Audio and BT Blues in a 2007 E-350
I just recently purchased a 2007 E-350 and I love it. However, I was driving a Volvo S80 with an after market system (Kenwood DNX7100) with all the works (Ipod, BT, Video, Amp Sub). So overall its better than the command in the E-350. So I am trying decide the best path. Leave it as is buy Ipod interface or upgrade the whole thing. Help from any of you will be greatly appreciated and any work I do will be posted with pictures.
Question #1 Does the iPod adapter charge the Ipod? I read somewhere that it does only for the older ones. I have model MB754LL (Apple 4th Generation 8GB iPod Nano). If it will not then I may just do the upgrade.
Question #2 If I remove the Command will the street information that displays on the cluster as I am driving stop being displayed? I am not asking about when I am getting navigation directions. Just driving around the cluster shows what street I am on. I like that and just curios if it goes away. I understand that the GPS is actually a seperate unit and was wondering how much of a role the command plays.
Question #3 If I buy a 2009 command (US or Eur) is it plug and play in my 2007 E-350?
Question #4 I have a Blackberry Curve 8330 and the phone book wont synch. I think its a BB issue, anybody else have any luck or the same issue.
I just installed a Panvise mount for my phone. Had to pull the changer to install it. Was very easy to do. If anybody is interested I will post pictures on how to do it. Have not seen allot on the E-350s here so I will be happy to contribute anything I do.
Thanks in advance.
For #2, it is Comand that feeds the info to the cluster, you would not be able to use the Navi processor without a Comand head unit anyway. You would certainly lose this info from the cluster.
For #3 it isn't plug and play, it is doable but in your case actually quite a lot of work (simplest on a car with an Audio 20 CD head unit).
Don't know about the Blackberry stuff.
The iPod issue revolves around the pin-outs on the unit; Apple switched from FireWire based charging, to USB charging. I have a pinout diagram.
Your 4G should charge (Like 95% sure); I have a Gen-1 Touch; same vintage, ad it works correctly. If you need the pinout diagram, I can provide. It's really as simple as moving a few wires on the circuit board/cable.
But, onto the bad news. The MB iPod kit isn't so hot. I actually bought an H/K Drive & Play; still haven't installed it permanently, but it allows for a much better interface. I'm having issues sticking things to my interior..
Drove a friend's W211 with the Benz system, and the interface is really underwhelming. Sound is OK; just don't like the interaction.
The BlackBerry should work fine; I have a Storm/9530, an dit syncs fantastically with the factory MB Bluetooth puck. I believe there are some issues with older Puck models, and some newer phones. Only thing that doesn't/won't work, ever is SMS. Did you tell your BB to "Allow" swapping of the phonebook?
If you need help with the BlackBerry, I may be able to assist, let me know.
-Andy/Oldimpala
A better solution might be to contact www.autoaddiction.com. They sell an iPod integration kit that connects up to the Command, but you lose the 6-CD changer. The cost may turn out to be less than the factory iPod connection kit.
Based on everything I have read on the MB iPod kit, its not worth it. I did find this kit which appears to be better than the MB version. Anybody have experience with it? I can find a $100 cheaper but still not sure if its worth it.
http://www.crutchfield.com/p_581BENZ...ce.html?tp=120
The Dension ICE 500 would be the one I would go with, if not the MB one.
The 2009 head unit would give you about everything you want - it's just a labor intensive installation.
I don't mind the labor to do the install. My concern is researching all the details of what needs to be replaced rewired etc.... Does anybody have that information?
If I replace the command with an after market HU (kenwood), the AGW can not be used because it takes a data feed via fiber and has copper connections to the speakers.
I will have to wire an amp from the HU to the speakers. The HU alone can not drive all the speakers. And unless I can get a schematic of the speakers with power ratings and how they are wired I will have to tear the car apart to get this information
. Anybody have this information?Upgrading to NTG2.5 means replacing hardware but what I dont like is that I will have get the Mercedes service guys to reprogram the car after the installation and i am concerned they wont do it? There are very few in my area. More to come.
