E-Class (W211) 2003-2009
wierd squeak noise from front
Old Oct 23, 2008 | 05:27 PM
CrimeDoesPay's Avatar
2004 e320
i got this wierd squeak noise or short whistle coming from my front right shock when ever i go over a speed bump or any lil pot hole its annoying as hell anybody have any insight hopefully its not my shock
Old Oct 24, 2008 | 08:32 AM
2004 e320
nobody
Old Oct 24, 2008 | 08:48 AM
Diesel Benz's Avatar
I would still guess the lower ball joint. It may be pretty difficult to figure out which joint is bad, it could be one of the others too (the upper one, the stabilizer bar should not squeak as much as it would give a thumb noise.
How many miles does it have?
Old Oct 24, 2008 | 02:07 PM
BenzBee's Avatar
Mine: 2008 E350 4Matic --- His: 2014 E 550 4Matic
Is it only at low speeds? I had a similar problem when I first picked up my car. The dealer told me I had a damaged shock. I know there has been a post on the board about a service bulletin regarding this type of noise. You may want to check that out too, and see if it applies to your car.
Old Oct 24, 2008 | 03:17 PM
Do you both have steel springs? Just checking that your shocks are the same.
Old Oct 24, 2008 | 04:21 PM
cunnincr's Avatar
2001 E320, 2003 E500
I'm having the same problem with my 2003 E500. I'm hoping it is nothing serious as I've already had to replace 1 of the airstruts.
Old Oct 24, 2008 | 04:38 PM
vettdvr's Avatar
03 E500 and Corvette
ball joints
Old Oct 24, 2008 | 10:22 PM
2004 e320
68k could it be a bushing
Old Oct 25, 2008 | 07:31 PM
konigstiger's Avatar
'71 Pinto
Squeaking/thumping the upper ball joint sealing boot on upper control arm may be damaged, if there is any indication of vehicle pulling slightly to one side accompanied by small movement of the steering wheel when braking the lower ball joint may be damaged.
