Can't remove oil filler cap !
'04 E320 4 matic.
OK guys, for the life of me I can't get the oil filler cap to unscrew. What am I missing here? (hell of a way to start off a project). This sucker just won't budge.
Yea Plutoe, the only problem with that is that I'd have to remove the engine cover to get a grip on the sides of the cap. Was looking for the short version.
Edit : @Quadcammer....thanks, that did the trick. One good tap and it broke loose. I was just surprised that it was so tight.
96 and 08 911 turbos
don't bother removing it.
drain oil from the bottom, remove oil filter canister.
once oil is drained, replace the plug and fill the oil through the much larger oil filter opening.
its faster and easier and doesn't require the oil filler cap off.
Thanks, my intention is to drain from the bottom and fill from the top. Just wanted to check the cap first.
Makes sense to fill via the larger filter housing though.
Removing the cover does take a little longer than 2.5 sec....remember those hoses. Plus, I didn't have to so all is well.
