Driveline "surging" while cruising
Thank you!
Luckily, on this front, I can get a low mileage transmission for around $900. I just wanted to see if anyone else has experienced what I have described and could give some insight.
how are the front wheel bearings ?
Any chance you can hookup a acanner before replacing tranny with used one..?
The front wheel bearings have no play and are quiet.
There are no faults in the driveline. I have an Autel Maxisys Elite. I haven’t monitored while driving, but plan on doing so.
The surging isn’t bad, and a lot of people probably wouldn’t notice, but I live in a hilly area and it’s most noticeable on an uphill climb with light gas pedal pressure. I plan on doing a transmission service first to see if that fixes anything, plus I’m not sure when or if it has ever been done.
A relatively violent jerk when changing gears, before the gearbox is warmed up. Mine has done it for approx 10,000 miles, and I'm aware that it may cost more to fix than the car's worth (04 E320 Sport, 130,000 miles).
At this point it looks like I’ll have to do the transmission service first and then report back. All other fluids have been changed and made a huge improvement in the way it drives: no more binding when turning being the main resolved issue.
