E320 Oil change OK?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
I just picked up my 2008 E320 from an independent garage. My slip lists 5w30 Mobile 1 as the oil used. Is this a problem? I though the correct oil was 0w40 Mobile 1? Can the 5w30 cause problems? Thank you![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Boy, are you ever confused.
A 2008 E320 is a diesel and must use MB spec 229.51 oil.
The ONLY oil you can get that meets this spec--unless you mail-order German-made oils--is Mobil 1 Formula M ESP 5W-40, which is only available at Mercedes dealers or one or two mailorder sources.
Use of any oil other than MB spec 229.51 will cause damage to your particulate filter that will not be covered under warranty. This is use of ANY QUANTITY, BTW, meaning do not add a quart of something else.
Note
Amsoil European Car Formula 5W-40
Anglomoil RoadMaster 500 API SM 10W-40
Aral SuperTronic 229.51 0W-40 LOW SAPS
Aral SuperTronic Diesel 229.51 0W-40 LOW SAPS
Bizol New Generation SAE 5W-30 (added 09 July 2007)
Castrol EDGE Formula RS SAE 0W-40 (added 09 July 2007)
Castrol EDGE Turbodiesel SAE 0W-30 (added 09 July 2007)
Castrol Longtec Turbodiesel 0W-30 (229.51)
ELF Solaris LSX 5W-30
Fuchs TITAN GT1 229.51 SAE 5W-30 (first fill oil in OM 642)
megol Motorenoel New Generation SAE 5W-30
Mobil 1 ESP Formula M 5W-40 (to become available in the USA on 15 May 2006)
Mobil 1 ESP Formula 5W-30 Emission System Protection (Europe, from December 2005)
OMV BIXXOL special C3 SAE 5W-30 (added 09 July 2007)
Pentosynth HC 5W-40 (added December 2007)
Shell Helix Ultra AX 5W-30 Mercedes 229.51
Sunoco Synturo Xenon SAE 5W30 (added 09 July 2007)
Valvoline SynPower MST 5W-30 229.51 (added 01 June 2006)
Valvoline SynPower 5W-40 229.51 (added November 2007)
Valvoline SynPower 20W-50 229.51 (added November 2007)
Some dealers and indie shops carry 5w30ESP make sure that is what they installed,examine the label if need be.You do not want to be on the paying end of a particulate filter if you make a warranty claim at the dealer and it is denied.
![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
