Sponsored by: CARiD
Is a loud engine normal for an E350 Sport?
Old Feb 23, 2019 | 03:28 PM
fganter's Avatar
E350
Originally Posted by Sunnyslope48
Sounds like an exhaust leak to me. My 2016 makes no such noise upon acceleration.
That's what I said. The mechanic (two if them at the same place) said he didn't hear anything that sounded like an exhaust issue.
They didn't rack it. Just popped the hood and took it for a drive (with me pointing out the noise).
Old Feb 24, 2019 | 05:30 PM
fganter's Avatar
E350
Originally Posted by LALALAND
Open the hood to check the firewall insulation behind the engine has sag. Kind of suspect that it let some engine noise into the cabin. I know that my insulation sag like around 1 inch in 2 area. Going to get the dealer to take a look at it to see if they can adhesive glue it back next time I'm in service. Maybe buy high heat resistance tape from amazon to tape it back flush against the plastic barrier/wall if the dealer won't take care of it.
I am assuming you are referring to the material shown in the picture.
It looks to be in pretty good shape to me. While there is just a tiny bit sagging forward, I cannot imagine that's responsible for the noise I am hearing.
Old Feb 24, 2019 | 07:59 PM
ItalianJoe1's Avatar
2003 CL 600
Originally Posted by fganter
Are you saying you had this problem, then replaced the mounts and the problem went away?
On dozens of cars.
mechanic said mounts would not fix the problem and I have at least 6 months before they need to be replaced.
How did he determine they had at least 6 months left? Clairvoyant? They are a rubber item that wears out with time/age. I've replaced them on cars with 50k, 20k, doesn't matter. When they are bad they are bad, there's no set time that they work perfectly.
yes, mechanic recommended by multiple people.
local mercedes dealer is a joke. Told me I needed $2600 of work without visually inspecting the car - recommended a bunch of stuff based on miles.
have you listened to the recording? I would be a tad bit surprised if that sound is because of mounts, but, hey, I'm new to this, so that's why I'm asking.
It's quiet in the video but that distinct tapping like an exhaust leak is what happens when the mounts are collapsed. The torque/load causes direct contact where there should be insulation in the mount and it transmits that vibration/noise.
Mounts are easy on that car. Don't look for a magic fix, just fix the actual issue.
Old Feb 25, 2019 | 07:44 AM
fganter's Avatar
E350
Thanks for you comments, @ItalianJoe1
He was estimating based on the amount of vibration on the steering wheel.
While I definitely would have preferred a visual inspection, he seemed to know what he was talking about. No?
Old Mar 7, 2019 | 07:33 PM
fganter's Avatar
E350
New engine and transmission mounts installed and guess what?...
Problem solved.
What I've learned:
- I am more sensitive to sound than most people. Some other Mercedes owners (including 3 Mercedes mechanics) thought the sound was normal. I knew it was not (and I've owned a Mercedes for only 4 weeks).
- Mercedes cars can, in fact, be almost as quite as Japanese cars in the cabin.
- Where to get my Mercedes fixed. I found an awesome mechanic who was really understanding and fixed the issue for a fraction of the Mercedes dealer's cost.
- These forums are quite helpful. Thanks to everyone for your input!
- @ItalianJoe1 is the man! He was the first to call out the fix and was right on.
Here's video after the new mounts, in case you want to compare to my earlier video
Old Mar 7, 2019 | 08:38 PM
MBNUT1's Avatar
2010 E350 4Matic
Problem solved.
What I've learned:
- I am more sensitive to sound than most people. Some other Mercedes owners thought the sound was normal. I knew it was not (and I've owned a Mercedes for only 4 weeks).
https://youtu.be/yBOReTgst60
Thanks for the report. Now go get some gas. . Did you notice any difference in the smoothness of the shifting?
Old Mar 7, 2019 | 08:45 PM
  #32
fganter's Avatar
E350
LOL. I was driving to the gas station, when I made the video.
I have not yet noticed a change in shifting. However, I just had the mounts installed, so I was paying more attention to the sound.
Old Mar 8, 2019 | 04:15 AM
  #33
spclagent7's Avatar
2016 E350
After watching/listening to your YouTube videos, I don’t think you’re more sensitive.
Theres definitely a big difference.
Also, my 2016 E350 is very quiet from the interior. (The engine seems to be noisy/slightly clackety at standing idle from the outside... Maybe I’m over sensitive!)
Problem solved.
