Idling High rpm stoped help
Enginw Rpm in morming or when start motor 600 rpm
when i start moving and stop ia 800 rpm. No lamp in dashboard . Ac is off temperature outside 15 °c .
anyone amy idea what is . I check in servise and change a little.sensor in footwell passanger .
no problems .
i have change : ecu , all inside cabin sesnors , i have changet dhe altenator and battery becouse voltage in engine on 12.5 v ans sometimes 14.5 v .
This person at diagnostic centet tell me you need to havw update in mb offical or update frimware
no problems .
your idle rpm is a little too high when warmed for no apparent reason, right ?
You've changed many parts with no improvement.
I don't know your mileage or service history... have you considered the engine air breather system (PCV)? It can introduce a fair amount of unmetered air and cause all oil seals to leak blowby pressure.
As far as voltage swings, 12.5v to 14.9 is totally normal knowing the alternator regulation is controlled by the ECU. An output of 12.5V correspond to the alternator supplying all the consumers once it has recognized the battery as fully charged.
Turning the Headlights ON, defaults the alternator output to 13.5V or above.
I had same problem with the idle RPMs stucking at 800, that was on and off very offten, some were saying that is because the bluetech cycle, bla bla. The issue was coming from the Intake Port Shutoff Actuator, looks like this part doesn't actuate on the closing side after some time, it stuck at the possition where the engine RPM output is 800 RPM.
Everyone who has this issue should change that Intake Port Shutoff Actuator and clean the lever and all moving parts that this has to do with. No one who fixed this issue hasn't come back to tell us from where was coming. I guess I am the first one haha
Thank you,
