E-Class (W211) 2003-2009
The dreaded M272 Balance Shaft
Old Jul 19, 2018 | 06:13 PM
  #526
mountain man's Avatar
2006 E350
Boy do I feel like a loser for buying this car. My C320 was great. I'm going to let the wife buy the next car. She obviously has better sense than I do.
Old Jul 19, 2018 | 06:15 PM
  #527
2006 E350
It's surprising to me as an outsider how little mercedes cared about fixing what was obviously poor engineering. I also apologize for post padding. I don't how I can delete posts.
Old Jul 19, 2018 | 06:30 PM
  #528
Shack1's Avatar
06 E350
I totally agree, they knew the part was defective, IMO they should have covered the whole repair! 44k with a major engine malfunction is beyond words, look what Toyota did with the 3.0 head gasket issue, STOOD BEHIND THEIR
CARS AND CUSTOMERS.
Good luck Ill never buy another Mercedes after this ordeal.
Old Jul 19, 2018 | 06:32 PM
  #529
Shack1's Avatar
06 E350
MERCEDES IS THE ONLY ONE'S WHO SHOULD BE APOLOGIZING!!!
ILL PROBABLY HAVE THE DREADED SBC PUMP TRIGGER THE HAVE SBC UNIT SERVICED TOO, FOR NO REASON OTHER THAN A
SET FINATE AMOUNT OF SEQUENCES
Old Jul 20, 2018 | 05:17 PM
  #530
62bassman's Avatar
18 GLC300 4M
My 06 E350 has 138K miles and other than diligent routine maintenance and some scheduled replacements everything works perfectly. MB replaced entire fuel system at 110K , as well as transfer case and some other repairs earlier no charge. Seems like the owners of cars in the affected range that never have a balance shaft problem don’t bother to join this forum to complain. Given the number of those vehicles sold in that sequence, plus that the majority of balance shaft failures, according to MB statistics released in the class action were SUV and commercial applications, then the W211 series from late 05 to early 07 that are in the affected range do not all fail.
Old Jul 20, 2018 | 05:42 PM
  #531
2006 E350
I have the maintenance records for my car. I'm the second owner of a relatively low mileage vehicle bought from a family of Mercedes aficionados. I thought I did due diligence but apparently I was mistaken. My understanding was the engine should be reliable to 200k+. I'm not even at 100k. I can own up to wear and tear. I've had to replace the power steering pump and brakes are due in 10k miles.
However having this balance shaft issue pop up and seeing how pervasive it is and not having any real recourse but to junk the car is a huge pissoff. I could put another 2k into the car but 5-6k is crazy considering all the other maintenance an older car needs. European cars are more expensive to maintain. I'm fine with that. I know I'm beating a dead horse but this was pretty bad engineering and a lousy settlement that benefited the lawyers and not much else.
And I'm curious if you periscoped your shaft recently?
Old Jul 20, 2018 | 05:54 PM
  #532
cetialpha5's Avatar
You basically needed to do the research on the next car you buy. I was also interested in a 2006 initially just because it was face lifted but read the forum on all the problems and was going to get a 2007, but I got tired of checking to see if each one was past the balance shaft problem or not so I ended up with a 2008. Some standard maintenance stuff on it, but no crazy big bills like balance shaft/SBC etc. Biggest expense has probably been tires and bent rims.
Old Aug 28, 2018 | 04:07 PM
  #533
Bazil Jefferson's Avatar
mercedes cls350
Is £2000 plus the norm for a balance shaft repair on a 2007 cls350 ?
Old Aug 28, 2018 | 04:13 PM
  #534
95viper's Avatar
2007 cls550
In the US 4-5k independent mechanic and 6-7k dealer.
Parts are $500 plus another $500 in various tools and parts that should do while in there.
Old Aug 28, 2018 | 05:09 PM
  #535
Shack1's Avatar
06 E350
Im suprised an 07 would have the issue, miles? My repair at 44700 was $6500 dealer minus 15%, turned down at two indys.
Old Aug 28, 2018 | 05:31 PM
  #536
95viper's Avatar
2007 cls550
Take a non hardened steel gear and run a hardened chain on it. Done.
