DIY: Joyeauto Wireless CarPlay for NTG4.5/4.7
#426
2023 EQB 350 & 2014 GL350
Yes, there is. Check out the end of this thread:
https://mbworld.org/forums/e-class-w...-retrofit.html
A couple members are gonna install when they get the chance so I'd wait a little bit to wait for their feedback.
#427
W222 S550e, C207 E550, W212 E350
#428
Thanks!
#429
S550e: I've read on the other thread that you are waiting for yours! I'm really excited to see how it goes, really hoping this is a better solution for NTG4 users!
#430
From my understanding, the mic is only used for 'Hey Siri' (and Siri commands) and Bluetooth calling through the unit. I am only going to use the unit for maps and music so I am planning on leaving the mic in the glovebox or something. Or not plugging it in at all. You can still answer phone calls through the stock Comand unit with your steering wheel buttons, or flipping back to the Comand screen while the phone is ringing. I don't see the point for the extra mic, unless I'm missing something (feel free to chime in) but the NTG4.5 and above have the luxury of not needing an extra mic at all.
aibkaresz (09-06-2020)
#431
#432
Ahhaaa, you might be right! Well Siri does not support my language, and I have never used it for more than having 5-10 minutes fun with it, therefore if it is only required for Siri I will also leave it out. My other concern is connecting the phone via cable (to allow charging at the same time). Is it possible in the glovebox only? Would it be a nightmare to route the cable somewhere more accessible?
I'd say one of the better methods is leave the cable in the passenger foot well, use wireless CarPlay, and charge your phone in the cigarette lighter in the cup holder area.
#433
I believe the cable does provide charging and wired CarPlay. Most people place it snug in the passenger foot well, near the AC controls. You can also route it to the cup holder/ash area (by drilling a small hole) or in the glove box. The cup holder method will require you to take out the AC unit and cup holders but, if you are already taking out the Comand unit, it is not many more steps. But you will want to know where it is regardless so you can update the unit as needed or for the wired interface.
#435
After some additional thinking and research I am getting closer to understand the full picture. I have 2 question marks floating in front of my eyes now.
If the module is hidden between the main console and the glovebox as shown on the video, the glovebox must be removed every time when you want to update the module (of course wiring out the usb is an other solution). As I understand cadetdrivr removed a small plastic from the end of the glovebox to enable wiring into it and the module is easily accessible, I'm just wondering if the W204 has the same option, or if the wires are long enough. You can always drill a hole on the side of the glovebox but I would like to keep my car as close to factory or do at least reversible modifications.
The second one: if it's not possible to put it in the glovebox, and the module is stuck between the console and the box, if it's heating up can't it burn or damage the cables behind the HU and cause a short-circuit or fire? My trust is quite low towards these aftermarket electronic modules and if it's well hidden, causing damage I might not discover it until it's too late.
Thanks for the replies in advance!
#436
Hopefully yours has a glove box opening as well.
#437
#438
i have a W204 and mounted mine inside the glove box. Have had an issue once or twice when it was close to 100° out. It does take up pretty much the entire top shelf though. You could mount it below the glove box but I think inside the glove box is the best way to go to access the unit unless you connect usb cables to the unit so you can access it remotely
#439
2012 c63 estate
got a quick one to add her for mounting places.
note: this is a RHD W204 so your mileage may vary
I ordered 1 extension fakra video cable for mine and mounted it under the aluminum plate at the end of the passenger footwell, there was a gap of maybe 25mm between it and the firewall so I put some foam tape on it and ran the cables under the carpets to it. works nicely and a 2 min job with no tools if I need to look at it, and only 4 bolts if I need to remove it
#440
And just got my W204 C63 so digging into this topic! Had some questions after reading through the entire thread!:
1) Where does the CPU/RAM juice sit running the carplay? Is it on the iPhone itself, and then it just outputs it to the display?
2) Does the Android Auto work smoothly like CarPlay?
3) "3) Wire the USB extension cable as desired. I did not do this since I have access in the glove box, but you will want this cable installed for firmware updates, wired CarPlay, or wired Android Auto if the unit is mounted in an inaccessible location." -> can you use the existing USB port in the car? I assume not?
4) Do I need to buy anything extra for RHD (UK model) car?
5) I do not have OEM reverse camera. If I buy a third party one, that will only work via the new unit right? As opposed to NTG system. Will it automatically go to reverse camera regardless of where I am (e.g. CarPlay or using the native system)?
6) Where is the cheapest place to get the new models? I have a W204 NGT 4.5 MY14 (2013 production) and I am in the UK so if you see anywhere cheaper would be appreciated.
