E-Class (W211) 2003-2009
Squeaky Brakes
Old Aug 9, 2013 | 03:41 AM
AMGAffalterbach's Avatar
2014 BMW M235i
Angry Squeaky Brakes
I've searched the forums to try to find an answer, but I'm having a bit of a problem. For the first few thousand miles and even after bedding-in, my StopTech Street Performance Pads and R1 Concepts rotors were very quiet and the brakes have had great bite and stopping power.
On Tuesday, I went to get my tires rotated. After doing so, I went on a canyon run with a few friends and did quite a bit of hard braking and ran into a *little* bit of road dust. After coming back from that rally, I noticed that my brakes now squeak (I believe it's the front pads) at a certain threshold when I hold down the pedal at low speed. They do not squeak before or after this specific point of pedal travel.
I inspected the rotors and pads (visually without taking off the wheel) and they seem to be fine at first glance. I also took the car to a hand car wash and power washed the rotors and pads after letting them cool down a bit to flush out the huge amount of brake dust in there. This worked for a little while and then it came back I'm not sure what caused this all of a sudden and if it was the canyon run or something they did during rotation and re-torquing of the lug nuts.
The brakes are pretty new and should have easily 30k+ left on them, what should I do to stop the horrible sound, please help
Old Aug 9, 2013 | 08:05 AM
pinebaron's Avatar
07 E320 Bluetec
I know you decided against but Akebono brake pads..I've used them for years on my truck and Benz..never heard a squeak, no matter how I drive. On my truck I use frozen rotors (from tirerack) and the Benz still has original ones, will only use OEMs when needed.
+ I don't rotate tires on the Benz, staggered and directional tires however when I have them balanced, I specifically ask the shop, 'Mill Street Tires of Moorestown NJ', to torque them to 96lbs; at home I recheck with my own torque wrench, then again after about 100 miles driving.
Old Aug 10, 2013 | 01:03 AM
otto6457's Avatar
E350
Did your performance pads come with the dampening shims?
Old Aug 10, 2013 | 01:43 AM
2014 BMW M235i
Kevin from R1 concepts PMed me regarding a possible fix so I will try a braking procedure, I love those guys they have excellent ongoing support.
I rotate the tires on my car based on both the recommendation of my dealership and Big O tires, I think that rotation helps keep them quiet and last a bit longer as my tires are neither directional or staggered (running square 255s for 4-Matic). As for the Akebono pads, there is no reason I should have to change for those, thanks for the suggestion again but I would never trade increased performance for getting read of squeak that *really* isn't that severe.
As for the dampening shims, I am not sure that they did. While I checked the contents of the box I had StarTech install them for me so if they did come with shims as they were supposed to I am sure the technician installed them, if they did not come with any dampening shims then the answer would be no. Is this something that you can add later or do they specifically come with the pads?
Old Aug 10, 2013 | 10:36 AM
otto6457's Avatar
E350
Some performance pads don't come with dampening shims since brake noise is not much of a consideration when racing. You can always get the OEM shims if your pads didn't come with them. They will make a considerable difference in noise suppression if you don't have any shims now.
Old Aug 10, 2013 | 06:55 PM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
Try taking the pads off and use a small amount of brake lube on the back of pads and where the pads slide.
Old Aug 10, 2013 | 08:25 PM
Critter's Avatar
07 E63 + 07 CLK63CAB
Possibly you have a glazing on the pad surface from the hard braking. If it is that bad remove the pads and run the pad brake surface on a flat table or work bench over a piece of 100 grit sand paper to remove the glaze, also take a file and put a small chamfer on all the edges where they are 90 degrees. Reinstall the pads.
Old Aug 11, 2013 | 03:18 PM
vettdvr's Avatar
03 E500 and Corvette
I just put jurid pads on and ran them until they wore out. Never an issue.
