E-Class (W211) 2003-2009
E350 cranks but no start
Old Feb 14, 2014 | 01:43 PM
HectorG's Avatar
2006 E350 4Matic
Hi, I have a 2006 e350 4matic, car was driving fine, temperature droped to -14 ,drove it for two days and the next morning it would not start, tried to jump start, no previous check engine light, has half tank gas, please help me , give me ideas to solve this, thanks.
Old Feb 14, 2014 | 03:39 PM
vettdvr's Avatar
03 E500 and Corvette
Not enough info to help.
Battery voltage
Spins won't fire
Doesn't spin
clicks
Powers up but won't spin
You will need more info to get any help.
Old Feb 14, 2014 | 05:31 PM
HectorG's Avatar
2006 E350 4Matic
Thank you vettdvr for responding, I should also mention that it showed warnings about battery on dashboard two days before it stoped , it cranks but no firing, Have not checked voltage on battery, it totaly died and recharged it with another car.
Old Feb 15, 2014 | 01:23 AM
homeofstone's Avatar
2011 E63, 2011 Hyundai Genesis 4.6 v8, 2013 GMC Denali XL, 1965 Ford Mustang, 2005 Merc. E500
have trouble codes checked. It could be the CPS. Not expensive.
Old Feb 15, 2014 | 02:17 AM
purplecty's Avatar
2006 E350
CPS as in crankshaft or camshaft?
Old Feb 15, 2014 | 04:23 AM
LemonSqueezy's Avatar
14 550 sedan
Crankshaft Position Sensor.
Old Feb 15, 2014 | 06:25 AM
purplecty's Avatar
2006 E350
http://www.autohausaz.com/search/pro...ition%20Sensor
Is this the correct one?
Old Feb 15, 2014 | 11:55 AM
ingydrummer's Avatar
2005 E-500 4matic sedan
DO you have pressure to the fuel rail. This happened to me once and it was the fuel pump. Not to hard of a R&R if this is what it is. The hardest part was getting the fuel level low enough to remove the pump.
Old Feb 18, 2014 | 01:50 PM
purplecty's Avatar
2006 E350
Is this the correct Crank position sensor replacement procedure for the 06 e350? This shows it was done on an AMG...
https://mbworld.org/forums/showthrea...472&styleid=18
Old Mar 9, 2014 | 01:15 AM
purplecty's Avatar
2006 E350
Im a friend of the OP. He changed the crankshaft sensor with an OEM one and still cranks and no start...
Old Mar 9, 2014 | 08:44 AM
Its maybe the camshaft pos. sensor. Also have codes checked first and don't waste time and money on parts not needed. Make sure shop has a code reader for Mercedes that will give you details on exactly what is wrong.
Old Mar 10, 2014 | 10:30 AM
purplecty's Avatar
2006 E350
Checked fuel pump fuse and relay which was fine. Had battery tested which came back a good battery and had it charged. He would like to purchase a code reader for the e350. What code reader do you recommend? Post a link please...
Old Mar 18, 2014 | 02:22 PM
purplecty's Avatar
2006 E350
Can a bad aux. Battery cause the car not to start? He had the car scanned with a proper scanner for mercedes. The main thing that the guy who came to scan the car pointed out was a bad aux battery.
Old Mar 20, 2014 | 02:51 PM
HectorG's Avatar
2006 E350 4Matic
I installed new auxiluary battery, recharged main battery and still does not start , cranks but not firing, any ideas I should try. Thanks everyone, vettdvr I need help, advice etc.
Old Apr 26, 2014 | 01:23 PM
purplecty's Avatar
2006 E350
Ended up being the fuel pump. Figured ide update the thread. New fuel pump fired right up!
Old Apr 26, 2014 | 10:26 PM
HectorG's Avatar
2006 E350 4Matic
e350 cranks but no start
I did also have to replace the fuel pump, and the car has been runing fine, but now the suspension in the front is lower than before, I need to lift the front , do you know the instrucctions to fix it?
Old Apr 27, 2014 | 01:14 AM
john0183's Avatar
2003 E500 sport
I am having the same problem but my car cranks and tries to start but it seems like it's trying to get gas but it's not enough pressure also when I open the gas , gas cap to fill up no pressure releases when I open the cap it starts after I prime the fuel pump the second time . Does anyone recommend a good Mercedes scanner to read my e500 and also a scanner for my airmatic system any help would be greatly appreciated .
Old Apr 27, 2014 | 12:42 PM
HectorG's Avatar
2006 E350 4Matic
Hi John, I a not sure about the scanner, can obd2 that reads m benz,at Orreily? My friend recomended me a tecnitian that came to my house, checked for codes, ask him to try to read if fuel was beeing send ,finally the fuel pump was not working, was replaced and car is ok, check if fuel pump is not working and needs to be changed, good luck.
Old May 20, 2017 | 07:06 PM
Billy Owusu's Avatar
W211 e350 4matic
Battery voltage
Spins won't fire
Doesn't spin
clicks
I got the very same problem, I replaced the crankshaft sensors but no luck.
Old May 20, 2017 | 07:17 PM
Steve_k_550's Avatar
W211 E550
At 190k km and no fuel getting to my fuel rail I presumed my fuel pump went bad however after replacing the fuel pump / fuel filter the car still wouldn't start .
I checked the rail and still no fuel which pointed me to the harness . Upon closer inspection and numerous testing I diagnosed the problem as a bent pin on the harness side not making proper contact with the fuel pump .
I cleaned the pin up and put a slight twist on the pin using a pair of long nose pliers so it could lock in properly and establish a proper connection.