Old Aug 28, 2018 | 06:14 PM
  #537
Shack1's Avatar
06 E350
Thanks Capt. obvious. Was under the impression 07's were passed the issue
Old Aug 28, 2018 | 06:22 PM
  #538
jimbo1763's Avatar
2007 E350 Sedan
They were not. My early model year 2007 fell to the problem at about 78K miles.
Old Aug 28, 2018 | 06:46 PM
  #539
95viper's Avatar
2007 cls550
Reading you post implies that you don’t know what caused the problem. I have a hard time believing that anyone paid 4K yet still didn’t find out what years were affected. Maybe try that search function since the year ranges have been discussed hundreds of times.
But that’s just captain obvious so maybe not.
Old Aug 28, 2018 | 07:57 PM
  #540
Shack1's Avatar
06 E350
Yeah I don't know what caused the problem but I paid $5400 to fix it. LOL DID YOU HAVE A CAR AFFECTED?
Please tell me what the cut off date was, since you know everything about everything? Capt. Obvious
Old Aug 28, 2018 | 08:11 PM
  #541
95viper's Avatar
2007 cls550
Geez. Of course I had a car affected. I fixed it myself too and interacted with this community to learn and share information so relax dude. I wasn’t trying to bust your balz, I thought you had a legit question.
The cutoff off date depends on model. For my CLS, which has the same problem but a gear instead of balance shaft, it was around October. You need a vin search to get exact.
Old Aug 28, 2018 | 08:17 PM
  #542
cetialpha5's Avatar
It's mentioned several times in the beginning of this thread. Basically all of 2006 E350's and some early 2007 E350 models, probably sometime to the September production date. M272 was the balance shaft, the M273 (the 8 cylinder) was the idler gear.
You run the vin through a vin decoder like:
https://www.datamb.com/
And then you see if you're in the affected range or not.
Lots of people get things fixed without knowing what the original problem was. All you have to do is take it to the dealer and tell them to fix it and you get the bill afterwards and hopefully the problem is fixed.
Old Aug 28, 2018 | 08:21 PM
  #543
Shack1's Avatar
06 E350
I bet mine was at a lower mileage than yours. 44700
I bought the car in 09 with 22k, so if there were reports of this issue they were FEW.
I did plenty of research and tried to get estimates from indys but was turned down. At least I got 15% off as I was well over a year from the tiered settlement date.
I get a little pissed I admit it, when someone says I don't know what caused an obvious wear problem due to bad materials.
Still pissed that MB didnt cover the whole repair and made a car thats already had this and a transmission issue, im only at 48000 and had the transmission go to limp mode,
which I had repaired by shipping the control module and had its electrics repaired. Then I the damn indy shop didnt put the trans gasket in correctly and it leaked.
So I bought a transfer pump and another new gasket and did it myself. NO leaks and working great now. Next issue the Fing SBC brake bs!
Old Aug 28, 2018 | 08:28 PM
  #544
Shack1's Avatar
06 E350
Worst car I have owned PERIOD!
Old Aug 28, 2018 | 08:34 PM
  #545
95viper's Avatar
2007 cls550
Now we are definitely in agreement although mine has 38k miles on it now. I cannot believe that MBZ wouldn’t even give me the parts to do it myself. They covered up a problem and the settlement didn’t help those with low mileage cars who will eventually have the problem.
Thankfully I have an 07 and don’t have the SBC drama. I did have to replace an airbag though.
Old Aug 28, 2018 | 08:52 PM
  #546
cetialpha5's Avatar
Keep reading the forum. There's a surprising development where MB just decided to cover SBC up to 25 years unlimited miles. Before it was just 10 years so now you're back in coverage.
Old Aug 28, 2018 | 09:30 PM
  #547
95viper's Avatar
2007 cls550
Hey Shack1, Now that is great news for you on the SBC!
i have a 08 C350, 07 CLS550 and 11 E350 so as much as I want to complain about the sprocket the cars are awesome.
Old Aug 28, 2018 | 10:37 PM
  #548
Shack1's Avatar
06 E350
Great news. Do you have a link to the bulletin? or a site?
Old Aug 28, 2018 | 11:21 PM
  #549
95viper's Avatar
2007 cls550
Either click on that search button top right corner and type SBC or scroll down about 15 posts in this forum and it will be obvious.
Old Aug 29, 2018 | 01:02 AM
  #550
Shack1's Avatar
06 E350
Thanks Capt. Obvious
