Sponsored by: CARiD
E350 4MATIC ESTATE (S212) lowering help!
Old Nov 24, 2017 | 02:45 PM
SteveS212's Avatar
E350 Wagon
Hey guys,
I have a 2012 E350 4MATIC wagon and want to lower the car a little.
I found a set of H&R springs to lower the car. It seems they only come for the front (2) springs....as the rear will lower itself once it recognizes the lowered front!?!?
Some please confirm that is the case.
Also, if anyone has this exact setup, maybe you can show me some pictures of the finished lowered car?
thanks!
Steve
Old Dec 28, 2017 | 11:49 AM
Exup99's Avatar
E350T Bluetec
Hi, as far as I know and can help, all the S212 (w212 Kombi) have the airmatic rear suspension, which means you will be able only to buy the front "normal" lower Springs.
As an extra, we can also have the front airmatic suspension.
The air suspension have a feature that force the car to self leveling every time the engine starts, so in theory if you lower the front, the rear will adjust to the front weight.
If the rear doesn't lower the same amount, you can always check for "Airmatic lowering links" for the rear.
In my case I have the front and rear airmatic suspension, so I can lower or raise the car (confort, or sport setting):
I hope it helps.
Old Dec 28, 2017 | 02:20 PM
Jabberwock's Avatar
Eclass
I would like to know if this is true as well.
Old Jun 11, 2018 | 11:36 PM
TO_MB's Avatar
2011 e350 Wagon & 2004 e320
SteveS212, have you lowered your wagon already? I just picked one up and would like confirmation as well. I looked today, springs up front and air suspension for the rear. Curious how to lower the rears. Thanks
Originally Posted by SteveS212
Hey guys,
thanks!
Steve
Old Jun 12, 2018 | 11:00 AM
SteveS212's Avatar
E350 Wagon
No, never ended up doing it. I felt that it was more trouble than it's worth. If I were to lower the car, it'll have to be coilovers for all 4 corners. I don't want to mess with an expensive part by having springs in the front and stock pieces in the rear.
Old Jul 11, 2019 | 11:04 PM
CanadianS212's Avatar
2012 MB e350 4matic s212 (wagon)
Hey y'all! I just bought a 2012 s212 and I want to trash the rear airmatic suspension. I can't find any type of kit anywhere to do that...
Can anyone help out?
Old Dec 10, 2020 | 10:27 AM
desobob's Avatar
W211 S212
Hi,
I'm in the same boat with my s212. Did you get anywhere with this?
Old Dec 10, 2020 | 12:22 PM
DFWdude's Avatar
2016 E350 Sport
Am I the only one wondering why anyone would want to lower a wagon? People buy the wagon (any wagon) for the extra load carrying capacity, and they are designed that way. (Is that why it has Airmatic on the rear wheels?) So, lowering makes no sense to me, fwiw.
Old Dec 10, 2020 | 01:33 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Sure, that's how they were designed... but not how people necessarily use them. Lowering cars, putting bigger wheels, added negative camber, roof racks that never get used... not just wagons.
Don't tell me people buy a E63 wagon because of the load-carrying capacity... I use my old E320 wagon like a truck, towing, hauling material inside, etc... I won't be using our E350 wagon like that anytime soon. Most don't use the third row, the wagon is just a gloried sedan with a bigger "trunk".
Old Dec 10, 2020 | 05:26 PM
desobob's Avatar
W211 S212
Angry
I'm interested in replacing the air springs with coil springs (S212). Conversion kits are available for S211, but there doesn't seem to be any for the S212.
Old Nov 26, 2021 | 10:09 AM
SteveS212's Avatar
E350 Wagon
So, after all my research...the only option I found was to buy H&R lowering springs for the front that drop the car 1.4"....and buying lowering links for the rear.
The option I found was from Airmatic Lowering Links from these guys ---> https://www.airmatic-lowering-links.co.uk/
Car will look like this afterwards:
Old Nov 27, 2021 | 02:21 PM
brentif's Avatar
2016 e350 4matic Wagon
Steve,
I currently have the H&R springs up front on my wagon, and a pair of the Ghost Links adjustable lowering links in the rear of my 2016 wagon, photo below for reference. Mine came with the sport suspension, and to be honest I am not totally happy with the ride now. I have owned many lowered vehicles over the years and this one disappoints me. There is an odd float going over speed bumps, and it is not the quality I would hope for. I took a leap of faith (and an amazing discount) and ordered a KW Suspension V3 coilover setup for a 4matic sedan https://www.kwsuspensions.com/produc...-35225069.html , and after speaking with KW, I am 99% sure it will work. I will not be able to use the rear springs, as I have airmatic, but based on my research everything else "should" work. Being that they are adjustable for rebound and compression, I hope to be able to dial in the ride to something more suitable (firm is fine with me as long as it is not bouncy). They should be here in 3-4 weeks, and I will update everyone on fitment and compatibility.
Old Dec 27, 2022 | 04:02 AM
Aussie_E350_Wag's Avatar
2013 E350 Facelift (Japan Import) 2007 E350 Elegance Wagon, 2014 E350 Wagon facelift model Jap Model
Originally Posted by brentif
Steve,
Hey Brentif,
How'd you go with the wagon suspension? Did you lower it using the links or go 4 X Coilovers instead?
Looking to lower my 2014 S212 at least 1"+ and I've been told you can code the self leveling system to think lower is now level instead of using links etc.
Anyone been able to try this method?
Cheers!
Old Jan 3, 2023 | 01:41 PM
brentif's Avatar
Originally Posted by Aussie_E350_Wag
Hey Brentif,
Cheers!
Car is doing great! Currently has the KW V3 coilovers up front. The rear is still on the ghost links and stock shocks. been waiting eight months for Bilstein B8s for the rear, as the KW sedan rear shocks were too long for my wagon.
Old Apr 15, 2023 | 12:26 AM
cheto's Avatar
e350 4 Matic Sport Wagon 2011 w212
Looks great, especially with no badges I am thinking about doing that on mine now.
Old Nov 14, 2023 | 02:25 PM
need2speed's Avatar
2016 S212 E400 RENNTech 345 whp/360 wtq
Update please, did the Bilstein’s work out?
Old Nov 14, 2023 | 05:18 PM
brentif's Avatar
Bilsteins have arrived, but I havent had the chance to install them yet. Hopefully next week I can get a couple hours set aside to get that done.
Old Nov 15, 2023 | 02:35 AM
BenzV12's Avatar
W212 FL
That's good , looking forward to hearing your feedback . I had bought Eibach but I have not installed them yet
Old Jul 12, 2024 | 01:21 PM
brentif's Avatar
Finally got around to installing the rear B6 Bilsteins. The ride is incredible compared to the stock shocks that had 90K of them (probably 30K miles of being lowered an inch and a half or so). Worth the wait and the install (which wasnt bad at all, took longer to get the rear interior apart to gain access to the top nuts than anything else).
