E-Class (W211) 2003-2009
Sirius satellite Radio "No SAT"
Old Dec 13, 2009 | 08:37 PM
m103-w124's Avatar
2007 E350 P1 Sport Pkg, 1993 BMW 325is, 2000 Tacoma PreRunner V6, 2008 Porsche Cayman S
I just replaced my beloved w124 with a 2007 E350. Sirius radio activation is giving me a little bit of hassle...called up Sirius six times but no luck with the ESN number and bunch of triggering signals , car park in an open field. Although I notice there is a message "No Sat" on the speedometer display. Do I have to reset the media unit or what?
My navigation works perfect.
Old Dec 13, 2009 | 09:38 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Not certain but wasn't Sat radio an option in 07?? If so maybe your car does not have it. I would check with a dealer and perhaps he can assist you in resolving this issue. I do know that on my 06 ML500 I had a SAT button on the command but did not have the Sat option.
Old Dec 13, 2009 | 10:24 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Please reread OP's post. If he has an ESN number he has the necessary unit.
Old Dec 14, 2009 | 10:58 AM
konigstiger's Avatar
'71 Pinto
Starting point would be to check the SDARS connections behind right side trunk panel.
Old Dec 14, 2009 | 06:16 PM
m103-w124's Avatar
Starting point would be to check the SDARS connections behind right side trunk panel especially splitter.
I can see a big hump behind the right tail assy..how do I gain access to it without tearing up anything
Old Dec 14, 2009 | 06:25 PM
MBtech1098's Avatar
10 speed bicycle
07's do not use a splitter...unless someone installed the old style antenna. Also if it says "NO SAT" and not "Acquiring Signal" the AGW is not seeing the SDAR.
Old Dec 14, 2009 | 07:04 PM
m103-w124's Avatar
I know CIA and FBI but what the heck is AGR or SDAR. I am a rookie as far as this car is concerned. Is there something I can somehow reset using the multi display unit? Or shall I just punt the ball and let the Mercedes Benz of Escondido deal with it since it's covered by warranty?
Take care.
Old Dec 14, 2009 | 07:19 PM
MBtech1098's Avatar
10 speed bicycle
Haha, SDAR-sat radio unit, AGW-audio gateway...didn't mean to screw you up. Of course, if you got warranty take advantage of it!
Old Dec 14, 2009 | 08:18 PM
Barry45RPM's Avatar
2015 ML 350
Take care.
SDAR = Satellite Digital Audio Receiver
Old Dec 18, 2009 | 10:43 PM
m103-w124's Avatar
MBZ of Escondido (CA) replaced a defective satellite "control module"....I'm a happy camper.
