Sponsored by: CARiD
DIY: Joyeauto Wireless CarPlay for NTG4.5/4.7
Old Dec 17, 2021 | 04:13 PM
  #701
Potrice's Avatar
2013 ML350 Bluetec, 1966 Ford Mustang Convertible (sold)
I ordered the Road Top unit for my W166 ML350 about 2 years ago and it worked well with my iphone. I bought a new phone (Pixel 6 with Android) and it will connect to the Bluetooth no problem but when I try to connect to the wifi, they are asking for a password. Does anyone know what it is? They didn't ask for a wifi password when I had my iphone...
Update: password is 88888888 (8x8)
Old Dec 24, 2021 | 12:02 PM
  #702
schalliol's Avatar
MB E550 '13, Rivian R1S Quad '23, Volvo XC60 T8 Ultimate '23, Honda Odyssey TE '16
On NTG 4.5 E550, we’ve enabled Aux in the hidden men, but it’s still not in the list of choices. Does anyone have ideas?
Old Dec 25, 2021 | 02:27 AM
  #703
brachu's Avatar
w176
hi
I have this problem in my roadtop box. When I turn on the indicator, the radio switches to a different view (as if the car thought I had a front camera). When the turn signal stops working, everything returns to its place. Let me add that carplay music works all the time. Link with my problem.
Old Dec 25, 2021 | 08:52 PM
  #704
schalliol's Avatar
Originally Posted by Mbw212-2013
Hi firstly thanks for all the help on this post, it has been really helpful in installing something like this for the first time.
I have managed to get everything working including CarPlay and AirPlay but unfortunately no audio. I have tried all the suggestions configuring MOST, turning on Aux etc using the engineering menu but still no solution. I have ensured the optical cables have been transferred to the new harness and followed all the instructions on selecting aux on the audio input.
Can anyone help to suggest a solution as the audio is the only remaining issue to complete the installation? Thanks in advance for any help you can offer
Were you successful here eventually?
on my W212 E550, I can’t get the Aux to provide any audio even though it now shows up. I don’t think Aux works with even a regular analog audio connection as originally intended either. I’d love any ideas!
Old Jan 11, 2022 | 05:42 PM
  #705
BillWoeb's Avatar
2014 E550 4Matic
I “installed” it in my 2014 E550 4Matic
I was able to play audio by enabling AUX, and selecting “external amplifier” in the engineering mode settings.
Old Jan 11, 2022 | 05:49 PM
  #706
BillWoeb's Avatar
2014 E550 4Matic
The Road Top kit works but I couldn’t get the radio to fit
I have the Road Top kit and
I tested it out with the radio partially inserted in the instrument panel and it works perfect!
BUT
I tried for 4 hours to make the radio seat all the way back in its location with no luck. The new harness has the large connector (which goes between the radio and the OEM harness) and I just can’t find room nor fit my hands to move it to a suitable location.
If anyone has ideas or is close to lower Michigan I will gladly pay you to finish what I cannot!!!
Thank you!
Bill
Old Jan 11, 2022 | 08:04 PM
  #707
DTofDUX's Avatar
GL450
Roadtop Unit in Glove Box
I realize this is an E class thread, but it’s the best one on this topic so I have subscribed here. In my 2013 GL 450 X166 I had the same frustration trying to fit the unit behind the radio. I instead placed it on the top shelf in the glove box.
There was an obvious spot on the left side of the glove box wall where I drilled a 1.5 or 2” hole. It was easy to snake the harness up through the hole and the box is simply sitting on the shelf. It appears from your photo that the E class does not have the same shelf, but perhaps you could either have it sit in the glove box, or mount it to the top of the box with straps. Good luck.
Old Jan 11, 2022 | 08:11 PM
  #708
BillWoeb's Avatar
2014 E550 4Matic
Thank you for the quick reply. My issue isn’t with where to put the encoder - it’s where to put the new power harness (with big black connectors). It just won’t fit behind the radio, unless I am really not seeing something (most likely!!)
Old Jan 11, 2022 | 09:24 PM
  #709
Davery's Avatar
2012 E550 Cabriolet 2011 VW Eos 1985 Pininfarina Spider
It took me several days to find a place for the harness. I believe I ended up stuffing it to the back, down and to the left.
Old Jan 11, 2022 | 09:28 PM
  #710
Davery's Avatar
It took me several days to find a place for the harness. I believe I ended up stuffing it to the back, down and to the left. I think I had remove some insulation to make it work.
Old Feb 18, 2022 | 07:57 PM
  #711
Dan Crăciun's Avatar
Mercedes
RSE 1 CABLE
Originally Posted by cadetdrivr
Now that the dash is opened up, it's time slide out the Comand unit.
1) Place a soft towel on the center console for protection
2) Remove the 2 T20 screws on the top of the Comand unit
3) Carefully start to slide the Command unit out until you can see the small wire harness attached on the right side. Disconnect the harness.
4) Slide the Command unit all the way out. Once out, I found that rotating the unit 90-180 degrees made the harnesses in the back easier to remove.
5) Remove both the MAIN (large black) harness and the blue LVDS (video) cable from the rear of the Comand unit.
6) Plug the blue Joyeauto LVDS IN cable into the back of the Comand unit (There are two LVDS cables, it's the one with a 90 degree connection)
7) Remove the optical cables from the MB harness. Be VERY CAREFUL with these optical cables. Do not bend or force them at any time as they can break. I found that I had to strip away a few inches of the wrap around the MB wire harness bundle to free the optical cables.
