Radio doesn't work - Mercedes logo turns on and off
I swapped the audio gateway with a used unit I purchased. I tried a fiber optic loop cable on the CD Changer and Tele Aid. I have no navigation and my fiber optic loop cable did not have the correct connector for the voice module but I did hold the cable by hand to the connectors. Still the same issue...
Could the Antenna cause this issue? It was damaged, I purchased a used unit and replaced it with no luck.
Please help...
Does anyone have any ideas? Is there anything else that could cause this issue? Maybe the actual comand/head unit is at fault? Maybe I should purchase more fiber optic loop cables in case I have more then 1 unit bad...
Sometimes you just have to go to the folks that have the proper test equipment. You can keep swapping components but that will not matter a whit if the issue is a short to power or ground in one of the components in the MOST ring.
If you don't have the knowledge or the tools, pay the dealer or an independent to correct the problem.
There are 2 components in the ring that can not be diagnosed with the fiber optic loop adapter, the head unit and the audio gateway. I assumed there was no damage to the wiring of the ring because when you pressed power on the old head unit and watched each connector that you unplugged 1 by 1 they would blink red twice indicating they received a signal. In my case the head unit was the cause of the problem, part replaced and everything is working normally.
Throwing money at parts:
$8.37 Voice Module
$8.78 Loop Adapter
$48 Audio Gateway
$80 Head Unit
$145.15 Total
If I had went to dealer and still done the work myself:
$120 Diagnostic
$80 Head Unit
$200 Total
So I saved myself $55 and still have 2 parts to sell reducing my total bill to less then $100, less then the cost of a diagnostic. Thanks for all the suggestions!
I went to the dealership yesterday and paid around 70 for half an hour inspection and they told me that I have to pay $2425. They said that the amplifier part ( 211-870-69-89) is bad and it costs 2000 + two hours labor. I looked it up online and it costs around 200 used but there are few ones with different serial numbers not sure which one to pick. I tried the resetting the awg fuse and didn't work.
if you got a solution please let me know.
I would thank my stealership for their diagnostic and pick up my car. The serial number is not going to matter, it looks like every unit had a different serial number, just pay attention to the part number. I would purchase the part they said I need for $120:
http://www.ebay.com/itm/2007-2009-ME...RYlOnO&vxp=mtr or make an offer on this one for $80 and see what he counters with: http://www.ebay.com/itm/2007-MERCEDE...JX8ANU&vxp=mtr
Then watch the video at the bottom of this post and replace it yourself with a few tools. If you don't feel comfortable with that, take the part you purchased and your smartphone to an independent mechanic, play the video for them and ask how much they'd charge you to swap it. If you didn't want to buy a used part then I'd look online for the best price of a new one or look for a rebuild service. Hope that helps save you a couple of thousand!
I am going to get one online and replace it at a local shop and I'll post my result. One more Question, my car is a 2003 e500 and the ebay parts you posted and most of what I found belong to 2007-2009 cars with harman kardon's audio system. I am not sure if mine is HK audio system I don't see any signs by the speakers. Does it really matter or as long as the part number match it should work fine ?
Thanks again..
I could check what the part # is on my amplifier/audio gateway when I'm at the car later if you want to know. I'm guessing I have an older part revision.
I was so excited to try the Radio! but IT DIDN'T WORK! Still freezes on MB LOGO!
The part number that the dealership gave me is different than the one I took out of the car. I scheduled an apointment with an audio expert for tomorrow so we can check other systems and bypass each one of them to see if there's another problem! I don't want to visit the dealership.. they told me it's the amplifier and it's clearly not :@.. I will post my updates
Does it need any programming ? and I noticed that the MB logo disappears after a few mins or secs now, it didn't do that before it used to just freeze and not disappear..
Best of luck!
I'll go to a different stealership for a final diagnose if it's not fixed I'll just accept the fact that I don't have a radio system..Can I install comand gta 2.5 the bigger screen one instead of my current one ?
do you know any place I can go in in Utah ?
Good afternoon from South Africa. I cut the Bluetooth dongle from the armrest compartment(when I bought the car, the dongle was missing and I could not get it anywhere else), hoping I'd just bypass the Tele Aid module and the SAM will see everything okay and I'll be able to use the audio system. Unfortunately I have got no sound still. Can anyone help please, I only cut the Bluetooth cables in the armrest compartment, and my ausio system stopped working since. ANY assistance would be highly appreicated. Thanks.
Then watch the video at the bottom of this post and replace it yourself with a few tools. If you don't feel comfortable with that, take the part you purchased and your smartphone to an independent mechanic, play the video for them and ask how much they'd charge you to swap it. If you didn't want to buy a used part then I'd look online for the best price of a new one or look for a rebuild service. Hope that helps save you a couple of thousand! https://www.youtube.com/watch?v=OwJjxDcQCas
which is good
