E-Class (W211) 2003-2009
COMAND HEAD UNIT software update to enable MP3
Old Nov 1, 2012 | 12:38 PM
  #126
vanboy's Avatar
E55 2004
first batch of US Comand?
My HW state: 37/02, (211 827 25 42 Comand Avantgarde / Elegance/ bis 06/2004)
Omega version:
0.09.1596 XSYS_SW_VE
R0.30e
DVD DRive
FJ-TEN DVD-ROM DV-01
Its ready for DVD video?
Old Nov 1, 2012 | 12:54 PM
  #127
Mackhack's Avatar
They built the same models for US and rest of world models (ECE) at first. Then they switched course bc MB demanded it and also to save cost.
You got a good DVD drive (and I believe it is the one that even reads dual layer DVDs, FJ-TEN).. On the other hand, the Omega chip is indeed the DVD playback processor.
In that case you might be able to actually play back DVD movies.
Old Nov 1, 2012 | 02:23 PM
  #128
vanboy's Avatar
E55 2004
Do You mean, to try change the basic setting in the comand, with SDS dev.mode?
(US vs ECE)
Any idea what menu?
How to enter engeneering menu and setup?
Old Nov 1, 2012 | 02:50 PM
  #129
Mackhack's Avatar
I know how to enter EM again but DR.DIST codes are a well kept secret. Developer mode won't help either because COMAND is coded as US not ECE. But even that is possible to change, without Dev. mode.
Old Nov 1, 2012 | 04:16 PM
  #130
vanboy's Avatar
E55 2004
Noted.
Do you have solution for the change the hardwere settings
To play video?
Could you make to me? I wait your offer!
My PM : lukilaci.hu@gmail.com
Old Nov 1, 2012 | 04:33 PM
  #131
Mackhack's Avatar
No time right now, sorry!
Old Nov 1, 2012 | 04:52 PM
  #132
vanboy's Avatar
E55 2004
Of course,
I understand,
As i have a twins, i hav'nt time for car.
I asked you becouse you have a lot of reply in this topic, and in other too
"Guys,
I have the solution to all of your Video in Motion problem. If you wanna know more PM me and I give you all the details."...
Could you refer some guy, who help me to change hw settings, and see video in car?
Thx
Old Nov 1, 2012 | 05:25 PM
  #133
Mackhack's Avatar
If you wanna talk in German to me pm me as this is a English speaking forum. I'm sure all non German speakers will appreciate it.
Old Nov 1, 2012 | 08:18 PM
  #134
Mackhack's Avatar
Swap your US COMAND with a ECE COMAND and you're good to go dude!
Old Nov 2, 2012 | 01:53 PM
  #135
samo1's Avatar
Mercedes Benz E320 W211 2004
Originally Posted by vanboy
Noted.
To play video?
Basically it's not possible to play DVD MOVIES on US comand, because it hasn't DVD Decoder.
Old Nov 2, 2012 | 02:09 PM
  #136
Mackhack's Avatar
Change hardware setting? That would require to solder! Don't think so.
Buy an ECE COMAND as I told you now several times here as well as in PMs!!!!!!!!!!
Old Nov 3, 2012 | 03:42 PM
  #137
samo1's Avatar
For those, who have updated their comand by this software and can't enter Engineering Menu.
Originally Posted by samo1
Try this:
1. SERV>Lang
2. Hold buttons: END>Arrow (it is located between LEFT and UP buttons)>AUDIO
Attached Thumbnails COMAND HEAD UNIT software update to enable MP3-untitled.jpg
Old Nov 5, 2012 | 03:14 PM
  #138
Mackhack's Avatar
Try this:
1. SERV>Lang
That doesn't do any good as once you're inside EM you still won't be able to access DR.DIST menu where Video In Motion is located. And I keep saying this...
Old Jan 10, 2013 | 09:54 PM
  #139
funkeyro's Avatar
2007 R350 & 2006 E350 Wagon
I have both a US Command and a European Command. It's a 2006 E350 built in Dec 2005. I don't know the manufactured date of the head unit, but the head unit software has never beed updated (at my request of the dealer. I use the European head unit to be able to play DVD movies and the head unit is enabled for that. If I swap back the US head unit, is there a chance that I can get DVD movies to play on that unit as well?
