Sponsored by: CARiD
Front camber arms?
Old Nov 13, 2016 | 08:34 PM
Chris_tA_4's Avatar
A4
Front camber arms?
looking to get front adjustable camber arms. Anybody know of any?
Old Nov 15, 2016 | 10:06 PM
Chris_tA_4's Avatar
A4
Looks like there is no such thing as front camber arms...only front camber bushings for our cars. Seems like KMAC is the only option?
Old Nov 16, 2016 | 09:34 PM
kp1's Avatar
kp1
2014 E350 4Matic Sport
Camber bolts got mine in spec for alignment. About $15 per side.
Old Nov 16, 2016 | 10:02 PM
Chris_tA_4's Avatar
A4
That's probably what I will do too. What brand camber bolts did you purchase?
Old Nov 16, 2016 | 10:12 PM
kp1's Avatar
kp1
Acdelco 45K18036
For the rear I bought Specialty Products 28855 bushings.
Old Nov 16, 2016 | 10:20 PM
Chris_tA_4's Avatar
A4
Acdelco 45K18036
How long have you been running Acdelco bolts up front? Any issues? Also, what is max camber, +1.75 and -1.75?
Old Nov 16, 2016 | 11:49 PM
kp1's Avatar
kp1
6 months. Not aware of any problem. I don't remember if they're +/-1.5* or 1.75*.
Old Nov 17, 2016 | 01:31 PM
belarus27's Avatar
2010 e550 p2
Acdelco 45K18036
any idea if these camber bolts and bushings will work for 2010 550?
Old Nov 17, 2016 | 06:36 PM
kp1's Avatar
kp1
Their catalogue says it fits all E-Class 2010-16 except AMG.
Old Nov 17, 2016 | 06:56 PM
belarus27's Avatar
2010 e550 p2
Thanks , might give those a try , because tires wear out a bit unevenly on my lowered 550
Old Nov 22, 2016 | 01:07 PM
Chris_tA_4's Avatar
A4
@Kp1 - did you do the install yourself? I've noticed that my E550 only has one bolt, not two, in the strut/spindle assembly.
Also, do you recall what size mm bolt they sent you? The reason why I ask is because the Acdelco 45K18036 bolt they sent me is really skinny in diameter in comparison to the OEM bolt i have circled.
Old Nov 22, 2016 | 01:34 PM
belarus27's Avatar
2010 e550 p2
is that ^^ where the camber bolts go? oh shidd it looks way more simple to replace than i thought , install new ones (instead the ones you have circled) , take it to alignment and thats it? im assuming...
Old Nov 22, 2016 | 01:37 PM
Chris_tA_4's Avatar
A4
yup that's where the bolt goes. Seems pretty easy. It's just with the directions supplied from Acdelco is shows an upper and lower bolt, not just one.
Old Nov 22, 2016 | 01:56 PM
belarus27's Avatar
2010 e550 p2
as far i as know only one bolt needs to be replaced. (did it come with 2 bolts per side or just one?)
thanks Chris , always thought it was more difficult and only can be done at a shop.
Old Nov 22, 2016 | 02:01 PM
Chris_tA_4's Avatar
A4
yes you are correct, only one bolt needs to be replaced. I'm gonna give it go now. I'll place a jack under the hub so that when I remove the existing bolt the assembly wont sag. That way I can easily push the new camber bolt into the strut/spindle holes.
Old Nov 22, 2016 | 02:05 PM
belarus27's Avatar
2010 e550 p2
NICEE thats what i do too , i use my 2 ton jack to lift the car up , and then the one that came with the car to hold suspension pieces in place or to raise or lower them to put bolts in/out )
PLEASE POST PICS , and your review on how did it go. i been debating if i should get those for a minute , and if all is good ima get them too. (cheaper than changing tires more often than needed)
Old Nov 22, 2016 | 02:10 PM
Chris_tA_4's Avatar
A4
Ill take some pics for ya
Old Nov 22, 2016 | 02:30 PM
kp1's Avatar
kp1
I did install the camber bolts myself. I don't recall what diameter they are. The eccentric is the same diameter as the oem bolt and the rest of the camber bolt must necessarily be narrower or it wouldn't work.
I'm not sure that's the right application to adjust a strut like you have on that E550.
Old Nov 22, 2016 | 03:14 PM
Chris_tA_4's Avatar
A4
ok bad new. These Acdelco camber bolts only work if you have them oriented for positive camber (tab facing outside of car). If you orient the bolt for negative camber (tab toward inside of car) it will hit the assembly and not sit flat...
Old Nov 22, 2016 | 03:16 PM
Chris_tA_4's Avatar
A4
I'm thinking about cutting the tab off to get them to sit properly
Old Nov 22, 2016 | 03:34 PM
belarus27's Avatar
2010 e550 p2
whatever you do , be careful. waiting on your progress
Old Nov 22, 2016 | 06:17 PM
Chris_tA_4's Avatar
A4
yeah I'm still going to torque the bolts down to proper spec. I'm not sure if I will be able to get any negative camber when all is said and done because I think these two lower bolts will not allow the spindle/knuckle to move. Even when I had the camber bolt in the positive orientation, as I would turn the bolt I didn't notice any change in camber. We'll see...
Old Nov 22, 2016 | 06:23 PM
belarus27's Avatar
2010 e550 p2
if they wouldnt work , they wouldnt sell them.
so you all done with it?? but you right , looking at these pics , looks like those 2 bolts do not move?
shidd im a bit confused now
Old Nov 22, 2016 | 06:40 PM
Chris_tA_4's Avatar
A4
I honestly don't think the camber bolts are made for the E550. Just the E350.
I didn't shave down the tab yet but I'll probably do that tmrw.
Old Nov 22, 2016 | 07:00 PM
belarus27's Avatar
2010 e550 p2
went to check compatibility and it shows that they should be fine.. ughh man.
