E-Class (W211) 2003-2009
car too low !!
Old Apr 26, 2009 | 03:55 PM
pinto514's Avatar
2003 w211
car too low !!
hey guys, need a lil help around here.... this morning i went 4 a drive and my car display screen showed this message( stop, car too low ! ). i stoped in a near by gas station to look underneet the car, thats when i realized that the driver side of the car was lower then the rest of my car...i dont recall on hitin a pot hole or anything that would blow my shocks ....anybody ever had a similiar problem...and any hints on wut the problem might be and cost ....would be apriciated ...thanks ...
W211 2003
Old Apr 26, 2009 | 09:10 PM
tashakes's Avatar
2020 GLE350
Most probably a bad Airmatic shock, common on older W211s, search is your friend.
OEM dealer $1000+ or,
OEM online $750
http://www.parts.com/
refurbished $399
https://mbworld.org/forums/e-class-w...available.html
Easy to install, or pay dealer/independent/mechanic $500 or so.
Old Apr 27, 2009 | 08:41 AM
vettdvr's Avatar
03 E500 and Corvette
OEM online $750
refurbished $399
Could be the air spring. They gave the same indiacation in my E500.
Only factory parts available for the replacement air spring. Basically it is an a rubber sack (airmount air bag type). for a spring. A tiny crack will form in the fold and cause it to leak.
Old Apr 27, 2009 | 11:33 AM
pinto514's Avatar
2003 w211
okok ..thanks ill take a look at the parts on line...
Old Apr 27, 2009 | 11:53 AM
erifly's Avatar
Can you let me know what issue and what you did to resolve it after you get it fixed. Thxs.
Old Apr 27, 2009 | 11:56 PM
tashakes's Avatar
2020 GLE350
Vett: are you saying there is a bladder replacement for front shocks? I have not seen that part available, if there is one, do you have a part #? Was your problem resolved by a shock component replacement as opposed to a complete shock assembly?
Old Apr 28, 2009 | 12:35 AM
jagass's Avatar
pick up
Do you have pics?...
Old Apr 28, 2009 | 08:50 AM
vettdvr's Avatar
I was referring to the rear suspension. There is an air spring on the rear that fails and will give you a too low warning. Sorry if I missed yours was front.
Old Apr 28, 2009 | 10:40 AM
pinto514's Avatar
2003 w211
no, i have to get the complete shock assembly but still, its way cheaper and supose 2 be good quality with a warranty. So imma try that out, juss waitin for a call from the factory to see how long it will take for it to arrived in Cananda ....ill let u know as soon as i get it ..