Also, if I update the software on the US unit, will the Euro unit still be able to play DVD movies?
Old Jan 10, 2013 | 10:00 PM
  #140
Mackhack's Avatar
If you update your US COMAND then this will update your US COMAND and nothing else. You will not be able to play DVD back on your US COMAND because it lacks the hardware (Omega chip to decode and play back DVD). All settings for this are stored on the COMAND head unit not in your AGW. So you can safely swap head units all day long without loosing the ability to watch DVD while driving (or not driving)!
Old Jan 10, 2013 | 10:01 PM
  #141
funkeyro's Avatar
Can you make the Euro Command update cd files available to me? I have a euro Unit that has never been updated.
Old Jan 25, 2013 | 08:17 AM
  #142
Grozdanov's Avatar
Mercedes CLK W209
Originally Posted by MPOW33R
IT WORKED !!! HERE IS HOW
BURN THIS IN 6X OR SLOWER
https://www.dropbox.com/s/mgojhwm43fi84ao/US4006.zip
CAR WAS "ON" ENGINE RUNNING.. (do not touch key until competed)
TURNED HEAD UNIT ON--> (I was in FM radio mode and just turned the volume all the way down)
HOLD DOWN 1,3,8 @ the same time AND
ON THE SCREEN ITS SHOULD SAY - INSERT DISC
I INSERTED DISC AND IT STARTING TO UPGRADE
IT SHOWS 2 VISUAL PROGRESS BARS AND SAYS
FLASH AND REFLASH AND THEN SAID
RESTARTING UNIT IN 3,2,1 AND RADIO SHUT OFF THEN ON
DONE - TOOK ABOUT 6-8 MIN
IT SAVED ALL MY PRESETS BUT RESET MY EQUALIZERS
NOW THE CD DRIVE IN THE HEAD UNIT ITSELF PLAYS
DVDs with MP3 Folders and MP3 Cds.
I FEEL MY MY SUB SOUNDS BETTER, I USE THE LOGIC MODE
FUGGIN AMAZING
*** WILL NOT PLAY MP3 OR DVD FROM CDC ( cd changer)
and I dont care
Hello from Bulgaria,
I downloaded this file, unzip him and write on CD in 8x, because my burner can't slow speed. When I put CD, I get the error: Update Error - Wrong variant. Where is the problem?
Attached Thumbnails COMAND HEAD UNIT software update to enable MP3-wp_000250.jpg
Old Jan 25, 2013 | 12:06 PM
  #143
Mackhack's Avatar
ECE and US firmware. You downloaded the wrong firmware
Old Jan 26, 2013 | 12:24 AM
  #144
kkanuck's Avatar
'06 E320 CDI, '04 Sprinter 316 CDI
I have the update cd as well if someone...
Will MP3's work on Euro Commands?
Old Jan 26, 2013 | 12:37 AM
  #145
Mackhack's Avatar
Yes. Might need a firmware update if it's too old. But this usually doesn't happen since only the very first ones didn't have it. My ECE COMAND even has a dual-layer DVD drive in. Awesome!!!
Old Jan 26, 2013 | 01:42 AM
  #146
Grozdanov's Avatar
Mercedes CLK W209
What is the correct firmware for me?
Old Jan 26, 2013 | 01:45 AM
  #147
Mackhack's Avatar
At least 15/04 netter latest of course 30/06. I even have newer firmware versions on my computer which aren't available officially.
Old Jan 26, 2013 | 02:11 AM
  #148
Grozdanov's Avatar
Mercedes CLK W209
Thank you! Do you know from where can I download this version? And this
Code:
what version is?
Old Jan 26, 2013 | 02:24 AM
  #149
Mackhack's Avatar
No because I have them all already.
Old Jan 26, 2013 | 03:45 AM
  #150
Grozdanov's Avatar
Mercedes CLK W209
I update my firmware with correct version 30/06 and mp3 files again not reading? What combination is for engineering menu in the new firmware version. Now and CD's and DVD's not reading.
What wrong?
