E-Class (W211) 2003-2009
After market Android 4.4.4 Quad Core complete install. Vids and Pics and txt
Old Jan 8, 2016 | 10:16 PM
  #126
tubaprde's Avatar
E55, past: SL55, 560SEL
Originally Posted by NubyIz
For it seems ok. But I noticed when talking to another guy with exact same stereo that I got a strong echo of my own voice. Suggest to turn down volume. Also consider using an external microphone Also keep in mind these unit seem to have an issue with the mic hardware and amp. For a proper fix u would likely need a hardware mod. http://forum.xda-developers.com/showthread.php?t=266066 Look for "Mic sound is awful and click show content. Cheers
OK thank you I have tried both of the internal mic of the unit and the OEM Mike of the car and two extra mics and they all have the same issues. I think I've seen that hardware mod on there before and it require soldering. Hmmm, maybe I can get someone to do it for me
Old Jan 8, 2016 | 10:36 PM
  #127
Mrnd23's Avatar
2009 CLS550
I already PMed a couple of guys from this thread and thought will post this question to everyone too.
Saw this online while doing a bunch of research -
http://www.seicane.com/seicane-s1275...-camera-usb-sd
They seem to offer a $129 item that allows use of original amp. Any thoughts on this head unit?
Old Jan 9, 2016 | 02:05 AM
  #128
JoeNobody's Avatar
Mercedes
For $129 just install an after market amp, and sell all your old HK amps. Aftermarket sounds much better too.
Old Jan 9, 2016 | 12:39 PM
  #129
Mrnd23's Avatar
2009 CLS550
The seller replied very promptly as well and confirmed this seicane brand one fits the 2009 cls550 and that this $129 unit will allow use of factory amp instead of bypassing it with the 6ft cable.
so i am not really sure if this is a new amp or something that allows to connect to the factory amp and provide enough juice to power it.
Old Jan 11, 2016 | 02:31 PM
  #130
tubaprde's Avatar
Cheers
I tried following your instructions but didn't get anywhere that showed "mic sound is awful..." ?
Old Jan 11, 2016 | 02:46 PM
  #131
Mrnd23's Avatar
2009 CLS550
Anyone here tried this on a 2009 CLS? I have been trying to remove the woodpanel around the gear shift and it will not budge. I have seen the w211 dash removal videos on youtube and they all show just pulling on the front of the panel is pop it out and then it just needs to pulled out to release the rear clips.
I have pulled with all my strength and cant get it to move at all. Any suggestions or advice will help.
Old Jan 11, 2016 | 03:30 PM
  #132
NubyIz's Avatar
C219 CLS350
Try here:
http://forum.xda-developers.com/show....php?t=2660662
Look for "PROBLEMS AND SOLUTIONS FOUND BY THE USERS"
towards the end of first post.
Click on "show content".
Then look for "Mic sound is awful"
and again "Show content".
Cheers
Old Jan 11, 2016 | 03:34 PM
  #133
NubyIz's Avatar
C219 CLS350
I found first remove leather cover around gearshift knob.
Inside you can see clips towards the front, left and right. Try releasing them with screw driver and pull up panel at front.
Old Jan 11, 2016 | 08:23 PM
  #134
tubaprde's Avatar
Try here: http://forum.xda-developers.com/show....php?t=2660662 Look for "PROBLEMS AND SOLUTIONS FOUND BY THE USERS" towards the end of first post. Click on "show content". Then look for "Mic sound is awful" and again "Show content". Cheers
Ahh ok, next question is which unit do we (I) have?
Attached Thumbnails After market Android 4.4.4 Quad Core complete install. Vids and Pics and txt-image-3193112166.jpg
Old Jan 11, 2016 | 08:26 PM
  #135
NubyIz's Avatar
C219 CLS350
Hi, sorry, really dont know.. thats the limit of my knowledge.. suggest to browse through the whole post there, seems to have a lot of knowledge and might help u identify which model you have.
Old Jan 11, 2016 | 11:11 PM
  #136
JoeNobody's Avatar
Mercedes
See the Settings-> About screen. It'll say which model in one of the text strings. All info that's needed is in the first post of that huge XDA thread.
