E-Class (W211) 2003-2009
COMAND HEAD UNIT software update to enable MP3
Old Feb 4, 2013 | 07:01 PM
  #151
bmp061490's Avatar
2004 E500
update works great
Old Mar 29, 2013 | 11:57 AM
  #152
Hkokkalis's Avatar
2004 E320
Please email me the link for comand update. I recently purchased my e320 and just installed the navi on it. Thank you all for the great write up!
Old May 19, 2013 | 01:10 PM
  #153
dzonve's Avatar
E320
Thanks to everyone for posting this thread!
I burned the files to the CD as a data CD and tried the procedure couple times but the CD always keeps coming out after a few seconds. I pressed the 138 , it said Insert Update CD and when I put the CD in there in comes out in a few seconds...
Any suggestions?
Thanks again to everyone for helping people save some money with this forum!!!
Old May 21, 2013 | 02:30 PM
  #154
samo1's Avatar
Mercedes Benz E320 W211 2004
Try to burn CD 6x or slower
Old Jul 9, 2013 | 12:25 PM
  #155
ar2002's Avatar
vw
Originally Posted by dewana421
Mercedes COMAND HEAD UNIT Service CD W211 589 14 22 00
This is for 2003-2006 models with command unit.might also work for 2007-2009 yr model
use google
Use this CD to update the COMAND Head Unit to software version 46/06.
Unzip the archive and burn all of the files onto a regular CD-R disc, making sure that your software finalizes the disk when it's done. I use NERO, and on NERO it is listed under the "burn" tab on the verification screen just before the CD starts burning.
Once you have the CD, power up your COMAND unit, briefly hold down 1,3,8 at the same time, and the service screen should come up asking you to insert the CD. Insert the CD and the update will begin automatically. VERY IMPORTANT....DO NOT CHANGE SETTINGS OR TURN IGNITION ON OR OFF DURING THE UPDATE PROCESS.
Once the CD is done updating, it will eject the CD and the COMAND unit will restart itself. That's all there is to it.
My unit is a 2005 version, and I cannot attest to weather this will work in other versions, but I have read that it will work on all COMAND units.
If you do not have the Nav module, then this should still update your audio SW... but only if you have the COMAND Head Unit (the one with the large screen). If you have the smaller unit, I think it's called the Audio 50 (but don't quote me on that), then I don't think this will work for you.
Also, this IS NOT a map disc. This is simply the SW update for the COMAND system itself. This update will add a few features with the Navigation module (i.e., adds the ability to display ETA at the bottom of NAV screen) if you have it installed, but it also updates other audio items as well, like the ability to play MP3 discs.
Old Jul 9, 2013 | 07:35 PM
  #156
typhoon43's Avatar
From: Gainesville, FL: In a garage or in a bar, or a garage with a bar in it.
2005 E55, 2011 Honda Push Mower (21 inch deck bishes)
I have an 05 E55 and I noticed my 6 disc in dash will play MP3 CD-s, butthose same discs won't play in the top slot-load. Any idea if this firmware may help that issue? Would be AWESOME to burn a DVD full of MP3's and salp it in the top slot.
Old Jul 9, 2013 | 07:52 PM
  #157
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Your COMAND single-slot must have a DVD drive, and very few in North America came with DVD drives. Most N.A. COMANDS only have CD drives.
Old Jul 10, 2013 | 12:48 PM
  #158
typhoon43's Avatar
Correct, My NAV DVD is in the trunk, but would this possibly enable the top slot CD player to play MP3 CD's as well?
Old Jul 10, 2013 | 01:01 PM
  #159
Mackhack's Avatar
Yes. Update 30/06 will update firmware to play mp3s in the top CD-drive. 30/06 is a pure COMAND head unit update and has nothing to do with your navigation processor in the trunk or the CD Changer. Navigation processor Inge trunk also cannot be used to play back movies on DVDs. This just to clarify once again as many are mistaken on this. I have a ECE spec COMAND with dual-layer DVD/CD drive and I can use 9.5GB Dual-Layer DVDs full of mp3, I can play back standard definition DVD movies as long as try are burned as a regular DVD with the necessary folder structure and correct files inside. COMAND is unable to play back any encoded or compressed films such as divx, xvid or anything else.
If you want to burn your own music videos (I do this, I'll create a DVD with appropriate software that generates a legit DVD with menus and what not!
Hope I could clarify some stuff here!!!
Old Jul 10, 2013 | 01:04 PM
  #160
murman's Avatar
And for further clarification, for almost all North American COMANDS that have been upgraded to play mp3 files, they will only play mp3 files burned onto a CD disc. Very few NA COMANDS have DVD drives, and even then they aren't able to play DVD video.
Keep in mind that the V in DVD doesn't mean Video. It means Versatile.
Old Jul 10, 2013 | 01:44 PM
  #161
Mackhack's Avatar
Only first batch of US spec COMAND head units had DVD drives in. There was no need to continue and Daimler AG decided to replace DVD drives with cheaper CD drives. Reason: US spec COMAND head units don't have the necessary Omega DVD playback encoder chip on mainboard, hence it was unnecessary to equipt unit with DVD drives. Later on ECE head units got Dual-Layer DVD drives like mine.
