Camshaft sensor leaking!
If the error goes away, shorted actuator. If it stays, remove the pigtail on that one, retest. Be certain, no wire is cut, broken. Definitely a short.
after replacing phasers actuators.... normal
This transient fault is passed history - It got logged while you had the connection opened during pigtail install... meaning fault is Not PRESENT.
"Short circuit to GND" is the Bosch ECU reporting "missing power supply", not realy a zero Ohm issue.
All in all... you're ready to drive after clearing historical faults.
Can you test & compare voltage present in solenoid harness.... it seems your missing 12Volt or bad connector pin contact
Or swap intake and exhaust solenoids, and rescan
Electrically it has a low resistance, like 15.Ohms. Its neither an open circuit, nor short circuit either.
You solenoids have been swapped around ue. good solenoid means bad ECU harness side ...
The live ECU harness side supplies 12V on one pin and some GND pulses on the other pin.
Test by measuring 12V from connector to the engine block GND
Compare results with the other solenoid circuit...
I have given up on trying to figure this out myself. My circumstances are such that I’m not free during the week. My question is, would it be fine to drive it for a couple of miles where there’s a European Indy shop?
There's no guarantee what may happen driving around with this issue active
I think it's on the mild side so long phasers stay locked and not wildly out of control.VVT Solenoids are
You do have 12.5V at the solenoid.... you're missing the ECU pulsed GND or somethings causing the ECU to defaut to the lock position without actuation.
Someone was having similar issue like you........ start from post #59....or much earlier, up to you.
https://mbworld.org/forums/e-class-w...ml#post9230445
The short info is this : A capable person doing DIY on the very same parts you also replaced ( and bit more parts ).
In the end, nothing was wrong at all. Just "bad" install I guess
Hey, thanks for your pics and showing what you bought to fix it!
I have a 2015 E400 4MATIC M276 3.0TT and it looks like I'm facing the same problem.
I know I have a different engine, but did you just happen to buy new cam sensors and new cam solenoids/magnets to fix the problem? Along with the electronics cleaning spray to get the oil off of the electronic engine components? I'm trying to fix my similar leak without opening up the engine and spending much more $$$$ in labor compared to just replacing the sensors & solenoids/magnets while cleaning everything with the electronics spray.
