What octane rating do you use?
So am I going overboard with 93? Can I safely drop down to 92 or 91, or just stick with what I am using?
If equipped, and I think our bi turbos are so equipped, an engine will change its timing to prevent detonation, which has the related effect of lowering its peak output. Unfortunately it doesn't work the other way; adding a higher octane fuel will not give more power, only ensure the engine can produce its peak output.
So using lower octane than 91 will not harm the w212, but it will not produce full power.
I always go with highest octane level i can get from local stations.
In B.C. Canada, Chevron has 94 octane 0% ethanol.
But i have also heard our fuel quality is not as good compare to U.S.
So what's the % reduction of the reduced "performance" of not getting "full power" ?
Is it 26% less?
As for 100 octane, wow, $7.37 a gallon.
Octane is not a measure of fuel burn rate. Diesel fuel has a specification for cetane, which is actually a measure of burn rate - but this is not applicable to gasoline.
Octane is a measure of resistance to pre-detonation. If you use an octane rating too low for your engine, the air/fuel mixture explodes before it should (due to compression & heat), which causes knock.
You are correct - all modern engines have knock sensors, and will adjust timing to cool the cylinder temperatures and prevent knock.
In fact, at the terminal there is only Premium and Regular. For the retailers who have a mid-grade tank, the tanker takes on the correct amount of Premium and Regular in order to deliver the mid-grade. Some terminals may have mid-grade as an available pick-up, but it is mixed at the rack via a proportioner prior to going in the truck.
But most retailers these days have a tank for Premium, a tank for Regular, and a Diesel tank where applicable. Mid-grade is mixed at the retailer in these cases.
