Noise from engine compartment with car off. Should I be concerned?
2018 C300 4 Matic
2014 E350 sedan. Engine off - key out. Making a whining noise from the engine compartment (front/low). Sounds like something running??? Can feel a vibration through the hood. Do I need to be concerned?
Fire hazard?
Battery hazard?
Any advice/help/suggestions would be greatly appreciated. Thanks
Fire hazard?
Battery hazard?
LED lighting cool down fans. Lock the car and they should stop running within a short time.
abqhudson (09-20-2017)
W212 E-class, W211 E-class, F10 5-Series
Fire hazard?
Battery hazard?
Fire hazard?
Battery hazard?
whining noise from the engine compartment is usually the technician from a stealership after a service and nothing else was needed to be fixed.so no extra cash for them LoL
Fire hazard?
Battery hazard?
Fire hazard?
Battery hazard?
Hey, if you let the car cool down for about 30 to 45 minutes, it'll go away
Is the noise still occurring with the key in the ignition, or the key out of the ignition? or is it keyless-go?
That could have some affect on it...I know there are sounds under the engine with the key in, and after removing it (mines a w212 with no keyless go) after a few mins the whine goes away. There are a multitude of noises but the vibrations your describing dont sound good...
How long does it go for? maybe listen with a stopwatch
KEY08 (09-22-2017)
^ yep, this is absolutely correct.