Old Aug 11, 2013 | 10:45 PM
JP500's Avatar
2003 E500 sport (sold), 2009 GL450, w213 E63 (waiting for ordering guide)
I was going to open a new thread for this question but since your on the topic of brakes anyway then I will just ask it here... How long do breaks usually last? I mean on our Benz's at least... Iv driven my 500 for 65 thousand miles and I changed them about 3 times already due to squeaking at the end of the life on each round (OEM every time) and I see you mentioned @AMGAffalterbach, that your brakes still have about 30k or more in them... Just curious thanks
Old Aug 12, 2013 | 06:29 PM
09W211's Avatar
2009 W211 E350 AMG Sport PKG
my pos stoptech pads are unbearably squeaky, i'm about to replace them with posi-quiets or akebono's.
Old Aug 12, 2013 | 07:54 PM
06E5004ME's Avatar
06 S211 E500 4Matic
JasinP, it really depends on the pads and your driving conditions/style. I want to say on OEM pads you can expect at least 50k miles.
Old Aug 12, 2013 | 08:26 PM
JP500's Avatar
06E5004ME thanks for the reply
Old Aug 13, 2013 | 08:28 PM
2014 BMW M235i
I've heard of some squeaking issues with StopTech pads but I put quite a number of miles on them without the issue. Thanks for all of your replies and answers, I think it's quite possible I have a glaze built up over the pads so I will be sure to do that. First I'm trying a braking procedure that Kevin recommended then I will report back.
@JasinP as stated above, it truly does depend on your driving style. I go on a lot of canyon runs and brake fairly hard on those so I'm guessing I'll get 40k-60k out of them, I probably underestimated a little bit but I'm not very easy on them. Also important to note that unless you get down to metal on metal, brake rotors usually don't need to be replaced for 2-3 sets of pads, or more. Sometimes they can last the life of the car if you're doing a lot of highway driving but if you run your car to high miles good to get those replaced past 100,000 miles probably.
Old Aug 14, 2013 | 06:05 PM
09W211's Avatar
i'm over stoptech pads. i just ordered new posi-quiet semi metallic with new sensors. going in next week.
Old Aug 15, 2013 | 11:56 PM
Alan_G's Avatar
E320
I'm in the market for new brake pads and rotors, how are the R1 rotors? Have you had any problems with them? Ive heard some good things as well as bad things about them. Also are any of you familiar with the EBC brake pads?
Old Aug 16, 2013 | 12:35 AM
Go with akebono pads=low dust and quiet.
Old Aug 16, 2013 | 12:42 AM
Alan_G's Avatar
E320
Thanks for the reply. Would you recommend I also replace my electronic wear sensors or the ones that i have on now should be fine?
Old Aug 16, 2013 | 12:57 AM
2014 BMW M235i
R1 Rotors are incredible. Paired with StopTech Street Performance pads the performance is next to none and definitely better than stock. People are crazy about Akebonos here but they lose about 10-15% braking performance from stock and that's a no-no for me. I'd rather deal with a little squeak (which has improved through regular driving but I still need to try other solutions, but the car is spotless so I'm going to wait until the next time it's dirty) and get amazing performance and low dust.
Old Aug 16, 2013 | 01:36 AM
Alan_G's Avatar
E320
Thanks man. I think i might go with the same setup. Did you have to replace your electronic wear sensor or you think i will be fine with my old ones?
Old Aug 16, 2013 | 09:26 AM
Replace sensors, they don't cost much and sometimes come with the pad set.
Old Aug 17, 2013 | 03:36 AM
2014 BMW M235i
With StopTech Street Performance pads they came with the set, so you need to get a new wear sensor every time. Basically what stone said, very cheap part not complex at all.
Old Aug 20, 2013 | 06:40 PM
09W211's Avatar
did you get the ceramic pads? i just replaced my ceramic pads with posi-quiet semi-metallic pads and no noise whatsoever and stops the 211 fairly well.
Old Aug 20, 2013 | 08:29 PM
2014 BMW M235i
Was that addressed at me? StopTech Street Performance pads are para-aramid, which interestingly enough makes the brake dust stick a lot less.
