Sponsored by: CARiD
Rear passenger door won't open
Old May 28, 2019 | 08:13 PM
2011WhiteE350's Avatar
E350
hi all,
The rear passenger door on my car started to act up.
It won't open when I unlock the door. I tried to open with the door handle but it just won't budge..
Has anyone have the same problem before?
Thanks..
Old May 28, 2019 | 08:45 PM
Arrie's Avatar
Originally Posted by 2011WhiteE350
hi all,
Thanks..
Does the lock pin come up when you unlock?
Old May 29, 2019 | 06:26 AM
E350
The lock pin moves up when unlock and it comes down when i push the lock button.
The door just wont open.
I'm thinking about removing the panel from the inside to see what is going on.
Old May 29, 2019 | 07:10 AM
ygmn's Avatar
2015 E400 Sedan
Does door handle move easily or can you feel "linkage"?
Does it open from inside?
Old May 29, 2019 | 07:28 AM
E350
The door handle moves normal like the front one. I didnt feel any "easy feeling" like you said but i still couldn't open the door either from the inside or outside.
Old May 29, 2019 | 08:27 AM
ygmn's Avatar
2015 E400 Sedan
Time for dealer
unless you can get door panel off from inside with door closed and see what is going on to open.
Old May 29, 2019 | 09:32 AM
DFWdude's Avatar
2016 E350 Sport
This one is pretty weird. A door is just a door.
If you seldom use this door, I guess the weatherstripping can seal the door to the sill. But you have pulled strongly on it, I'm sure.
Old May 29, 2019 | 09:36 AM
DFWdude's Avatar
2016 E350 Sport
That back seat covers a lot of the door panel. I question whether you can get the panel loose where covered, without taking out the rear seat bench.
Old May 29, 2019 | 10:19 AM
RA72825's Avatar
Kick it.
Old May 29, 2019 | 12:07 PM
konigstiger's Avatar
'71 Pinto
Unplug (arrow) and disconnect electrical connector for several minutes in an attempt to reset door internals / door lock catch. Worst case removal scenarios, see attachments.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Jun 2, 2019 | 08:54 AM
E350
Ok
So I tried to remove the electrical connector but couldn't.
I pushed the tab loose and pulled the sleeve but still couldn't remove the connector.
The next thing is to remove two screws.. that is my next step..
Old Jul 14, 2019 | 04:57 PM
E350
hi all,
I was able to open the panel but still couldn't open the door..
I pulled the metal cable.. Tried to open from the outside but still couldn't open the freaking door..
It drives me nut....
I hit the surrounding area of the door handle hoping that can release the latch but no help..
The last resort is to drill out all the rivets and remove the aluminum plate to take a look inside..
Old Jul 15, 2019 | 07:12 PM
nota_amg's Avatar
2013 SL550 BiTurbo
I'm surprised you were able to get the panel off without damaging it, good show. Unfortunately it appears to be "Driller Time"
Old Jul 16, 2019 | 08:28 PM
Zavato's Avatar
2012 E350
At this point I’d take the car to an MB indie or the dealer
Old Aug 7, 2019 | 09:18 PM
E350
I did some more research and came up with one of the root cause... it's the door actuator..It didn't activate when I unlock the door either using the key fob or the outside door handle..
I found a few used one on Ebay and they are not that expensive..
https://www.ebay.com/itm/Mercedes-C3...4AAOSw2fNcoqTN
But let me check all the fuse one more time before I drill the rivet out ... just to make sure...
Old Aug 28, 2019 | 10:31 PM
E350
Finally, I was able to drill out the rivets and remove the metal plate but i still couldn't open the %^$$%$ door...
I tried to hit the door from the outside, inside but it still won't move..
Does anyone know where I can find the repair manual for W212??
I tried to search our forum and online but couldn't find it..
Old Feb 26, 2021 | 08:40 PM
adsldrew's Avatar
2005 E320 Sedan, 2012 E350 Coupe, 2014 E350 Sedan, 2014 E350 Coupe
What ever happened?
Hello 2011WhiteE350,
I have the exact same problem on the same door.
Please tell me if you ever got it open and whet you had to do.
I want to drill out the rivets but not for nothing.
If you could give me any more info, I sure would appreciate it.
Thank you!
Old Feb 26, 2021 | 10:10 PM
Left Coast Geek's Avatar
2016 E350 4Matic wagon, 2019 Ford Expedition, 2019 Chevy Bolt EV
you can buy bootleg copies of the WIS (Workshop Information System) on fleabay etc, for $10-30. most come as a preconfigured Windows VM you run under VirtualBox, and it takes quite a bit to get used to finding your way around it. Mercedes themselves only make it available as a online subscription service, aimed at independent repair shops, its like $15000/year or something.
Old Jan 30, 2022 | 02:38 PM
mushrooom's Avatar
E300 Ecotec Estate
I've got the same problem on the opposite door.
It was opening using the inner door handle but the seller put the child lock on and shut the door, now it's stuck shut.
I guess I need to strip the door and drill the rivets out
How hard was the panel to get off with the door closed ?
Did you ever fix it ?
Old Jan 30, 2022 | 03:23 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
DCM signature
Lucky I haven't had to deal with this yet. It seems the door no longer unlocks.
Guess what controls the tik-tok??
The DCM module with unsoldered pins
It's also possible the lock itself is worthless...
Go for easiest first!
Old Jan 30, 2022 | 03:25 PM
mushrooom's Avatar
E300 Ecotec Estate
Guess what controls the lock tik-tok?
The DCM module with solderless pins.
The door is unlocked but the child lock enabled makes the inner handle useless and the outer handle is floppy
Old Jan 30, 2022 | 03:28 PM
ouch, that is one weird combination!
Time to drill the inner plate.
They found a way to design a door handle mechanism that gently wears out after x-many cycles then fails.
Old Jan 30, 2022 | 06:04 PM
wow, must have been taking lessons from VW. both my 80s veedubs went through drivers door handles every couple years.
Old Jan 30, 2022 | 06:21 PM
the best or ....
These guys are really amazing... LoL
I did not know this problem has been so prevalent.
I hope we can get couple good pics of the latch actuator. I am curious to see how MB designed their limited life handle.
Old Jan 31, 2022 | 11:26 AM
mushrooom's Avatar
E300 Ecotec Estate
Sawed the handle off and put a wire coathanger through the hole and pulled the latch open
Turned off the child lock for now but found a used latch assembly on ebay