What I've learned:
Old Mar 8, 2019 | 08:15 AM
  #34
FireRx Captain's Avatar
2020 GLE 350 4Matic, 2016 E350
Glad you solved it,. that's what mine sounds like on acelleration,. nice and quiet
Old Mar 9, 2019 | 06:55 AM
  #35
2003 CL 600
Not to say I told you so, but.... I did lol.
Old Mar 9, 2019 | 07:15 AM
  #36
CanonSterVA's Avatar
Veteran: Navy
E350 Sedan 4-Matic
Followed with interest.
Glad it was resolved.
Old Mar 9, 2019 | 10:58 AM
  #37
RA72825's Avatar
Problem solved.
What I've learned:
Glad you got it fixed and listened to advice. Don't ever go back to the idiot mechanic who steered you away from the problem.
Old Mar 11, 2019 | 11:25 PM
  #38
dacia's Avatar
2014 E350 station wagon gasoline
Problem solved.
Can you tell us the cost and how long it took the change them?
Old Mar 12, 2019 | 05:58 AM
  #39
fganter's Avatar
E350
$800 including labor and tax; 4 hours
While I could have gotten it a bit cheaper with another mechanic, I trusted this guy.
Old Mar 12, 2019 | 12:25 PM
  #40
not too bad, fgater, having a warranty check on mine today. will have him check my mounts also.
Old Mar 14, 2019 | 06:05 PM
  #41
MBNUT1's Avatar
2010 E350 4Matic
I'm guessing that you have a RWD.
Old May 25, 2019 | 01:46 PM
  #42
noladude's Avatar
2015 e350 sport
Saw your later posts. Thanks for sharing this. I will certainly get this checked out
Old Jun 25, 2019 | 10:07 AM
  #43
Frank Martinez's Avatar
2014 E350 Sport
Thank you for sharing... I have the same exact noise. Thank You!
Old Jul 5, 2019 | 09:48 PM
  #44
shak's Avatar
Thanks for sharing, had the exact noise, and new motor/transmission mount fixed the issue. It was however a pain the rear to replace, did that in my garage in about 5 hours all together.
Old Jul 6, 2019 | 01:33 AM
  #45
cocobeex's Avatar
2014 E550 4MATIC TUNED - Turbo Upgraded Stage 3
Problem solved.
What I've learned:
Was it under warranty ? or How much does it cost you to replace Engine mounts ?
My indy tech told me this will need 9 hrs to replace engine mount.
Old Jul 6, 2019 | 05:28 PM
  #46
shak's Avatar
I wonder how much more difficult it is to get in there for e550. According to this, http://www.mercedesmedic.com/diy-eng...mercedes-benz/ e350 and e550 are not that much different, and like I posted above, I did them in my garage with zero experience working on these, without a lift. Sounds like you may need to shop around. Because your is a 4matic, the passenger side may not be pulled from the back of the exhaust side, so alternator may need to come out, but still, 9 hours sound fishy to me.
Old Jul 25, 2019 | 04:44 PM
  #47
konigstiger's Avatar
'71 Pinto
See attachments.
File Type: pdf
File Type: pdf
Old Nov 29, 2020 | 03:10 PM
  #48
HAnZiDK's Avatar
C200 1.8 turbo
I have the exact same noise in my W204 C200 - Think i will get the mounts replaced right away
Old Nov 30, 2020 | 05:28 AM
  #49
Dingo L's Avatar
E250 CGI
Same problem and same solution.
https://mbworld.org/forums/e-class-w...ing-again.html
Old Dec 3, 2020 | 08:18 AM
  #50
Soulguard's Avatar
2010 Mercedes E 350
2016 E350 noise
Hello everyone.
I purchased my 2016 E350 with 30.000 miles 4 months ago, and I have the same noise, coming from the right side of the cabin, throttle-like sound exactly like the one in the video. I'm sure that the mounts are still in good , and still confused about the noise. Sometimes it's bothersome. On higher speeds and RPM, that sound disappears, and the car is quiet more than multiple cars I've driven. Its only occurring from a red-light stop or city driving at lower speeds. Anyone found solution? I took it for inspection when purchased and thr mechanic said everything is fine.
P.S. my previous car was 2010 E350 with 140.000 miles and it didn't sound like that at all. By the way, I test drive a 2013 E350 and sounded loud as this 2016 E350. Is it the new engine for that model with higher torque and horsepower "just" louder? Or is something wrong? Thanks in advance