Old Aug 4, 2013 | 02:43 AM
  #162
danieldjx's Avatar
03 E500 (Japanese Spec)
Arrow Anyone come across this Command HU?
Hi, Ive been searching across the forum and googled but can't find a definitive answer as to whether there are unlock codes for this model.
Reading through this thread I find you guys seem to know what you are talking about.
I drive a Japanese import E500 (W211) 2003 Avantgarde
Comand system has:
3D Nav maps with Japanese language voice directions
Phone pre-wired for Japanese CdMA phones (I presume)
E-mail and web browsing function using cellular data connection.
Digital TV Tuner
DVD\CD player accessible by sliding the motorized display screen UP
MD player accessible by sliding the motorized display screen DOWN
6 CD changer (single slot)
Does anyone have the unlock codes for this particular variant of the Command? Ive tried several codes listed for USA/Euro without success. I would like to enable MP3 playback on my HU.
My question is if I update my command, with the update CD mentioned in this thread, will my UI change to a fully English interface?
Id appreciate any assistance you can give. Ive attached some pics as well as a copy of the original MB Command manual (in Japanese) for your ref. I can post a video on YouTube if anyone requests.
Im really happy with this car and if I can update this command to your euro or us spec software it'll be a perfect ride. I'm don't quite understand why MB would go out of their way to design a special variant of W211 just for the Japanese market!
Thanks in advance.
Daniel
P.S. if I have posted in the wrong thread pls direct me to the correct one. Thanx.
Old Aug 4, 2013 | 01:20 PM
  #163
Mackhack's Avatar
Daniel,
EM codes are for Harman/Becker COMAND systems. Japanese spec COMAND systems are build by Alpine and therefore won't work. I think I mentioned that just a few posts up.
You cannot use US/ECE spec updates for yours.
If you're in SoCal I can help you with all your needs.
Old Aug 5, 2013 | 01:58 PM
  #164
danieldjx's Avatar
Thumbs up
Originally Posted by Mackhack
Daniel,
I would first like to Thank you for the prompt reply.
I'm sorry but I live half way around the world from you. Wish I was in SoCal though. Do you by any chance have the proper key sequence to enter diagnostics/engineering mode for these Alpine made Commands?
My local Benz service is unable to do anything with this command. So pls help is you have ny info about this.
Thanks in advance.
Daniel.
Old Aug 5, 2013 | 02:36 PM
  #165
Mackhack's Avatar
Daniel, there are no EM codes for Alpine COMAND models. Sorry that I can't help you.
Old Aug 5, 2013 | 08:28 PM
  #166
nawras_20's Avatar
2008 E350 4-Matic
Can you please send the link to my email address ...
I have 2008 e350 and my COMAND not play Mp3
nawras_20@yahoo
Old Aug 21, 2013 | 03:16 AM
  #167
Irek's Avatar
E270cdi w211 2003
I have a problem. I have ECE Comand NTG1 with Video DVD decoder. Everything was fine until I started doing different things in EngineeringMode. I have deleted a file or something else (I remember I deleted something) by mistake and Comand has stopped working properly. He pointed to the monitor software update. I downloaded from the internet update file but it turned out that it's an update to the U.S. version. Now I have no video playback or dr.dist in EngineeringMode. When I want to install a version of ECE, Comand displays Wrong Version. Does anyone know how to reset to factory version Comand ECE, or how to remove the U.S. software from Comand to be able to install the ECE software again?
Old Aug 21, 2013 | 04:01 PM
  #168
Mackhack's Avatar
You deleted the flash ROM from your COMAND.
My advise to you and anyone who doesn't wanna **** up his COMAND: stay away from engineering menu if you have no clue what you're doing.
If you want PM me and I tell you how I can get your original firmware reflashed onto your COMAND.
Old Aug 21, 2013 | 05:26 PM
  #169
Irek's Avatar
E270cdi w211 2003
I cant write PM to You Mackhack (you have full PM memory), so i am writing here.
Yes, I agree, I made a mistake by going to EngineeringMode. MackHack thank you very much for your interest in my problem. I beg you help me fix my Comand.
Old Aug 21, 2013 | 08:13 PM
  #170
Mackhack's Avatar
Now you can. Got to clear a ton of SD programming work order requests
Old Aug 22, 2013 | 02:16 AM
  #171
Irek's Avatar
E270cdi w211 2003
I wonder if I can delete the flash ROM in this US version software just as I did it before. I was looking to spoil the Comand but this software Engineering Mode I did not find such an option to reset flash ROM. How to spoil Comand was calling for a software update?
Old Aug 22, 2013 | 08:21 PM
  #172
Mackhack's Avatar
just keep ****ing your COMAND up!
Old Aug 23, 2013 | 01:52 AM
  #173
Irek's Avatar
E270cdi w211 2003
You dont understand. I dont want to ..ck my NTG1. I MUST delete ROM because there is no other way to install ECE version on US one. Otherwise Comand show Wrong Version monit.
Old Aug 23, 2013 | 07:54 AM
  #174
Mackhack's Avatar
The things you know... Tztzt!!!
Oh and yes I understand, much more than you think. Good luck on your project if deleting...
Old Aug 23, 2013 | 11:49 AM
  #175
StanVoronin's Avatar
2005 e320 CDI
whats the latest software update available for a 2009 e350?
can someone pm me link for a download?
i currently have the 08 version
