Sponsored by: CARiD
Hard to Pull Parking Brake 2014 E350
Old Aug 24, 2019 | 04:06 AM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Hi. i own a 2014 E350 4MATIC and it takes a lot of pulling to get the parking brake to disingage, when looking at other forums it happens in cold temperatures, but my happens in hot and cold temperatures? is this just something that needs to be adjusted or what?
Old Aug 24, 2019 | 08:36 AM
spclagent7's Avatar
2016 E350
I took my 2016 to the dealer. They replaced the brake release assembly.
Old Aug 24, 2019 | 09:32 AM
DFWdude's Avatar
2016 E350 Sport
For some in hilly country this is an issue previously discussed. Here is just one thread... https://mbworld.org/forums/e-class-w...e-release.html
Old Aug 24, 2019 | 04:39 PM
Zavato's Avatar
2012 E350
I had a similar issue. They initially lubricated the mechanism them replaced it.
Old Aug 24, 2019 | 06:39 PM
Alandf's Avatar
2016 E350 Sedan
Also had the similar issue. Known failure of E-350. Dealer replaced assembly ,no charge.
204-420-15-84 Foot parking brake
011-990-58-04 Screw w/socket drive
Old Aug 25, 2019 | 10:47 AM
konigstiger's Avatar
'71 Pinto
You can check adjustment @ rear wheels but most common problem assembly need replacement as mentioned. Part # is correct not sure why dealer replaced screws it is not required. See attachments for replacement.
File Type: pdf
Old Sep 29, 2019 | 02:28 AM
Fixed the problem and only costed me a can of wd40
I followed this video. sunroof lube is expensive. Just used lithium grease. Don’t know how well it will hold up. But it’s working!!!!!!
Old Oct 8, 2019 | 01:45 PM
cespinal26's Avatar
CL
Had this same issue...
Dealer was looking to charge 600+ to swap out those parts, I said no thanks and instead sprayed it with dry silicone lubricant and it was good as new.
Old Oct 8, 2019 | 08:43 PM
YAY. Glad I could help, or did you just think of it haha.
im surprised a lot of people don’t know about it.
Old Oct 15, 2019 | 10:10 PM
Alandf's Avatar
2016 E350 Sedan
Angry
Not surprised- NOT releasing again. Have to pull pedal up with toe
Old Oct 15, 2019 | 11:34 PM
Use the WD-40 method and then mercedes paste or lithium grease. Follow the video!
all the best!
Old Oct 16, 2019 | 09:06 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
From what I'm reading, this is a fairly common problem. I just bought my W212 last week and it was getting stuck out of the gate. Took the car in and after full inspection, they determined the mechanism was binding and they replaced the entire assembly under warranty
Old Apr 30, 2020 | 12:05 PM
PapaStahl's Avatar
C240 Wagon (sport)
@ml3504matic___
I found the same YouTube video and it worked for me too!