8) Plug the large black MB harness into one end of the Joyeauto harness
9) Attach the Joyeauto power cable to the Joyeauto harness
10) Plug the other end of the black Joyeauto harness into the Comand unit
11) Plug the optical cables into the rear of the new Joyeauto harness at the rear of the Comand unit
12) Attach one end of the Joyeauto audio cable to the Joyeauto harness AUX IN
13) Attach the Joyeauto LVDS out cable to the MB blue monitor cable
14) Fish all the above cables that will attach to the main Joyeauto unit behind and to the right inside the dashboard as necessary making room to reinstall the Comand unit. Since I was going to install the unit in the glove box, I positioned them in that direction around the interior components of the dash.
15) Now we will slowly start to put the Comand back in place. Even with all the new cables moved out of position, it will be VERY DIFFICULT to get the Comand unit to fit back due to the new harness. It will take some trial and error, but CAREFULLY move the wiring harness to a least bad location while ensuring that everything remains connected. I found success with the large black harness connector forward, up, and toward the driver side. YMMV.
16) Before sliding the Comand unit all the way back in, reattach the small harness on the right side
17) Once the Comand unit is back in place, install the two T20 screws. Whew!
Hi. Any suggestion from where I can buy NTG4 RSE 1 cable for external monitor preferably with rca video output? Thanks in advance, guys!
Old Feb 18, 2022 | 08:39 PM
  #712
strife's Avatar
560SL, 380SL, E350
This is effectively what I did. For that reason alone, I hope that I don't have to ever remove/reinstall this again. This unit has radically improved and modernized my car and I hope that it or its cabling never breaks.
Old Feb 22, 2022 | 01:45 PM
  #713
Henry_jenks_'s Avatar
2013 MB C250, 2009 MB SL550, 2018 BMW X3 X30i
carplay
Hello I saw that the carplay works for the NTG 4.7 unit as shown but will it work in my 2013 C250 because it has the same NTG 4.7 command system
Old Feb 28, 2022 | 01:15 PM
  #714
Navrozashvele's Avatar
W212 Facelift
Hi I am looking to install android auto on my w212 facelift. I want to be able to connect to it via android wirelessly and have 360 camera activated once I shift to park. After talking to sellers these products "satisfy" my needs:
https://www.alibaba.com/product-deta...196986908.html (seems like roadtop box)
https://www.aliexpress.com/item/4000656837413.html actual roadtop unit
https://www.alibaba.com/product-deta...227390938.html I couldn't find about this company but they're standing behind their product and give me warranty on it.
To people who have use android. Which should I go for? Which have best integration with built in 360 camera?
P.S I am going to have it installed by a professional.
Old Mar 18, 2022 | 07:34 AM
  #715
W212 Facelift
Hi, I installed roadtop unit connected aux grond to ground and all that but sound has static in it and is very bad quality. Has anyone experienced it before?
Old Mar 18, 2022 | 09:00 PM
  #717
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
How irrelevant
Old Mar 18, 2022 | 10:50 PM
  #718
cadetdrivr's Avatar
2014 GL350
Originally Posted by DubVBenz
How irrelevant
No kidding. That unit would work for what, 5%, of W212's?
Old Mar 21, 2022 | 06:42 AM
  #719
W212 Facelift
If anyone looking to update firmware of roadtop device here you go:
System forced upgrade:
1. download the file,Find an 8G USB flash drive and format it in FAT32 format, Unzip the file and copy the upgrade files "GEMINI_PACK.BIN" and "recovery111#" to the root directory of the U disk, not in the folder
2. Insert the U disk into the USB port of the decoder
3. Within 10 seconds after the car is powered on, immediately long press the "C" button for 5-8 seconds and then let go (within 10 seconds after the car is powered on, you must long press the C button. If it exceeds 10 seconds, you cannot enter the forced upgrade by long pressing the C button)
4. The entire upgrade process needs to wait three and a half minutes
I will update it once I have it time and post results
Old Mar 21, 2022 | 10:24 AM
  #720
Erro's Avatar
C class w204
Aux issue
Hi all, I've installed one of the newer boxes Limcet box, installed all good but audio only comes left hand side oft he car. At first I thought that Ive broken the fiber optic cable, however when playing original car radio it works throughout all speakers in the car, any ideas what it could be? I guess I would have to move HU and check connections again just want to have an ide at what I should be looking at. Thanks
Old Apr 25, 2022 | 11:10 PM
  #721
prestj's Avatar
Merc W176
It sounds like the ground wire isnt grounded properly, is it connected to a non-painted bolt or chassis? I stripped the paint off 1 off the bolts in the centre console and connected to that and it runs fine. Before I took the paint off the bolt I had a similar issue with a lot of static and low audio volume so I'm pretty sure your ground wire isnt grounded properly.
Old Apr 26, 2022 | 08:27 AM
  #722
W212 Facelift
I have it grounded to a cable which comes off harness that connects to head unit. I tried grounding to a chassis and had same issue. I got ground loop isolator and installed it between aux and aux adapter. It works good enough that I have to turn up volume to max(which I rarely do lol, its very loud) to have static.
Old Apr 26, 2022 | 07:21 PM
  #723
JettaRed's Avatar
Veteran: Army
What version is the firmware update? What problems is it supposed to fix?
Old May 22, 2022 | 05:03 PM
  #724
Seryog's Avatar
W218 cls350
Carsara android auto
Hi to all does anyone know how to update this device. thanks in advance.
Old Jul 31, 2022 | 10:19 PM
  #725
SchneiderIS's Avatar
ML350 BlueTec
Since I no longer need my clip on vent iphone holder/charger I decided to make a wireless charging pocket. It turned out pretty good.
Just seeing this, and am inspired. What a great mod!
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