Old Jan 11, 2016 | 11:25 PM
  #137
djempirE55's Avatar
E55, Granturismo, F430, 993, E39, Jag
I had mine installed. Couldn't be happier with everything from the phone, BT audio and navi. I'm struggling with the Torque feature. I purchased the ELM327 but Can someone provide some info on how to set it up on the HU.
Attached Thumbnails After market Android 4.4.4 Quad Core complete install. Vids and Pics and txt-img_3101.jpg
Old Jan 13, 2016 | 12:28 AM
  #138
tubaprde's Avatar
Damn that probably means there's a problem with my individual unit's Bluetooth. Looks like you have the same unit I do.
Can you send me which dealer you bought the unit from? The link please?
Old Jan 13, 2016 | 03:12 AM
  #139
JoeNobody's Avatar
Mercedes
ELM adapter may not be working, because the stock rom only works if ELM has a specific device name. Upgrade to the modified Rom and it should then work. See the first page of that huge XDA thread and you will find instructions. Good luck.
Old Jan 13, 2016 | 06:44 PM
  #140
tubaprde's Avatar
Would you guys mind seeing what your model says in regards to this I would like to compare it to mine.
If we all have the same model then maybe my unit was not installed correctly or perhaps there's interference with the new amplifier and it's wires? I'm a totally a layman when it comes to this so I paid somebody a significant amount of money to do the install
Old Jan 14, 2016 | 12:27 AM
  #141
JoeNobody's Avatar
Mercedes
I had distortion in the front channels of my unit. I switched to using the rear channel to power both front and rear speakers, and now the problem is gone.
Either rca line is pinched, or head unit front pre-am is is bad. Works just fine for me because I just adjust front/rear on the amp.
Old Jan 14, 2016 | 03:43 PM
  #142
Gangrene3075's Avatar
03' Mercedes-Benz E500
After installing this unit. I never could get my Steering Wheel Controls to work. Re-checked installation and swapped CANbus decoder box with no luck. Do you think that ROM update may help?
Bluetooth MIC on my unit sounds crappy as well...
Old Jan 14, 2016 | 09:28 PM
  #143
JoeNobody's Avatar
Mercedes
Go into factory settings menu, and change canbus setting. Info is in this thread
Old Jan 14, 2016 | 11:00 PM
  #144
THAT WORKED!! Thank You very much!
Old Jan 14, 2016 | 11:39 PM
  #145
tubaprde's Avatar
Originally Posted by Gangrene3075
After installing this unit. I never could get my Steering Wheel Controls to work. Re-checked installation and swapped CANbus decoder box with no luck. Do you think that ROM update may help? Bluetooth MIC on my unit sounds crappy as well...
Are you thinking about soldering to fix it?
Old Jan 15, 2016 | 04:56 AM
  #146
No. Think I will leave it as is.
Old Jan 15, 2016 | 12:26 PM
  #147
Mrnd23's Avatar
2009 CLS550
Thanks NubyIz. the leather cover looks pretty solidly attached. not sure how i will get that off but will it a go soon and let you know. THanks again.
Old Jan 15, 2016 | 03:30 PM
  #148
NubyIz's Avatar
C219 CLS350
Will take a few pics and a video later today and post here.
Keep in mind my car is pre facelift 2006, yours might be slightly different.
Cheers
Old Jan 17, 2016 | 12:51 AM
  #149
gazosnic's Avatar
e46 m3, w211 e55
Awesome thread - excited about this...but have a few questions:
- How does audio sound if bypassing the stock HK amp through the cable they provide?
- Anyone have luck getting that other cable which allows you to use stock HK amp?
- Does the basic install require any wire cutting or splicing? Want to make sure its 100% reversible.
Old Jan 17, 2016 | 01:01 AM
  #150
NubyIz's Avatar
C219 CLS350
Sound is quite good. Had no HK amp, just a normal AMP at the back.
Havent tried the special HK cable.
No cutting or splicing required for radio installation.
Only needed that when hooking up power for reverse cam to reverse light.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
