Sponsored by: CARiD
Need help finding LED bulbs for my "High Beams"
Old Sep 5, 2015 | 02:40 AM
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
Hello everyone
I have 2011 E550 that did not come with Xenon headlights.
I just installed Xenon low beam kit and it looks and works perfectly, but my high beams and the other little bulb inside the high beam housing area regular halogen.
Does anyone know how to replace those 2 bulbs in the high beam housing with LED bulbs? and if its possible please let me know which bulbs I need.
Attached is a photo of my headlight.
Old Sep 5, 2015 | 08:18 AM
pamiboy's Avatar
E 350
Originally Posted by Kobzarhomes
Hello everyone
Replacing high beam halogens with LED will not serve any purpose other than "looks". The beam pattern from LEDs are completely different to halogens and the existing reflector housing will simply scatter the light, than pointing it straight ahead as you need for high beams. The so called superbright halogens bulbs will offer only a marginal improvement in brightness and color.
Your best bet would be to replace those projectors with E55 Bixenons (which I believe will be a simple bolt on replacement without any modifications, but not sure) which will give you the looks and performance you desire. If you want only looks you can simply place any compatible LED bulbs (I think H7) in the existing high beam.
Old Sep 5, 2015 | 10:45 AM
You are probably right that LED will not have a good light scatter.
**I guess my main concern is the little bulb on the bottom, inside the housing. It is yellow and does not look good when you have HID's on.
Im OK with keeping the high beam regular halogen I guess, unless its a easy swap with LED. I don't use high beams very often.
Old Sep 5, 2015 | 11:50 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
Suggest either keep high beam stock, or use whiter halogen bulb or go HID. LEDs are not a good option for high beams. City light can be swapped to LED though. You'll need a set of 194 wedge.
http://www.aznoptics.com/index.php?m...products_id=95
If you choose to go HID for high, we carry top shelf Morimoto HID conversion kits.
Old Sep 5, 2015 | 12:21 PM
What is the whitest halogen bulb for High Beam thats available and that will fit?
Old Sep 5, 2015 | 01:16 PM
AZN Optics's Avatar
The whitest halogen bulb we've seen that can even sniff HID temp range are Philips Diamond Visions. However, to get that level of whiteness, they sacrificed some lumens. That's why they're only approved for off road use per DOT. If you live in the city though and really only use your high beams to flash people, they're fine.
Old Sep 5, 2015 | 01:36 PM
If you sell them, please send me a link to the halogen white bulb.
Thank you
Old Sep 5, 2015 | 07:19 PM
AZN Optics's Avatar
Sorry, we don't deal in halogen bulbs, just LEDs and HIDs. I will say be careful buying those Philips bulbs online. There are a lot of counterfeit.
Old Sep 6, 2015 | 05:02 PM
pamiboy's Avatar
E 350
You can check with the Sylvania bulb selector tool for checking the type of bulbs you need. http://www.sylvania.com/en-us/applic...n.aspx#fldYear.
Parking lamp bulbs (?2825) can be switched to LEDs with the correct specifications .
I would be extremely cautious in replacing the high beam bulbs. Most of the whiter halogens achieve the HID look by coating the glass with blue dye which kills the lumens. But they are okay for purposes other than high/low beams. Yes, many of the eBay bulbs are fake (even those supposedly made in Germany and shipped from there) and the OEM manufacturers do not seem to care. Buy from reputed shops / retailers only (candlepower, retrofit source, etc).
Old Sep 6, 2015 | 05:05 PM
Thank you for the info.
I will probably just not mess with the high beam bulb unless I can find a good quality replacement. The other little bulb on the bottom I would like to replace since its always ON when headlight are ON.
Old Sep 7, 2015 | 04:25 PM
thenew3's Avatar
2020 X7 xDrive40i, 2016 X3 sDrive28i
I got these
Philips Diamond Vision H7 Philips Diamond Vision H7
for my high and low beams earlier this year. The color matches pretty well with the LED DRL, but they are not as bright as the factory Halogens.
I also got the 194 Wedge from AZN Optics for the "parking" lights (the small bulb in the high beam housing).
Old Sep 8, 2015 | 06:27 PM
channey's Avatar
2015 S550
For the brightest (not whitest) H7 bulb, I use these...
http://store.candlepower.com/osraulhiouh7.html
Old Sep 8, 2015 | 11:06 PM
pamiboy's Avatar
E 350
HIR bulbs will also offer much improved brightness but not color. It may not be ideal as the OP's concern is not brightness but color comparable to LED drls.
