E-Class (W211) 2003-2009
URGENT: NHTSA Opens investigation into fuel leaks on the W211 E Class
Old Apr 3, 2014 | 12:25 PM
  #376
E500wanabe's Avatar
07' E350 sport
Originally Posted by hutchinshouse
See attached
So if I'm reading this right California cars are covered for 15 yrs/ 150000 mi.?
Thanks!
Old Apr 3, 2014 | 12:43 PM
  #377
hutchinshouse's Avatar
2007 E350 (PZEV) Sedan
Thanks!
PZEV cars, you are 100% correct!
Old Apr 3, 2014 | 02:33 PM
  #378
E500wanabe's Avatar
07' E350 sport
COVERED BABY!!! YEAH!!!!!!!!!!!
Don't know the details yet,this is just what my wife just E-mailed me.
hutchinshouse RavenMDX
Old Apr 3, 2014 | 02:50 PM
  #379
^^Right on! Let us know what they fix.
Old Apr 3, 2014 | 02:57 PM
  #380
E500wanabe's Avatar
07' E350 sport
Will do.......
Old Apr 5, 2014 | 01:06 PM
  #381
fmijo2345's Avatar
2005 e320
My drivers side fuel sending unit went out in my 05 E320. has anyone replaced one?? hard ? dealer has one for $330...
Old Apr 6, 2014 | 09:29 AM
  #382
amg_w211's Avatar
2014 E63 AMG S, 4Runner
Exclamation NHTSA update: preliminary eval to engineering analysis
Looks like the feds are starting to listen and our complaints are getting traction, as of today, here's the latest update on the fuel smell issue from the NHTSA:
http://www-odi.nhtsa.dot.gov/cars/pr...h&summary=true
Report Date : April 6, 2014 at 09:25 AM
NHTSA Action Number : EA13003 NHTSA Recall Campaign Number : N/A
Vehicle Make / Model: Model Year(s):
MERCEDES BENZ / E320 2003-2005
MERCEDES BENZ / E350 2006-2008
MERCEDES BENZ / E500 2003-2006
MERCEDES BENZ / E55 2003-2006
MERCEDES BENZ / E550 2007-2008
MERCEDES BENZ / E63 2007-2008
Manufacturer(s) :
Mercedes-Benz USA, LLC.
Component(s) :
FUEL SYSTEM, GASOLINE
FUEL SYSTEM, GASOLINE DELIVERY
FUEL SYSTEM, GASOLINE DELIVERY:FUEL PUMP
FUEL SYSTEM, GASOLINE DELIVERY:HOSES, LINES/PIPING, AND FITTINGS
FUEL SYSTEM, GASOLINE:STORAGE
FUEL SYSTEM, GASOLINE:STORAGE:TANK ASSEMBLY
Date Investigation Opened : March 15, 2013
Date Investigation Closed : Open
Summary:
The Office of Defects Investigation (ODI) opened this investigation as PE 12-001 based on 20 consumer reports. The subject vehicles were the model year (MY) 2003-2006 E55 AMG model and the complainants alleged fuel leaks or a strong odor of gasoline both inside and outside of their vehicle, particularly after refueling. Some reports alleged that the leaks may be related to a Mercedes Benz 2008 emission recall (Campaign No. 2008020001) involving the fuel filter module. This recall pertained to MY 2003-2006 E and CLS AMG models only. These AMG models use a different fuel pump and fuel filter module than the non-AMG E-Class however they share other fuel system components, including the fuel tank. To date ODI has identified an additional 350 reports relevant to this investigation. Of those reports, 116 reports are on the E55 AMG model. The remaining 234 reports are on other E-Class models, such as E320, E350, E500, E550 and E63. Preliminary Evaluation (PE) 12-001 has been upgraded to an Engineering Analysis to further study the alleged defect. The ODI reports cited above, and listed on the attached document, can be reviewed at www-odi.nhtsa.dot.gov/owners/SearchNHTSAID.
If you haven't registered online your W211 online, please follow this link and get your complaint filed with the NHTSA:
https://www-odi.nhtsa.dot.gov/ivoq/ (direct link)
http://www.safercar.gov/Vehicle+Owners (general link)
The more complaints filed, the more likely we are to get a resolution with pressure from the NHTSA to Mercedes. Spread the word.
In the meantime, I'll continue to fill my gas tank 3/4 full.
