Strange Ticking noise
Most likely what your hear is a little noise from the valves. Depending on how the car was driven up until now and what maintenance there might be a little wear on either the cams or valve stems. It should not be much but enough for you to sometimes hear it. If you can live with the clicking then don’t worry about it.
This is a very common issue on most Mercedes vehicles. I experienced this on my CLK and my E after about 20,000 miles on each.
You plagiarized this from sgaar. I knew I've read these words before:
https://mbworld.org/forums/showpost....95&postcount=2
By the way, you guys are way too involved here if you actually remembered the response verbatim.
DTB P-B-07.00/21f – If the VIN is less than A224352, the dealer should install modified motor mounts that correct a “piston slap like sound” for the 03 e500. Even if out of warranty, this is a MB mandated modification, as such request a no cost goodwill repair. If the dealer refuses contact MBUSA 800-367-6372.
In addition, if the noise is isolated to the passenger side, sometimes the purge valve may cause a ticking sound and needs replacement.
If you need a copy of the DTB to support your claim, PM your email address.
and yes ive posted in other threads i just want all the diff answers
I think my car start making that noise plus the motor had some excessive shaking when starting if its not too much to ask can I can a copy of the DTB P-B-07.00/21f my vin is within those affected units.
Thank you very much again!
after I read this thread, I'm beginning to notice that ticking noise too. Currently driving, 2005 MB E500 @ 37780 miles and it is still under warranty. What should I do? take it in to the dealer let them take a look at it or what? Please give me some suggestion. Thank you.
