Service indicator after Dealer Visit
Took my 2016 E350 to the dealer since they were running a special on my A3 service. I just flipped 50k miles, they wanted to do plugs and air filter, told them told them to hold off.
After getting the car back, checked and noticed it says my next Service B9 is due in 365 days. Why Service B9? It's only had 1 Service B last year so I'm a bit confused.
Any ideas?
Thanks all for the help.
Any ideas?
Plugs are due at 50,000 miles. My car is at 46k and also saying A3 is due - services 1, 3, 8, and 12.
1 - A service
3 - Oil/filter change
8 - Engine air filter
12 - Spark Plugs
It sounds like they confirmed partial service in the ASSYST menu. If you go into the "secret" menu, it will give you numerical codes for what all is due at B9. I suspect what you didn't let them do is part of the "9" in B9.
1 - A service
12 - Spark Plugs
pierrejoliat (04-25-2021)
Received 1,008 Likes
'11 E350, '11 E550, '98 M3, '95 E320
OP, go into the workshop menu: https://mbworld.org/forums/e-class-w...e-message.html
and select Assyst Plus and see what services (#s) are due. I never understood what A1, A3, B5, or B9 meant... I mean, I know what an A Service and B Service is. The number following... I'm not sure. In the workshop menu each service # corresponds to maintenance as LILBENZ320 posted.
Here's what I found it WIS:
Services are based on W212 overview attached
- Service 1: Minor basic service (Service A) includes replacing keyless-go key battery
- Service 2: Major basic service (Service B) includes replacing charcoal cabin filter and replacing keyless-go key battery
- Service 3: Change engine oil and oil filter
- Service 4: Replace brake fluid
- Service 8: Replace engine air filter
- Service 8: Perform rear axle oil change (w/ code 471, manual locking differential)
- Service 10: Clean and lubricate panoramic sliding roof mechanism (w/ code 413, panoramic sliding sunroof)
- Service 11: Replace fuel filter
- Service 12: Replace spark plugs
- Service 13: Replace coolant
- Service 15: Check condition and operation of trailer hitch (w/ code 550, trailer hitch)
- Service 20: Change automatic transmission oil and filter
pierrejoliat (04-27-2021)
Received 1,747 Likes
1922 Ford Model T / no OBD
The FSS on my 2014 model gives me option to reset some services, when leaving other.
I went through the MBNA recommended service for 2016 document I found on their website, and condensed and compiled it into this summary for my E350 4M... Now I filtered this by the options I have (Pano roof, etc). Caveat Emptor.
“A” Service at 12 months or 10,000 miles, then every 2 years or 20k (eg, odd 10k intervals)
“B” Service at 24 months or 20,000 miles, then every 2 years or 20k (eg, even 10k intervals)
Every 10k miles or year (A and B)
Every “B” (20k miles or 2 years)
Additional work:
- Read service data, reset ASSYST PLUS display (A,B)
- Check warning/function lights (A,B)
- Check interior and instrument lighting (A,B)
- Check horn (A,B)
- Check washer fluid (A,B)
- Check exterior for visible damage (A,B)
- Check windshield for damage (A,B)
- Check wiper blades (A,B)
- Oil and filter change (A,B)
- Check brake fluid level (A,B)
- Check coolant level (A,B)
- Inspect tires (A,B)
- Inspect brake pads, rotors (A,B)
- Check/correct tire pressure (A,B)
- Check/correct spare pressure (A,B)
- Check first aid kit expiration (A,B)
- Clean visible area of water deflector (A,B)
- Check parking brake (A,B)
- Check exterior lighting (B)
- Check wipers, washers (B)
- Replace charcoal interior dust filter (B)
- Check poly V belt for wear (B)
- Check vehicle underside for leaks, damage (B)
- Check tires for damage/cracks (B)
- Check condition of steering, tie rods (B)
- Check front axle and ball joints (B)
- Check rear axle and ball joints (B)
- Check spring/strut/shocks (B)
- Check drive shaft flexible couplings (B)
- Check power steering fluid (B)
Additional work:
- Replace brake fluid - every 2 years
- Clean/Lubricate Panoramic Roof - every 30K/3 years
- Replace engine air filter - every 50k/5 years
- Replace spark plugs - every 50k/5 years
- Replace ATF oil/filter - every 60k/6 years
- Replace fuel filter - every 150k/15 years
nightspd (04-28-2021)
So I checked my ASSYST menu and it says:
However it doesn't show Service 12 for Spark Plugs, so I'm wondering if they just marked it as complete despite the fact I didn't have them do them?