Old Apr 6, 2014 | 11:20 AM
  #383
WANTED!!'s Avatar
14 E63, 05 E55, 03 Evo 8, 08 F250, 06 R6R, 92 Talon TSI, and instability
It's about damned time they're listening. What's probably helping is the scrutiny they're under over the most recent GM debacle and their role in it.
Old Apr 6, 2014 | 12:09 PM
  #384
Kwijibo's Avatar
2007 E550 4matic
Did everyone see MB's law firm November response where 20% of the text is redacted?
http://www-odi.nhtsa.dot.gov/acms/cs...003-58167P.pdf
Old Apr 7, 2014 | 06:32 PM
  #385
Cashville's Avatar
2004 E55
I also read the attorney's reply and am very curious of the redacted text. Defininitely somehting to hide.
Old Apr 7, 2014 | 10:19 PM
  #386
AMGAffalterbach's Avatar
2014 BMW M235i
At least we have some momentum here. I just hope there comes a time where they stop upgrading the status of the issue and do something about it.
Old Apr 8, 2014 | 10:05 PM
  #387
E500wanabe's Avatar
07' E350 sport
Ok guys update. Rear seat was removed and the pressure sensor was leaking. The part was only available with the fuel tank. That's it for details. I have never known a fuel tank to have a pressure sensor. I'm assuming I have a new fuel pump,sender and all related components.
The estimated parts $3497.50
Again a huge thanks to hutchinshouse and RavenMDX
Chris
Old Apr 9, 2014 | 09:41 PM
  #388
Green E-300 DT's Avatar
Late Built 2005 W-211 E-320 CDI
Thumbs down Mine is Leaking
Originally Posted by kkanuck
Are CDI's prone to this too?
Yes.
I believe that the CDIs fit into that leaking business just as all W-211s do.
I have not removed the rear seat yet, but when mine is filled up, it smells until the gauge is down to nearly half full. This just started recently.
I'm afraid to go to the dealer and ask.
Regards,
Derrel
Old Apr 10, 2014 | 09:03 AM
  #389
vettdvr's Avatar
03 E500 and Corvette
MB has had a lot to hide since the beginning of this Thread and before that!
Old Apr 10, 2014 | 10:55 PM
  #390
2014 BMW M235i
I blame all of this on Obamacare
Old Apr 22, 2014 | 11:43 PM
  #391
tonyML's Avatar
'00 ML320, '07 E550
Chris
Which dealer did you get your fix? hopping in north Cal, both "Hitchinshouse" and "jandmtv" was fix in south Cal.
I dropped mine off for the same problem and of course it not under warranty and they want $1300 to replace the fuel pump and pressure sensor.
My is 2007 E550 but my data card does not show code 917, I can only see 915 which is larger tank. Not sure why
Anyone with E550 in CA can help to see if your has 917 code?
TIA
Old May 1, 2014 | 11:34 AM
  #392
tr2ride's Avatar
2005 E500
Joining the battle.
2005 e500 ... exact same problem as being described by this thread.
I'm in NC but car is from Northern CA. Local MB dealership says I'm not covered under the original bulletin based on my VIN ( I don't understand why but no sense arguing with them ).
According to my service guy ( non mercedes dealership but specializing in MB ) the bulletin should cover all 211 chassis between 2003 and 2006. Is this not the case?
Calling MBUSA next.
Any other suggestions?
Old May 1, 2014 | 11:38 AM
  #393
GregMB's Avatar
Originally Posted by tr2ride
Joining the battle.
Calling MBUSA next.
FILE AN OFFICIAL CLAIM WITH NHTSA!!!!!!!
There are a bunch of links that direct you there.... do it.
The number of filings just keeps growing and growing, and it's becoming clear that this is NOT just an AMG issue.... too many other W211-chassis cars are seeing the same problem.
It's clear now why MBZ didn't want to deal with this fuel issue honestly from the start. The sheer number of cars affected is staggering!
Old May 1, 2014 | 01:47 PM
  #394
sirhjob's Avatar
E-Class
Hey MBworld, long time reader, first time poster. Love this site.
