LoMo M1 ELM install
LoMo M1 ELM install
Well I lied when I said that I wasn’t going to lower my car. ![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
I didn’t like the negatives that come with driving a lowed E-class but my car just didn’t look right with the wheel gap.
I will upgrade to thicker tires to better fill the gap but for now I went with an ELM.
I didn’t find any installs of Lomo M1 on the W212 on this forum so I’ll try to make this a detailed post. When I spoke to Ken he assured me that they have sold M1s for the W212 so I am not the first. Or maybe he just said that… lol j/k Ken.
I went with LoMo M1 because it fits with how I plan to use an ELM.
Here are the pics
The pics don’t show the gap that well. (I should have turned on the camera flash)
Control:
![](https://mbworld.org/forums/attachments/e-class-w212/204932d1299815391-lomo-m1-elm-install-control.jpg)
Install was easy. It took me 1.5hrs; A couple mistakes in the instruction slowed me down so it probably would have taken me only an hour.
Just like the Nav you can’t change any settings if your car is moving.
You have a range of -8 to +8 front and rear and Module on or off.
When ordering you can select what speed you would like the system to go back to stock. Default is 40mph. I asked for 35mph
If you would later like to change that speed you will have to send the module in and pay for shipping or drive to Phoenix. This is the only negative to the M1 IMO.
Module Off/ Stock height:
![](https://mbworld.org/forums/attachments/e-class-w212/204934d1299815446-lomo-m1-elm-install-normal.jpg)
Highest Setting (+8 Front, +8 Rear):
![](https://mbworld.org/forums/attachments/e-class-w212/204936d1299815564-lomo-m1-elm-install-highest.jpg)
The rear has a wide range. I didn’t measure the height but it looked like a 9” gap.
The front might have been about 5-6”
Lowest Setting (-8 Front, -8 Rear):
![](https://mbworld.org/forums/attachments/e-class-w212/204935d1299815446-lomo-m1-elm-install-slammed.jpg)
The rear gets slammed while the front looks about two inches higher than the rear.
I was surprised to find that I was able to drive like this with no rubbing in the rear. However I scuffed my front right rim on the inner fender.![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
-6 in sport mode is the lowest I can go in the front without rubbing.
My Choice (-6 Front, -4 Rear):
![](https://mbworld.org/forums/attachments/e-class-w212/204933d1299815446-lomo-m1-elm-install-driving.jpg)
In Comfort mode when I am driving and I will hit sport mode when I park for the look that I like.![naughty](https://mbworld.org/forums/images/smilies/naughty.gif)
Excuse the dirty car I just wanted to take pictures of the LoMo.
Here are the pics
Control:
I have mine set to go back at 35mph so it will already be at stock height at 100mph.
I got in on a special discount + $10 shipping
https://mbworld.org/forums/sl55-amg-...available.html
![](https://staticssl.ibsrv.net/autocomm/EvoM/fcotmicon.gif)
Received 3,416 Likes
2012 CLS63
wow 78 degrees @ 5:15!
Titleist
Tjd,
I have an E350, so no real knowledge on the airmatic system. You mention you have the system system set to go to normal height at 35 mph. I take it you mean that if we were to see you at highway speeds, your car would be at the normal factory height and the lowered appearance would be while the car is parked or at speeds up to 34 mph. Is my understanding correct? Is the speed/height adjustment user-defined, ie, you could have the car always at the lower setting, or it raises at 10, 20, 30 mph, or whatever you set?
Looks good and enjoy the Vegas heat!!
I almost didn’t but the M1 because of this. I think there might be times when I would like it not to turn off automatically, and I didn’t want to set the speed high because I didn’t want to go through the menu to turn it off when I jump on the highway every time.
Former Vendor of MBWorld
I'm happy you like the M1. Ken is a great guy. I work with him directly on many things, one being the M1 Lomo. I was able to get a sale going for this. If you visit our sister site loweringmodule.com we have a sale going on to MBW members. When checking out use promo code MBH-2011 (case sensitive). you will receive a special MBW discount on the M1 ELM.
Here is a video of how it works on my SL55
http://www.youtube.com/watch?v=44mjCMuLqZI
Here are the pics
Control:
Excuse the dirty car I just wanted to take pictures of the LoMo.![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
Here are the pics
Control:
Apparently another member here had an issue with the airmatic displaying errors when driving with it. I have seen the same error before but I don't often see it because I don't drive with the ELM on that often and it doesn't happen all the time.
I notified the distributer and the issue still has not been fixed.
Based on that I would NOT recommend this system to anyone for daily use until LoMo fixes it. It works perfectly and its perfect for me and the way I intended to use it however it seems that it has intermittent issues with the W212. (or maybe all ELMs are this way)
As for issues with dealers. I have not been in for service yet, however the install is completely stealth.
