The Misnomer of Warped Rotors
http://www.stoptech.com/technical-su...nd-other-myths
Among the important excerpts from this page is:
"In fact every case of "warped brake disc" that I have investigated, whether on a racing car or a street car, has turned out to be friction pad material transferred unevenly to the surface of the disc. This uneven deposition results in thickness variation (TV) or run-out due to hot spotting that occurred at elevated temperatures."
There you have it. It is in fact thickness variation and not a warped rotor that is the cause of most vibration under braking - assuming the hub and other components are in good condition. Is this becoming common knowledge? Perhaps I'm telling you something you already know. But based on the number of threads I have seen stating differently, I thought I should post this. Probably the best solution in this case is to have the rotors resurfaced if a bedding procedure does not work to correct this.
Thanks!
Occasionally used to see rear rotors on Supras warp. But they were thin non-ventilated rotors that didn't like racing very much. Most people never get their rotors so hot they glow red so warping doesn't really happen.
On that note, if you've never been to the 24 Hours of Daytona, it's amazing seeing the brake rotors on the fronts glowing red at night as they brake into turn 1.
But yeah.......people call rotors "warped" when they get vibration under braking. Resurfacing rotors just removes the uneven deposit of pad material from the rotors.
Often caused by sticking single piston calipers causing one pad to drag on one side, heating up the rotor unevenly.
Rotors do warp boys, that's a real thing.
And I clearly stated that I had seen warped rotors. But the majority of the brake jobs I do where the customer complains of a brake vibration is caused by pad material unevenly distributed on the rotor surface, or the rotor itself wearing in un-even patterns. It takes way more heat to warp a ventilated steel brake rotor than 98% of customers can generate in a brake system under normal use.
If you will notice when you re-surface a rotor and you have a variation in thickness, those variations are not at the same location on both sides of the rotor. They are offset. That is because under braking the caliper assy moves laterally as the high spot passes under the pad, and the high spot on one side wears a trailing low spot on the other side of the rotor. The pattern can repeat several times around the rotor. Don't believe me, next time you turn a set of rotors, mark your high spot with one cutter bit, then slowly bring the opposite side bit in until it just touches the other rotor face. In almost every instance, the high spot on one side slightly preceeds the low spot on the other side. It's also not uncommon for both high spots to be in the same location on both sides of the rotor due to uneven pad residue, which would be impossible for a "warp" to cause unless the steel was at it's melting point. (2500 degree F) And disc brakes will fail long before that point as DOT 5 brake fluid will boil at around 350 degrees and at that point, the brakes will fade to nothing. Brake rotors just don't get hot enough under normal use to boil the fluid or warp a rotor. It takes a wide variation in temperature between sections of the rotors to generate the sort of metal fatigue necessary to actually "warp" a rotor.
In fact, on my most recent ASE re-certification test series, one of the questions under brake pulsation causes was:
Technician A says un-even rotor wear can cause brake pulsation. Technician B says pad material building up unevenly on the rotor can cause a brake pulsation. Which technician is correct.
a) Technician A
b) Technician B
c) Both Technician A and Technician B
d) Neither Technician A or Technician B
the correct answer was "c".
Most rotors we turn are not in fact warped, but the ones that are do not merely suffer from a little scuff of pad materiel, the metal takes a new shape due to heat cycles.
Bad information is bad.
"ether" based, when it is actually glycol based, and it does in fact claim that rotors cause pulsation from pad materiel build up. My direct experience is different, and I turn rotors almost every day.
Think what you want, it makes very little difference to me.
Unless you are turning them yourself, new rotors are often price competitive with turning rotors.
I read this article because I was researching warped rotors because I thought that was my problem.
As it turned out it was pad material buildup. After reading the article, I took the beast out on the expressway and made s few stops to build some heat. Then I ran it up to about 85 and stood on the brake pedal till I was almost stopped and then accelerated back to cruising to cool everything down. Since that time, my brakes have been as smooth and vibration free as new.
The adjustment I have made to my braking habits is to NOT sit stopped with my foot on the brakes after a hard stop as that is when pad material is transferred.
I have 64000+ miles on the original pads & rotors.