Same issue on my 2005 E500. Took it to the dealer and they want $1,500 to replace the "in tank fuel sender and level assemblies both with seals". Called MBUSA and got a case manager who offered a goodwill discount of a couple hundred dollars. No way I am paying that much. IMO, a few reasons why WE should be very upset about this:
1. This is a faulty engineering design safety issue that Mercedes is refusing to acknowledge as their fault. I understand business is business, but a well respected automobile manufacturer should have a moral standard to withhold, which goes beyond the legal realm. However, it is clear that their priorities are very much biased over making money than the safety of their consumers. Think about it, who would you likely expect in the backseat (where the leak is/the smell is strongest) of an E class? Your children, maybe? I am not okay with them breathing in the fumes, but Mercedes is.
2. Why have a recall on E55 AMG and not the other models? Perhaps, Mercedes believes that E55 owners are more adamant with the well being of their cars, so Mercedes tries to hedge their losses by satisfying those who are most likely to pursue the case. Are the fuel tanks completely different between the E55 and the other W211s?
3. "In the years of 2010 and 2011, Daimler plans to spend a total of €9.7 billion on its research and development activities. €6.1 billion of that total will be spent at the Mercedes-Benz Cars division." (daimler.com)
Ok, €6.1b = $8.5b in R&D. How many W211 cars were sold in the US in total? Correct me if I am wrong, but ~300,000? So the estimate to fix my vehicle was $1,500, and remember, that is including the mark up of the dealership. But I've read SOME people were quoted at $3,000, which also includes the markup. So lets just make a very very conservative estimate of recall costs at 300,000 vehicles * $3,000 at each car which is $900,000. Hmmm. $900,000/$8,500,000,000 = .01%. Of course, some additional costs may have to be considered, but will it be very significant? That I am not sure, but at this cost, this recall would equal .01% of their yearly R&D budget. Just a thought.
4. To throw salt on my rusty, tetanus filled, **** stained knife stab wound, Mercedes even PROFITS from our misfortunes!!!! Of course, "Das Beste oder nichts". Thanks, Mercedes!
Excuse my rant, but I am just a bit upset about this. So, just my 4 cents on this issue. In the end, I would think it should be a simple decision for Mercedes to want to protect the people who buy their car. But hey, I guess that's why I won't ever become CEO of a $158,529,939,000.00/year in revenues company.
Get your complaint heard by the NHTSA. https://www-odi.nhtsa.dot.gov/ivoq/
Old May 1, 2014 | 01:51 PM
  #395
GregMB's Avatar
On the E55, replacement of the in-tank filter is REQUIRED SERVICE at 60,000 miles.... I'm not sure if the same is true for the standard E-Class cars or not.
It's a numbers game.
MBZ knows that as the cars get older, people will be forced to replace fuel filters as part of normal maintenance anyway.... and if the new parts solve the issue and prevent leaks, their financial exposure gets smaller and smaller.
-G
Old May 1, 2014 | 02:18 PM
  #396
Cashville's Avatar
2004 E55
Joining the battle.
Calling MBUSA next.
I called mbusa and they said they would assign a rep. after I brought it in. They probably won't pay for it since recall was done in May of 2008. I however maybe lucky because I found out I have a warranty that is being transferred to me from prior owner. It is a Carmax warranty so I don't know. Definitely file a claim with nhsta, but don't hold your breath waiting for them or mb to do something.
Old May 6, 2014 | 03:19 PM
  #397
DEC-E350's Avatar
2004 CL600, 2008 W211, 2008 Armada, 2006 SLK350 w/ AMG pkg, 1949 willys
Hi All, Attached is a picture of the sending unit in my 08 E350. I originally posted this in an older forum by mistake. The color of the plastic is black and there are no stains or oder. Looks like it is ok. I took the passenger side cover off and there is nothing there. Looking at an 06 E55, before I buy it I'll look under the seat and inspect it.
Attached Thumbnails URGENT: NHTSA Opens investigation into fuel leaks on the W211 E Class-2008-e350-sending-unit.jpg
Old May 6, 2014 | 04:37 PM
  #398
Flash Gordon's Avatar
2003 E500, 2004 G35X
Your math is incorrect, recall of 300,000 cars at $3,000 each, the total is
$900,000,000 not $900,000 as you stated.
Old May 7, 2014 | 12:55 AM
  #399
asdf's Avatar
Filed, but my car is 03. Only noticed it for the last year or so. The garage smells worse than the gas station. No way I'd shell out 3k for this repair.
Old May 8, 2014 | 06:48 AM
  #400
vettdvr's Avatar
$900,000,000 not $900,000 as you stated. ......................... And now you know why MB gives little response.
