E-Class (W211) 2003-2009
Replacing Low profile with regular tires
Old Feb 20, 2014 | 01:20 PM
ny12577's Avatar
2012 E350 4MATIC
Post Replacing Low profile with regular tires
Driving in the northeast the roads are terrible, I have a 2008 E350 4Matic that I am thinking of getting rid of the low profile tires and replacing them with regular tires. Could I use the existing rims? would the suspension need to be adjusted.
Thank you
Old Feb 20, 2014 | 01:59 PM
LemonSqueezy's Avatar
14 550 sedan
I would not recommend using your existing wheels with bigger tires. Usually you have to keep your overall wheel+tire diameter or you'll run into a few problems. I would suggest you get a dedicated set of winter wheels and tires instead.
Old Feb 20, 2014 | 02:19 PM
Eayacht's Avatar
2003 E320 W211
If you get bigger profile tires using same rim diameter you will have a problem. Actually a big problem. Your ESP light will turn on as soon as you start rolling. And your trans will not shift into 2nd gear. Our cars have a rear wheel speed sensor. Take it from me, not because I'm an MB expert but because I didn't know this and I changed the tires and had this problem, lol
You can search on tirerack.com and you put in what car, and size rim you have and it will tell you what tires can be used on your car.
What size rims and tires do you have on your car now?
Old Feb 21, 2014 | 10:27 AM
vettdvr's Avatar
03 E500 and Corvette
Don't do it.
Old Feb 21, 2014 | 01:42 PM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
You need to downsize the wheels in order to upside the sidewall. What size wheels are you running?
I run 18" in the summer and 16" in the winter. There is a big difference in sidewall, and the 16" absorb potholes like a champ.
Eayacht - you still have a set of 16" wheels and tires for sale?
Old Feb 21, 2014 | 01:56 PM
rediesel's Avatar
Going from say a 245/40/18 to a 225/55/16 will make a real improvment.
Old Feb 21, 2014 | 05:03 PM
Eayacht's Avatar
2003 E320 W211
Originally Posted by rediesel
You need to downsize the wheels in order to upside the sidewall. What size wheels are you running? I run 18" in the summer and 16" in the winter. There is a big difference in sidewall, and the 16" absorb potholes like a champ. Eayacht - you still have a set of 16" wheels and tires for sale?
Yes I still have the 16" wheels but I think I'm going to keep them, so when I decided to sell my car I don't have to sell it with the 19" AMGs for my next benz
Old Feb 22, 2014 | 08:01 AM
pinebaron's Avatar
07 E320 Bluetec
+1. I also live in the the northeast and still have my OEM 16's/OEM tires on a Tirerack rack in the garage, with 95%+ tread. I usually drive my cars to the ground even though cannot imagine how, especially with this one, since I've only done 36K miles in almost 7 years from new. Fortunately (or not) this is not my daily driver, an SUV is.
