E-Class (W211) 2003-2009
2005 e500 Mercedes Benz
Old Feb 9, 2020 | 04:54 AM
Andre Henderson's Avatar
2005 e500 4matic Mercedes Benz
My car starts right up and stays running but the cluster panel is off. I mean the car starts and the blinkers work from the outside, the radio comes on the inside lights come on but the entire dash board is off. I have started the car over 10 times and ran it but the dash board stays off. Anyone have any idea what this could be or what should I do?
Old Feb 9, 2020 | 08:08 AM
konigstiger's Avatar
'71 Pinto
Check f52 @ front SAM (engine compartment). If fine, remove for several minutes in an attempt to reset if this fails you will need to remove cluster to check internal ribbon cables & circuit boards.
File Type: pdf
Old Feb 9, 2020 | 10:58 PM
Mercedes
Sorry I'm not mechanic savy but do you mean the fuse 52 on the driver side door panel by the dash and do also mean the glove compartment
Old Feb 10, 2020 | 12:47 AM
rodneypierce's Avatar
2009 e550 4Matic
No, he means F52 in the front SAM panel (engine compartment) There is a fuse panel in the front engine compartment, drivers side, close to the firewall. Its got a black cover on it with a slide lock on one side. F52 is the fuse number, located in that box.
Old Feb 10, 2020 | 01:52 AM
thanks so much I will check for it in the morning and keep you all posted,is the fuse panel located under the hood or driver side front dash?
Old Feb 10, 2020 | 01:54 AM
2009 e550 4Matic
under the hood..
Old Feb 12, 2020 | 11:51 AM
AeonTheTerrible's Avatar
W211 E500
I had this issue before on the exact same car. If I'm understanding you correctly, the car works and runs just fine, just the instrument cluster is dead so no speedometer/rev counter.
There were no other options for me other than to take it to a authorised MB mechanic and have them order the part (blanking on the actual name) of the onboard computer. Set me back 1100 US dollars, but I now have a fully working car.
Old Feb 12, 2020 | 10:29 PM
thanks a lot,I looked under the hood and on the driver side front close to the dash and found a black box with fuses in it but I didn't see a f52 fuse I only saw like a 25,50,75 nu fuse or my fault I should look at the numbers that the fuse is in for f52 to see if its blown or not am I correct and am I in the right box under the hood?
Old Aug 27, 2024 | 12:43 PM
Doingmybest's Avatar
E500 2005
are instrument clusters...
...plug and play when cluster model numbers match?
I've a dtc CAN issue pointing at the cluster.
THX!