I see here:
a) £152 (but delivered from China so subject to customs): https://www.aliexpress.com/item/4001310599721.html from "professional car tools" store
b) £176 (but delivered from China so subject to customs): https://www.aliexpress.com/item/4000804978103.html from "carsara" store
c) £206 (delivered from Czech Republic so ~5 days, and no customs as within EU): https://www.aliexpress.com/item/4000656449555.html from "RoadTop CarPlay" store
Are these all the same?
7) What are people's thoughts on this vs the 10.25" Android screens (which have Carplay built in now)? I know they are about ~£350-400 so double the money.
Sorry for the millions questions!
#441
3) Nope, unless you can figure out how to patch into it.
wsc (09-09-2020)
#442
I had a local car audio shop install my RoadTop unit yesterday (I don't know anything about car audio install and wanted to get it done right). Overall the box works well, with the caveats that have been discussed earlier in this thread (have to use the scroll wheel for everything, no steering wheel controls for next/previous track, etc.) I have a 2014 E63S AMG wagon with the B&O sound package for reference. There are two questions that I was hoping someone might be able to help me answer, though:
1. My backup camera doesn't seem to work when in CarPlay. I am planning to take the car back to the shop and have them look at this to try to get it fixed. When I am in CarPlay mode and put the car into reverse, nothing changes on the screen, it just continues to show the CarPlay screen. When I go into the settings of the CarPlay box and click the Camera icon, I get a black screen that says "No Signal". When I exit out of the CarPlay box and am back in normal NTG mode, the rear view camera and 360 camera work as expected when shifting into reverse. Has anyone else run into this issue/is this just a settings issue? The tech from the shop told me that it was working when they installed the box (I forgot to test that it worked before I drove off unfortunately) so I don't think the issue is as simple as they forgot to plug it in, but just wondering if anyone has any thoughts here.
2. The shop that installed the CarPlay box for me had to run an Aux cable from the CarPlay box to the center console, plugged in via the AMI adapter. I was under the impression that you just needed to have Aux enabled before install (which I did, could see it clearly in the source menu), but that the audio would go directly from the box to the head unit without an actual Aux cable needing to be run. I unplugged the Aux cable while music was playing in CarPlay mode and the sound stopped (and came back when I plugged it in), so clearly the sound is coming in through the Aux input. Am I just wrong and I need the Aux cable in order to get sound? The reason I ask is that I would prefer not to have an aux cable sticking out of my center console if possible, but obviously will keep it as is if that's the only way to get sound from the CarPlay box to the head unit.
Finally, just want to say thank you to cadetdrivr and all of the other helpful posters on this thread - this is my first MB and I'm very grateful for all of the good info here.
907igor (09-22-2020)
#443
2) Also unplug the AMI adapter and try again. If that does not work, leave the AMI connecter detached and verify AUX is enabled in the Engineering Menu (see post #2 of this thread).
#444
1) Contact RoadTop for updated MCU and main software updates. Note that the 360 camera apparently does not work as well as the single rear camera and you'll see some posts in this thread talking about that. Also make sure that the OEM camera system is selected in the RoadTop settings.
On your answer to #1, I reached out to Road Top, but is the Benz2 20.7.16 the latest firmware? If so, that's newer than what I have. Do you just load it on to a flash drive, plug it in, and hit update?
#445
But note: there are TWO parts of the firmware and they can be updated independently. The "main software" (operating system and apps) and the MCU software. Essentially, the MCU is the low-level bridge that interfaces with the the car and it's an MCU update that helps with the cameras.
#446
Yes, the firmware is very easy to update via flash drive just like you described.
SDK version: 25.0.0.5.6.0.0.0
CUST version: v2.1.0.6.lt.m2
MCU version: 20.4.30.17
HW version: BENZ2
#447
If the the combination of CUST and MCU do not help your setup and also after verifying that the RoadTop setup menu is set to use the MB OEM camera, then follow up with RoadTop.
It also appears that their software releases are not linear or cumulative so the 'latest' version that fixes one user's specific issue may break other things. I'd suggest being very specific with any issues you have and load the software they give you.
#448
Do different manufacturers firmware to your work?
#449
2012 c63 estate
Hi - could you share pics? And a link to an extension fakra?
will take some pics when I get some days off, the extension fakra was just off ali express but took 3 months to get so would look elsewhere
most of the gruntwork has been done on the phone
don't know, haven't tested with an andriod
I removed the fakra style USB plug from the head unit, plugged an adaptor in and connected it to the joyeauto that way, means that I can connect the phone or update USBs via the usb in the armrest
it will all work without buying extras, but I was happy to spend 20 bucks more to make it more hidden/factory looking
supposedly yes, I haven't tried a non oem camera so can't comment
I see here:
I didn't look at this approach, I wanted to be able to go back to dead stock without any issues if I needed to
no worries
I see here:
no worries
#450
And, yes, the firmwares are reseller specific and require a code.
wsc (09-12-2020)
