills.
5) Easier to get rid of used oil.
6) I don't even get my hands dirty.
Disadvantages:
1) Don't get to examine the underside of the engine and find leaks/damage/etc.
Seems like a no-brainer to me.
Old Nov 18, 2007 | 10:46 AM
mdreef's Avatar
All great points, thanks! the main thing I really needed to know was that it's not a requirement to use an extractor. I think I might go with the extractor after all, since it does seem to make life much easier...I'm not too old but I sure am lazy!
Originally Posted by PaulX608
Lots of advantages:
4) No spills.
Disadvantages:
Old Nov 18, 2007 | 10:52 AM
sack5000's Avatar
2015 AMG C63 S
The stealer uses an extractor and charges you for his time saved, ha!
Old Nov 19, 2007 | 11:19 AM
joelaff's Avatar
E550
I was always under the impression that an extractor does not do a very good job of removing the sludge at the bottom of the oil pan. I have heard that it is best to drain from the bottom, where that crud comes out first.
Thoughts? Simple gravity it would seem...
Old Nov 19, 2007 | 11:54 AM
This has been discussed many times and it is obvious that there are owners who don't accept siphoning and owners who don't see a difference between siphoning and draining (except that the other one is faster and cleaner job).
You are entitled for your own opinion but with modern engines and modern oils, there is no sludge to drain. And if there was, a good extractor pumps the oil out with an equal oil flow as if oil was drained, the sludge would come out equally.
Some claim they can drain a significant amount of oil after siphoning. I don't think they have done it properly if that happens (or some cars are different form those I've serviced). In any case all cars at the dealer are siphoned (except a few that don't have a dipstick tube at all, there are some in addition to the many that have the tube without the stick) as sack5000 explained. If it is OK for most cars, why not for yours.
Old Nov 19, 2007 | 12:44 PM
3on8's Avatar
Someone told me from 07 on, fss has to be reset by the dealer. Any truth to this?
Thanks!
Old Nov 19, 2007 | 08:51 PM
pinebaron's Avatar
07 E320 Bluetec
Thanks!
Nope. Can do it yourself.
Old Nov 20, 2007 | 11:52 AM
3on8's Avatar
Thanks, PB!
Old Nov 20, 2007 | 12:35 PM
joelaff's Avatar
E550
Interesting. I am sure it is a lot better than with older engines. But I would always want my oil changed from the bottom. Since all the stuff I really want removed (any minor sludge, and any metal particles) would be at the bottom, as it is more dense than the oil.
But I do not want to hijack this thread. I just found it interesting to hear people using extractors on pricey cars. I have used them on boats (where there is no other option) and lawn mowers, generators, and other small engines.
Old Nov 20, 2007 | 02:25 PM
N2oExpresS2k's Avatar
2000 Honda S2000
Does the oil filter in the 07 e350 take a special tool to change it?
Old Nov 20, 2007 | 02:58 PM
You should have the plastic oil filter housing. It does take a special tool but if you have a strong hand, you may be able to open it (a good grip is sufficient to tighten it). If it is too tight for a hand, an ordinary filter removal tool should be sufficient.
